You guys were right about the bigger carb #1899193
08/25/15 05:00 PM
08/25/15 05:00 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
It's faster with the 950 over the 750.
Got it to go 12.11 with the new 750( air was terrible)
Ended up at 11.91 with the 950. Best 60 foot to date with car on that pass.
Didn't have a chance to jet it down, know I left ET on the table, but with moving timing around and swapping carbs around it was enough for one night.
Car acts funny with the 750, doesn't rap crisply, accelerates lazy.
Put the 950 on, in the water box car raps so quick it hits the shift light ultra fast, sounds different even, accelerates faster.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: B3422W5] #1899197
08/25/15 05:08 PM
08/25/15 05:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the thing with the SB.... they love the air...
then you just put enough fuel to it to burn right to
make the power... but they love air
wave
Re: You guys were right about the bigger carb [Re: B3422W5] #1899214
08/25/15 05:42 PM
08/25/15 05:42 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
LOL ......
Re: You guys were right about the bigger carb [Re: B3422W5] #1899240
08/25/15 06:20 PM
08/25/15 06:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not surprising at all. You seemed to be basing your 750 choice by stating "it's only a 318". The size of motor was irrelevant. It made X HP and that HP needs some air flow. The small venturi of the 750, at least in my mind is way too small for about anything that makes decent power, regardless of inches
Re: You guys were right about the bigger carb [Re: B3422W5] #1899249
08/25/15 06:33 PM
08/25/15 06:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What was the reason it wouldnt rev? I assume its fixed?
Re: You guys were right about the bigger carb [Re: B3422W5] #1899251
08/25/15 06:42 PM
08/25/15 06:42 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
After the season think i am going to stick 4.56 gears in it, and remove these 4.10's. Trapping at barely 6k at the stripe
Problem is this hydraulic cam and springs are going to be maxed at 6500.
Might put a solid in it, have to talk to Dwayne about that...
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: Hot 340] #1899253
08/25/15 06:47 PM
08/25/15 06:47 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Timing was off, guys at a shop next door used a fancy setup( digital deal) and set it wrong.
I went and bought my own light.
Plus this little motor doesn't have a lot of grunt from a roll in high gear.
Had too high of fuel pressure( 8), changed it to 6.5, new plugs, and the 750 shiny new carb is a dog
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: B3422W5] #1899255
08/25/15 06:49 PM
08/25/15 06:49 PM
Covington Georgia
RV2 Online content
RV2  Online Content
Covington Georgia
Interested in your combo would you share more info?
Re: You guys were right about the bigger carb [Re: RV2] #1899260
08/25/15 06:58 PM
08/25/15 06:58 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
30 over 318 magnum
Lightened 340 crank, scat rods, diamond Pistons
Magnum RT heads, 2.02 valves, massaged.
Dual plane, air gap knock off
950 proform
231-238@50 hydraulic cam, 595 gross intake lift
10.44 compression
Cheapy 99 dollar 1 5/8 headers into dyno max bullets
8 inch convertor
904
4.10 gear, 28 inch tire, 3415 with me in it, flat hood.
71 New Yorker rear shocks, CE 3 way fronts, shift at 6200, trap at 6000
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: B3422W5] #1899262
08/25/15 07:00 PM
08/25/15 07:00 PM
Covington Georgia
RV2 Online content
RV2  Online Content
Covington Georgia
I ask because my son is building his first car, it's a 71 Demon and he's starting off with a 318.
Re: You guys were right about the bigger carb [Re: B3422W5] #1899277
08/25/15 07:32 PM
08/25/15 07:32 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I see a solid lifter cam
in your future.
Re: You guys were right about the bigger carb [Re: B3422W5] #1909805
09/10/15 11:20 AM
09/10/15 11:20 AM
Earth
Rob C Offline
Rob C  Offline
Earth
IMO, you have certainly have done the job quit well.
Re: You guys were right about the bigger carb [Re: B3422W5] #1909808
09/10/15 11:28 AM
09/10/15 11:28 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Nice run! I vote for the solid cam and more gear!
Re: You guys were right about the bigger carb [Re: B3422W5] #1909836
09/10/15 12:13 PM
09/10/15 12:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
They usually are................good deal and it would be even faster totally dialed in........the carb that is. thumbs
Re: You guys were right about the bigger carb [Re: B3422W5] #1909869
09/10/15 01:04 PM
09/10/15 01:04 PM
an8sec70cuda Offline
Glad you got that figured out!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: You guys were right about the bigger carb [Re: B3422W5] #1909886
09/10/15 01:27 PM
09/10/15 01:27 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Still puzzles me about the 750 not working. Almost think there is internally something wrong with it. Shouldn't be that much difference( and I know the 950 is a wee bit fat)
Just surprised the bigger carb is so much better. I would have thought even a 650 would supply enough fuel.
Learn something every day..... Lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: B3422W5] #1909898
09/10/15 01:41 PM
09/10/15 01:41 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
AIR FLOW........the fuel is not the issue.........LOL!!!!
Re: You guys were right about the bigger carb [Re: B3422W5] #1909902
09/10/15 01:44 PM
09/10/15 01:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My stock stroke 360 was quicker and faster every time I went bigger and ended up w/an 850 speed demon(flowed 930)and went a best of 11.88 @ 114 mph at 3200+ lbs at L.A.C.R.`s high elevation track.........
Re: You guys were right about the bigger carb [Re: Monte_Smith] #1909905
09/10/15 01:45 PM
09/10/15 01:45 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I know, more air, more fuel, equals more power.
My point was at 6200 rpm max, how much air can 323 inches gulp in and burn.
My guess is some carb guru could probably put a 650 on this little motor and get it to run better than I have gotten it to run with a 950... Lol
1.41 best 60 foot
6.60 at 103.90 1/8
Re: You guys were right about the bigger carb [Re: B3422W5] #1909915
09/10/15 02:03 PM
09/10/15 02:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How much HP does the 323 make? You can't make HP without air and fuel regardless of CI.
