Re: Oil Pressure gauge line
[Re: DusterKid]
#1916729
09/21/15 02:37 PM
09/21/15 02:37 PM
Challenger 1
Cincinnati, Ohio
-3 for sure.
Now you know why copper should not be on a car, especially a race car. I don't care that it(the gauge) came with copper, now you know why.
[Re: DusterKid]
#1916730
09/21/15 02:41 PM
09/21/15 02:41 PM
Posts: 43,367 Bend,OR USA
Cab_Burge
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You'll need the appropriate AN fittings, IE #3 AN with either 1/16 or 1/8 NPT for the block and a similar fitting for the back of the gauge ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I like and use TFE type(teflon lined) AN hose for all my oil sytems, it will take a lot of pressure and live forever ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) On the AN size #3 or # 4 will work, buy which ever one you can get all the fittings you need the easest ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) (SP?) BTW, do you want to buy a premade hose or do you want to make yourself a custom made cut to length hose for your car ![work work](/ubbthreads/images/graemlins/custom/work.gif) I make my own, sometimes that can be challenging the first couple of times you make them, you will need a good cut off wheel for a dremel tool if you make your own ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: Cab_Burge]
#1916737
09/21/15 02:50 PM
09/21/15 02:50 PM
Challenger 1
Cincinnati, Ohio
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You'll need the appropriate AN fittings, IE #3 AN with either 1/16 or 1/8 NPT for the block and a similar fitting for the back of the gauge ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I like and use TFE type(teflon lined) AN hose for all my oil sytems, it will take a lot of pressure and live forever ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) On the AN size #3 or # 4 will work, buy which ever one you can get all the fittings you need the easest ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) (SP?) BTW, do you want to buy a premade hose or do you want to make yourself a custom made cut to length hose for your car ![work work](/ubbthreads/images/graemlins/custom/work.gif) I make my own, sometimes that can be challenging the first couple of times you make them, you will need a good cut off wheel for a dremel tool if you make your own Never seen or heard of 1/16" pipe thread, they don't use them around cars and race cars. Maybe less emotions? Be sure before you post Cab IMO.
[Re: DusterKid]
#1916766
09/21/15 03:21 PM
09/21/15 03:21 PM
Posts: 13,417 Marion, South Carolina [><]
an8sec70cuda
[Re: rickseeman]
#1916769
09/21/15 03:25 PM
09/21/15 03:25 PM
Challenger 1
Cincinnati, Ohio
The only fitting for the back of the gauge that I know of is -4. Jegs has it. Most gauges I have seen are 1/8" male pipe thread and you use a 1/8NPT X #3 male AN adaptor along with a coupler or female 1/8" NPT AN adaptor. ![](http://i21.photobucket.com/albums/b260/challenger19711/After%2012-8-14/IMG_75991.jpg) Every line built, pressure tested and tagged by me. I built the entire car everything, except the chassis and body was built by Mike Bowen In Montrose Mi, near Flint. 3 AN lines.
[Re: DusterKid]
#1916774
09/21/15 03:28 PM
09/21/15 03:28 PM
an8sec70cuda
Must be. http://www.summitracing.com/search/department/fittings-hoses/section/fittings-plugs/part-type/an-to-npt-fittings/npt-size/1-16-in?N=4294951003%2B4294951002%2B4294948844%2B4294920995&SortBy=Default&SortOrder=Ascending
https://www.google.com/#q=1%2F16%22+npt+fittings
OK, for some reason they won't highlight as links, but copy and paste those 2 links.
[Re: Challenger 1]
#1916789
09/21/15 03:42 PM
09/21/15 03:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You'll need the appropriate AN fittings, IE #3 AN with either 1/16 or 1/8 NPT for the block and a similar fitting for the back of the gauge ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I like and use TFE type(teflon lined) AN hose for all my oil sytems, it will take a lot of pressure and live forever ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) On the AN size #3 or # 4 will work, buy which ever one you can get all the fittings you need the easest ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) (SP?) BTW, do you want to buy a premade hose or do you want to make yourself a custom made cut to length hose for your car ![work work](/ubbthreads/images/graemlins/custom/work.gif) I make my own, sometimes that can be challenging the first couple of times you make them, you will need a good cut off wheel for a dremel tool if you make your own Never seen or heard of 1/16" pipe thread, they don't use them around cars and race cars. Maybe less emotions? Be sure before you post Cab IMO. Yes they make 1/16 pipe fittings... I have a 1/16 pipe plug on my heads to block off the oil to the heads ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: DusterKid]
#1916814
09/21/15 04:25 PM
09/21/15 04:25 PM
Posts: 31,112 Oregon
AndyF
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You can use either #3 or #4 lines. I usually use #3 lines for the oil pressure gauge unless it is a super long run and then I'd use #4. You need the proper adapters for the gauge as well as the engine block. I use a bulkhead fitting for going thru the firewall rather than drilling a big hole and pushing the line thru.
