Re: 727 Aluminum Case Type //// A518 Aluminum Case Type
[Re: DeMopuar]
#1913436
09/16/15 12:49 AM
09/16/15 12:49 AM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
i have the ultra bell on my 512cid a518 68 charger so far it's good.
[Re: DeMopuar]
#1913788
09/16/15 04:12 PM
09/16/15 04:12 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The Ultrabell is SFI approved. I bought one years ago but have yet to install it. Maybe it'll go on the Imperial.
[Re: feets]
#1914485
09/17/15 03:29 PM
09/17/15 03:29 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Same here, got mine during that group-buy that happened on here a few years ago! The Ultrabell is SFI approved. I bought one years ago but have yet to install it. Maybe it'll go on the Imperial.
[Re: RT 440]
#3168988
08/19/23 10:06 AM
08/19/23 10:06 AM
Posts: 1,017 rust belt
Moparite
rust belt
Sounds like he's going to weld a B/RB bellhousing onto a 518 You may consider using a A618/47RH. It can handle more power than the A518. I would assume you could weld on the ultrabell since it to is aluminum(along with the bolts). I believe the pump bolt pattern is the same between the 518 and 47 so the ultrabell would be an easier install. I see they make a adapter plate to install a ZF8 to a big block, That would be even better than any 518/47rh but would need a controller to run it. link
[Re: Moparite]
#3169434
08/21/23 02:14 PM
08/21/23 02:14 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
Sounds like he's going to weld a B/RB bellhousing onto a 518 You may consider using a A618/47RH. It can handle more power than the A518. I would assume you could weld on the ultrabell since it to is aluminum(along with the bolts). I believe the pump bolt pattern is the same between the 518 and 47 so the ultrabell would be an easier install. I see they make a adapter plate to install a ZF8 to a big block, That would be even better than any 518/47rh but would need a controller to run it. link Difference from a 518 to a 618, other than the bellhousing size, is the internals mainly in the clutch/steel count of the OD section, which can easily be built to 618/47R* spec... you would not want to run the diesel spec valvebody behind a gas engine .
[Re: gtx6970]
#3169688
08/22/23 01:55 PM
08/22/23 01:55 PM
Posts: 19,641 north of coder
moparx
Wouldn't a gear vendors OD be a better route???? it could be. however, i priced out a JW Ultra bell [big block], a rebuild kit for the A518, a valvebody kit, and billet servo kits, and it came in roughly $1000.00 cheaper than a gear vendors unit. i did not include any driveshaft work because one would be doing it [shortening or replacing the driveshaft] regardless of which way one went. i also didn't include a converter, because of so many choices one could make. the A518 also has a more favorable [in my opinion] overdrive ratio at .68 than the gear vendor's .072. it [the A158] is also a shorter package overall, unless you have a "shorty" 727 to start with. the A518 may require some tunnel mods, but the gear vendors may, or may not require some as well. remember, this is just my opinion/observation. your mileage will vary. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
