Re: 420cid build with a new Ritter Aluminum Block
[Re: 69 lawndart]
#1918429
09/23/15 10:34 PM
09/23/15 10:34 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Good luck, hope it works out as we sb guys need something for blocks.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: MR_P_BODY]
#1918482
09/23/15 11:31 PM
09/23/15 11:31 PM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
What is the deck height and lifter angle on these blocks This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle.
[Re: 69 lawndart]
#1918490
09/23/15 11:46 PM
09/23/15 11:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
[quote=MR_P_BODY]What is the deck height and lifter angle on these blocks This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle. [/quot What you have is what I'm looking for... thats why I will watch your build... I have a set of W-9 for one
[Re: MR_P_BODY]
#1918510
09/24/15 12:20 AM
09/24/15 12:20 AM
69 lawndart
Kansas, Topeka
[quote=MR_P_BODY]What is the deck height and lifter angle on these blocks This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle. [/quot What you have is what I'm looking for... thats why I will watch your build... I have a set of W-9 for one I have a set of W9's on my other R3 block (468 cid) with 59 deg lifter angle. That set of heads is a set of Chapman done heads and they are to small for that motor it gives up at 6800 but it pulls hard in the mid range. This one is going to get the W9RP that Curtis Boggs from RFD did.
W9RPw9rp 2
[Re: fishy340]
#1918511
09/24/15 12:21 AM
09/24/15 12:21 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Not to mention aluminum is easier to fix
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 69 lawndart]
#1918513
09/24/15 12:24 AM
09/24/15 12:24 AM
MR_P_BODY
[quote=MR_P_BODY]What is the deck height and lifter angle on these blocks This one is a tall deck (9.6") 48 deg. you can get a short deck and what ever lifter angle. [/quot What you have is what I'm looking for... thats why I will watch your build... I have a set of W-9 for one I have a set of W9's on my other R3 block (468 cid) with 59 deg lifter angle. That set of heads is a set of Chapman done heads and they are to small for that motor it gives up at 6800 but it pulls hard in the mid range. This on is going to get the W9RP that Curtis Boggs from RFD did. My set is the standard Chapmans they ported... I wasnt gonna go that big
[Re: J_BODY]
#1918536
09/24/15 12:59 AM
09/24/15 12:59 AM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
are these blocks actually for sale?? I remember the other attempt at building one it was mentioned it was a "prototype". I hope to have some info after this weekends race if the same guy shows up that I was introduced to at last years race. If not I should still have a contact number.
[Re: pittsburghracer]
#1918542
09/24/15 01:05 AM
09/24/15 01:05 AM
69 lawndart
Kansas, Topeka
Yes I think the blocks are for sale, all I did was E-mail him. I know last time I spoke with him he said that the foundry was having problems casting the steel blocks because of core shift, but the aluminum blocks they weren't having problems with. I was told that the other aluminum block that is running is the prototype block.
[Re: J_BODY]
#1918545
09/24/15 01:17 AM
09/24/15 01:17 AM
MR_P_BODY
Not to mention aluminum is easier to fix ... never saw my W5 head that I tried to have repaired did you. Some aluminum..... well, isn't. Isnt that the truth... my first set had so much crap in the alum that it was useless to even try... when I got my replacement set from mopar they said I could keep them... I tried to weld on them..what a joke.... the set I have now is pretty porous but seal.. with some work
[Re: hudsonhornet7x]
#1918756
09/24/15 01:44 PM
09/24/15 01:44 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
called Kevin at Hughes Engines yesterday about doing a ritter block and he said they have done 4 engines to date and have had no problems. He said they will support 1400 hp easily. just need to make clear what you want done from Ritter before they send the block to Hughes.
Founder and CEO of the Central Valley Mopar Drag Pack
