Re: 420cid build with a new Ritter Aluminum Block
[Re: 69 lawndart]
#1917807
09/23/15 12:29 AM
09/23/15 12:29 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
While were looking at this side of the motor the oil pan will block off the oil return if you have an oil pan gasket lay it up there and you will see the oil return for the time tunnel is blocked off.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1917816
09/23/15 12:37 AM
09/23/15 12:37 AM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
While were looking at this side of the motor the oil pan will block off the oil return if you have an oil pan gasket lay it up there and you will see the oil return for the time tunnel is blocked off. Yes the oil pan will cover most of the original hole that was there that's why there is more of a slot there now. I have also drilled and tapped 4 1/2NPT holes right under the cam next to the back of the mains for oil drain back. I know if gets into the swinging assembly it will cost HP but for now getting the oil back to the pan is more important than windage loss.
[Re: 69 lawndart]
#1917829
09/23/15 01:01 AM
09/23/15 01:01 AM
WHITEDART
bean town ....Ca
Are you bushing the lifters ?????will the lifter uncover the oil hole when its all the way at the bottom or all the way at the top.THIS is another big problem.... if so bushing the block is the easy fix... I would pressurize the water aND oil before I did anything..
[Re: 69 lawndart]
#1917847
09/23/15 01:27 AM
09/23/15 01:27 AM
WHITEDART
bean town ....Ca
You don't have to bush the lifters but I'm thinking you'll need a taller than normal lifter so that when it's at the bottom the hole is not uncovered I've had both style blocks the one with the oil hole behind the lifter and the one with oil hole in the center of the lifter. If you measure from the base of the cam to the top of the oil hole that will tell you how tall of a lifter you will need
[Re: J_BODY]
#1918001
09/23/15 12:40 PM
09/23/15 12:40 PM
WHITEDART
bean town ....Ca
The ones I have seen all take the low deck cover however the block could use a tall deck cover if new holes are made.
[Re: 69 lawndart]
#1918005
09/23/15 12:45 PM
09/23/15 12:45 PM
WHITEDART
bean town ....Ca
check every lifter to be sure that you are ok .they look low when they drill the galley from one side only the hole some times will wander of course. That is why other blocks are drilled from both directions and intersect one another
[Re: WHITEDART]
#1918067
09/23/15 02:10 PM
09/23/15 02:10 PM
Posts: 20,176 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just had to drill and tap (2) new holes on my R3 block for a stock 360 timing cover to work. Not a big issue
[Re: pittsburghracer]
#1918068
09/23/15 02:11 PM
09/23/15 02:11 PM
Posts: 20,176 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Kinda like the looks of this block and I hope all goes well.
[Re: 69 lawndart]
#1918096
09/23/15 02:55 PM
09/23/15 02:55 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Now where are the xr2s.... I'd love to get my hands on a raw casting of one of those.
[Re: 69 lawndart]
#1918268
09/23/15 06:43 PM
09/23/15 06:43 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Are those coolant passages in the deck correct? Something funny looking there.
[Re: 69 lawndart]
#1918305
09/23/15 07:44 PM
09/23/15 07:44 PM
Posts: 20,176 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What brand of roller lifters are those. Thanks for starting this post.
#1918313
09/23/15 08:01 PM
09/23/15 08:01 PM
69 lawndart
Kansas, Topeka
What brand of roller lifters are those. Thanks for starting this post. No problem, thanks for all of the input. The lifters are Morel +.300 height and .200 intake offset .904 diameter.
