Re: snow meth/water injection [Re: MoparBilly] #1919715
09/25/15 08:39 PM
09/25/15 08:39 PM
Texas
mprhound Offline OP
mprhound  Offline OP
Texas
Originally Posted By MoparBilly
Charley,
What head gaskets? If you don't mind me asking...
It was a felpro Perma torque don't remember the number off the top of my head
That's what I had to put back on it
Going to put some cometics on it now
Re: snow meth/water injection [Re: Von] #1919804
09/25/15 11:03 PM
09/25/15 11:03 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By Von
What he said...
Im hoping to start building a car for DW in the near future. Motor is a 470 with BS heads and 11.5 comp. I am dropping the gear to a 3.54 and will be using a 9.5 vert. I too am worried about part throttle detonation...
Part throttle detonation is usually not the "destroyer" and can often be handled by altering the timing curve a little. If you are running a vacuum advance unit, buying an adjustable unit can also cure part throttle advance. Fattening the carb in the mid range can also fix it. Although you could address it with an adjustable water system, that is not what you want to do. Part throttle usually means cruise and you would need a LARGE water reservoir to be using it at cruise/part throttle. Water injection systems are ment to be used at WOT. The biggest problem with detonation is that mean sounding ( reads loud) exhaust system you have - you often don't hear it ( detonation ) until this.
Fastest 300
