Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1913066
09/15/15 03:44 PM
09/15/15 03:44 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Consider an SMR adapter, or designing something similar? I picked one up used for $200 a few weeks ago of off Craigslist. A few guys in the race section seem to believe it will work for a 512 build (minus the flex plate).
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1913318
09/15/15 10:21 PM
09/15/15 10:21 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We race Ultrabell's with trans brakes all the time w/o issue. And you're worried about a conservative street car? That Ultrabell bolted on is every bit as good as the prehistoric sand casting. The bolts are for clamp load, not shear. It's clamp load that holds everything together. If its torqued you won't have an issue. If it bothers you, stud it. Good luck getting it dialed in on center with-in .005". If not, trimming a block for starter sounds a whole lot easier than what you have planned.
Doug
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1913436
09/16/15 12:49 AM
09/16/15 12:49 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
i have the ultra bell on my 512cid a518 68 charger so far it's good.
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: MarkZ] #1913750
09/16/15 03:29 PM
09/16/15 03:29 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Thats pretty much a smoking deal on that! Retail is like $670.
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1913788
09/16/15 04:12 PM
09/16/15 04:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The Ultrabell is SFI approved. I bought one years ago but have yet to install it. Maybe it'll go on the Imperial.
- Stu Harmon
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1913829
09/16/15 04:45 PM
09/16/15 04:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Don't underestimate the strength of the 727 case. I personally think it will handle any amount of power your engine has. High frequency cleans the weld so I wouldn't worry to much about that, just weld both sides and make tight joints. I've thought of this many times but never got around to trying it myself, good luck, got my vote!
Waiting for results!
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: cudaman1969] #1914023
09/16/15 09:29 PM
09/16/15 09:29 PM
dogdays Offline
dogdays  Offline
I'm pretty sure the Torqueflite cases are die castings, same as the aluminum steering boxes. They're too smooth to be sand castings.
R.
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #1914179
09/17/15 12:53 AM
09/17/15 12:53 AM
West Central Wisconsin
DeMopuar Offline OP
DeMopuar  Offline OP
It's gonna take a bit to get the jig made properly -- but I will most certainly post the results when I get that far.
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: feets] #1914485
09/17/15 03:29 PM
09/17/15 03:29 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Same here, got mine during that group-buy that happened on here a few years ago!
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #3168832
08/18/23 02:24 PM
08/18/23 02:24 PM
Charlie Lake, BC Canada
RT 440 Offline
RT 440  Offline
Just wondering if you ever completed this project, do you still have the Jigs or Pictures of them?
Thanks!
Ryan
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: RT 440] #3168988
08/19/23 10:06 AM
08/19/23 10:06 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Sounds like he's going to weld a B/RB bellhousing onto a 518
You may consider using a A618/47RH. It can handle more power than the A518. I would assume you could weld on the ultrabell since it to is aluminum(along with the bolts). I believe the pump bolt pattern is the same between the 518 and 47 so the ultrabell would be an easier install. I see they make a adapter plate to install a ZF8 to a big block, That would be even better than any 518/47rh but would need a controller to run it.
link
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: Moparite] #3169434
08/21/23 02:14 PM
08/21/23 02:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Originally Posted by Moparite
Quote
link
Difference from a 518 to a 618, other than the bellhousing size, is the internals mainly in the clutch/steel count of the OD section, which can easily be built to 618/47R* spec... you would not want to run the diesel spec valvebody behind a gas engine .
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: DeMopuar] #3169450
08/21/23 03:19 PM
08/21/23 03:19 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Wouldn't a gear vendors OD be a better route????
Re: 727 Aluminum Case Type //// A518 Aluminum Case Type [Re: gtx6970] #3169688
08/22/23 01:55 PM
08/22/23 01:55 PM
moparx Offline
moparx  Offline
it could be.
however, i priced out a JW Ultra bell [big block], a rebuild kit for the A518, a valvebody kit, and billet servo kits, and it came in roughly $1000.00 cheaper than a gear vendors unit.
i did not include any driveshaft work because one would be doing it [shortening or replacing the driveshaft] regardless of which way one went.
i also didn't include a converter, because of so many choices one could make.
the A518 also has a more favorable [in my opinion] overdrive ratio at .68 than the gear vendor's .072.
it [the A158] is also a shorter package overall, unless you have a "shorty" 727 to start with.
the A518 may require some tunnel mods, but the gear vendors may, or may not require some as well.
remember, this is just my opinion/observation.
your mileage will vary.
beer
