Page 4 of 7 1 2 3 4 5 6 7
Re: K frame strength [Re: feets] #1911519
09/13/15 09:13 AM
09/13/15 09:13 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Thats what Im getting at. Look at all those right angles just waiting to become 80 degrees.
The factory K had way way more reinforcement around the engine mounts.
Are those the rack mounts just hanging in space? One big [pothole will tweak those in a hurry. Ditto for the control arm mounts. At best the alignment will never hold and after enough flexing complete failure will happen.
For drag only it would likely be ok but I'd not use something like that on the streetor road course.
Angry white pureblood male
Re: K frame strength [Re: feets] #1911557
09/13/15 11:38 AM
09/13/15 11:38 AM
NY
X
XVracing Offline
XVracing  Offline
X
NY
Your test rig doesn't have to do anything more than be the same for each test. Rigidity of the rig is most important thing, how the K is restrained is probably least important as long as it's safely held in place and is the same for each test.
Allowing movement at the mounting points would make the tests inconsistent as the angles would change....
CR
Re: K frame strength [Re: Supercuda] #1911559
09/13/15 11:42 AM
09/13/15 11:42 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By Supercuda
...wow, that's pretty impressive. In regards to lack of adequate load paths. Seems fine for a drag car, but I certainly wouldn't spend any money for that.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: K frame strength [Re: CKessel] #1911692
09/13/15 03:07 PM
09/13/15 03:07 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Originally Posted By CKessel
Chris, thank you for chiming in on this with Peter, Feets, JCC etc. You and Peter especially since you have been exposed to the test rigs and stuff with current and former employers and can weed through the feces and shinola. I'm interested in this as I'm not a believer of the A/M units as there is not enough cycle time, miles, crappy roads, Dukes Of Hazard imitations etc on them to prove they are worthy of purchasing and using. I know that eventually we will have no choice when nothing else available to us[ hint, hint for someone to make]. I've been working on the 70 k unit that will be going into my 65 and am interested in where worthwhile improvements can be made as I plan to autocross, road course, drag etc the car. Two of the things I've done are: add in 108 spot/plug welds around the k perimeter compared to 37 factory spot welds, box in the strut rod mount area on the backside of the k instead of just using the 2 attachment spots from Ma Mopar. Salivating on this subject fellas!!!!! Keep at it.
Maybe stating the obvious, but if this thread has real data at some point, I bet your proposed solution with come out on top. However we shouldn't completely discount the AF solutions, they do provide some solutions the OEM cannot.
On the restraint issue, sure would like to hear some other inputs on whether the test rig should supply any artificial restraint (rigidity), or let the chips fall were they may by having minimal restraint on the tested K.
"inconsistent" to me means non repeatable. If the results are inconsistent between K's, that the intention of the test I thought.
Re: K frame strength [Re: feets] #1911801
09/13/15 07:56 PM
09/13/15 07:56 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I took inconsistent to mean non repeatable.
Re: K frame strength [Re: XVracing] #1912266
09/14/15 03:20 PM
09/14/15 03:20 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Originally Posted By XVracing
BTW the K does a lot more than hold the frame rails straight. Again, some things you can't measure statically. It has to support the lower control arms as pointed out, and also support the engine as well as counteract the torque.
Just because the aftermarket K frame doesn't look as big as the factory, doesn't mean it's as strong, or stronger...
A Torsional Rigidity test can be done with the K installed or not, the better the rails are without the K installed, the better it will be with it installed.
My suggestion would be to twist the K members out of the car.
CR
These are the exact things I was talking about in this thread.
What are you getting for your money? Is it any improvement over the stock hardware? What kind of rigidity will it add to your car?
I have the tools, material, and metrology to build a rack to use for testing out of the car.
- Stu Harmon
Re: K frame strength [Re: GoodysGotaCuda] #1912586
09/14/15 11:00 PM
09/14/15 11:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Oh you ought to hear the praise heaped on that unit. Even here.
Don't be the exception.
Re: K frame strength [Re: feets] #1912621
09/14/15 11:26 PM
09/14/15 11:26 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
So are you only testing factory stock K frames that have many years of abuse or only NOS units that have been stored in an oxidation free environment?
Or will the K frame be a reinforced K frame by someone like Firm Feel?
Just those 3 examples of factory K frames will yield varied results.
Better yet lets dig up a K frame from an Original Dukes of Hazard jump car.......