[Re: AndyF]
#1916818
09/21/15 04:31 PM
09/21/15 04:31 PM
Challenger 1
Cincinnati, Ohio
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You can use either #3 or #4 lines. I usually use #3 lines for the oil pressure gauge unless it is a super long run and then I'd use #4. You need the proper adapters for the gauge as well as the engine block. I use a bulkhead fitting for going thru the firewall rather than drilling a big hole and pushing the line thru. #4 is huge for a oil pressure gauge and will just make your car weigh more and be more bulky around the gauges and motor, plus the fittings cost more. If he was using 1/8 OD line now that #3 is like 3 time as large which is plenty even on a super super long run. IMO Bulk head fittings just add to the cost, weight and more places to leak/come loose.
[Re: Challenger 1]
#1916835
09/21/15 05:03 PM
09/21/15 05:03 PM
MR_P_BODY
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You can use either #3 or #4 lines. I usually use #3 lines for the oil pressure gauge unless it is a super long run and then I'd use #4. You need the proper adapters for the gauge as well as the engine block. I use a bulkhead fitting for going thru the firewall rather than drilling a big hole and pushing the line thru. #4 is huge for a oil pressure gauge and will just make your car weigh more and be more bulky around the gauges and motor, plus the fittings cost more. If he was using 1/8 OD line now that #3 is like 3 time as large which is plenty IMO even on a super super long run. IMO #4 is big... your only playing with the air pressure thats in the line to work the gauge ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#1916845
09/21/15 05:18 PM
09/21/15 05:18 PM
Challenger 1
Cincinnati, Ohio
I discovered you must type "link" or anything in the second box that pops up to make it a live link with blue letters. I did find 1/16" pipe taps, so I was wrong, they make 1/16" pipe fittings. But I have never seen them used around cars, it would be a weak fitting that could crack too easy IMO. And what would you use it for around cars that small?, even mechanical fuel injection uses 1/8" fittings.
[Re: MR_P_BODY]
#1917156
09/22/15 12:27 AM
09/22/15 12:27 AM
Cab_Burge
I've always used the copper 1/8" line for my oil pressure gauges and never had an issue until this weekend when the copper line cracked and started to leak. Luckily my dad caught it early and was a simple fix, but it could have gotten ugly. I'm going to change to the stainless steel hose but should -3 AN or -4 AN be used? Is there any special fittings that will be needed when I change over? You can use either #3 or #4 lines. I usually use #3 lines for the oil pressure gauge unless it is a super long run and then I'd use #4. You need the proper adapters for the gauge as well as the engine block. I use a bulkhead fitting for going thru the firewall rather than drilling a big hole and pushing the line thru. #4 is huge for a oil pressure gauge and will just make your car weigh more and be more bulky around the gauges and motor, plus the fittings cost more. If he was using 1/8 OD line now that #3 is like 3 time as large which is plenty IMO even on a super super long run. IMO #4 is big... your only playing with the air pressure thats in the line to work the gauge I used a 1/4 inch copper oil pressure line on one of my old race cars years ago, the oil pressure gauge reacted much quicker and faster than the other cars with 1/8 copper oil pressure lines ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) NHRA ended up outlawing 1/4 inch copper oil pressure and fuel pressure lines several years later, maybe I should switch my cars to # 3 AN pressure lines now ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Cab_Burge]
#1917386
09/22/15 01:53 PM
09/22/15 01:53 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
mine came with a nylon line,been on there for 10 years and many thousand miles.mabey I should think of upgrading.
[Re: bonefish]
#1917412
09/22/15 02:20 PM
09/22/15 02:20 PM
Challenger 1
Cincinnati, Ohio
mine came with a nylon line,been on there for 10 years and many thousand miles.mabey I should think of upgrading. I have used small copper line and that plastic lines on street cars over the years before I went racing. One time I was doing some soldering under my dash and by accident I melted a hole on my plastic oil pressure line and didn't know it until the next time I started the car. Then I had oil dripping on my feet, then I went to the small copper line which lasted for years on the street. For a race car braided line should be used IMO.
[Re: DusterKid]
#1917419
09/22/15 02:24 PM
09/22/15 02:24 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Now what do you guys do when the line break and dump oil on the track? There is an old trick to get a brass 1/8" npt fitting and solder it closed then drill a # 60 drillbit hole in it. When bled it will allow oil pressure to pass but it wont empty your pan in 3 seconds. https://www.vansaircraft.com/cgi-bin/sto...;product=va-128This is one example.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
