Re: Oil Pressure on the Brakes [Re: ahy] #1914850
09/18/15 06:50 AM
09/18/15 06:50 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Another thing Milodon pointed out was that rear section is not filled 100% with oil. By necessity, it's mostly filled with the oil pump. Remember that's what the section is for. Especially if you are using a high volume taller pump, the body will displace most of that rear section.
If you where running a small block with an external pump, you could eliminate that section and run the cutout all the way to the back of the pan.
Re: Oil Pressure on the Brakes [Re: autoxcuda] #1914999
09/18/15 12:49 PM
09/18/15 12:49 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Steve -- Thanks for the info.. thought I'd read it previously as well as seen the pics... I know that YOU were directly involved with Miloden for developing these Mopar road race pans.
Gold66Cuda -- I like your shared concern and the idea of an additional drain plug... I might do that as I do have the extra time ahead of my engine build.