Re: K frame strength [Re: PHJ426] #1912646
09/14/15 11:42 PM
09/14/15 11:42 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My 65 cuda is mostly a purpose built drag car that is street legal. Some rules changed in KOS and inner fenders were no longer required. Already had a custom chrome moly tube k member with coilovers and rack, which is light years better handling than stock. But, when the inner fenders were removed the front got flemsy. Then removed the radiator support, including lower support. Thank goodness the k-member is welded in. This stamped sheet metal mentioned earlier in this thread is a huge part of rigidity in your front suspensions.
Re: K frame strength [Re: PHJ426] #1912665
09/14/15 11:51 PM
09/14/15 11:51 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I don't think years of use will effect the test results, assuming all welds are intact, there are no fatigue cracks, etc
Re: K frame strength [Re: jcc] #1912684
09/15/15 12:04 AM
09/15/15 12:04 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Pick up an un-welded, no reinforcement k frame to about 3 feet and drop it flat to the pavement and listen to the noise it makes. Then box/weld it and do the same test. Big difference in the sound. I think that means something...
I am glad you guys want to science the k frames but I can tell you already - real world testing proves beyond any doubt that it's necessary and makes a big difference in a cars handling.
And as to adding more spot welds vs a full weld - the full weld wins every time. Break out the mig welder, weld everything.
Re: K frame strength [Re: ThermoQuad] #1912719
09/15/15 12:42 AM
09/15/15 12:42 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Regarding welding everything, no real downside. The problem is that I see, and another member has already mentioned increasing the oem spot welds from mid 30's to over a hundred, the spot welds are structurally located better then edge welding, IMO. And the problem with spot welding 40+ years later, is getting reasonably clean metal inside for quality spot welds. Edge welding has this problem to a lesser degree. Doing both of course is also a solution.
Re: K frame strength [Re: PHJ426] #1912793
09/15/15 03:49 AM
09/15/15 03:49 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Well, let's face it, we can't turn back the sands of time and 99.9% of people out there are not using a NOS K-frame that have been stored in an oxidation free environment that's also never seen the road. Personally, I think it's 100% ok to use factory, used K-frames. Just test a larger sample size instead of testing one. It will help smooth out any variation in the data. I'd test both a stock OEM one, a stock one that's been welded up more, a reinforced Firm-Feel (or similar), and any aftermarket tubular setup that could be borrowed.
Re: K frame strength [Re: feets] #1912809
09/15/15 07:20 AM
09/15/15 07:20 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Since most folks don't have a stockpile of NOS K frames, a good used unit makes the most sense to me. If not tested to the point of failure that stock K can be reinforced and retested to see if the common tricks actually help or not.
Re: K frame strength [Re: ruderunner] #1912961
09/15/15 12:58 PM
09/15/15 12:58 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
iagree 100%
Re: K frame strength [Re: PHJ426] #1913024
09/15/15 02:43 PM
09/15/15 02:43 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I would test the stock K frame I have on hand. In my opinion it is a fair example of what is in use on the typical car today. It has no heavy rust or damage.
A pretty paint job on a restored K frame will not make it any more structurally sound.
After testing the stock piece I can weld it up like so many others do and test it again. That would be a fair test of what welding does for a K frame. I haven't seen that tested either.
- Stu Harmon
Re: K frame strength [Re: XVracing] #1913033
09/15/15 03:02 PM
09/15/15 03:02 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Chris,
I'm ready to go when you guys are.
Can you send me a K-frame? If so, I'll get the ball rolling with the other guys too.
- Stu Harmon
Re: K frame strength [Re: feets] #1913146
09/15/15 05:21 PM
09/15/15 05:21 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Let the testing begin...
Carl Kessel
Re: K frame strength [Re: feets] #1914134
09/16/15 11:54 PM
09/16/15 11:54 PM
NY
X
XVracing Offline
XVracing  Offline
X
NY
What's your credit card number, would be happy to!!!
CR
Re: K frame strength [Re: feets] #1914158
09/17/15 12:26 AM
09/17/15 12:26 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
The NOS K frame deal was tongue in cheek no doubt its cost prohibitive especially for a hemi E body K................
It was just an observation of 40+ year old abused pot hole ridden street use vs a pristine example that has had no stress at all.
Just like the cars unibody structure the 40 + year old high mileage example will have had stress applied to it vs a virgin tub.
Trust me spot welds do eventually fatigue.
I worked at a Borg Warner plant that made transmission bands the spot welds on a few select welds were tested via destructive testing every shift. They know how to do QC in this century, back in the last century Americans laughed at Demming.
