Thicker Head gasket to bring down compression
#1909197
09/09/15 01:31 PM
09/09/15 01:31 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
I have 2 motors that I'm thinking about putting on the street 90% and 10% race. Has anybody ever run the .095 Cometic head gaskets to lower their compression for pump gas. What's the down sides? They will never be full effort race motors. One is a 493" aluminum Indy block with -1 heads and the other is a 500" iron World block with -1 aluminum heads. Thanks in advance for the input.
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Thicker Head gasket to bring down compression
[Re: 65 Hemi]
#1909228
09/09/15 02:10 PM
09/09/15 02:10 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Where is your compression at right now?
[Re: pittsburghracer]
#1909286
09/09/15 03:23 PM
09/09/15 03:23 PM
65 Hemi
San Diego CA
493" aluminum is at 13.46:1 and the 500" iron block is at 12.4:1. I have 2 other race cars and race motors so these will very seldom see the track if at all. Where is your compression at right now?
Doug
[Re: 65 Hemi]
#1909331
09/09/15 04:28 PM
09/09/15 04:28 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
I got .125 inch. Downside is $400 for the gaskets. Never again.......
[Re: 65 Hemi]
#1909341
09/09/15 04:39 PM
09/09/15 04:39 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
If you just plan to DRIVE it on the street, pump gas and even high compression is not a big deal. Anything will drive on pump gas, with the timing a little low. When you choose to stick your foot in it is the issue. So you would either need the timing to be really low all the time, or lower the compression.
At the Pump Gas Drags, we ran some really high compression stuff, WITH a lot of nitrous and had no issues, just had the timing really low. But that's a RACE scenario. For just cruising, it still be snappy, plus safe for the assorted blast here and there.........I would lower the compression
[Re: Monte_Smith]
#1909353
09/09/15 04:57 PM
09/09/15 04:57 PM
65 Hemi
San Diego CA
Monte, would you lower compression by a thicker head gasket or do you think that is just a band aid. I just hate to mill the pistons down and re balance them. These motors have good part and I hate to be penny wise and dollar foolish! I just don't want to be running around all the time to chase race gas. I want to hop in and drive 50-100 miles. Both of these will always be NA motors. Like I said I have 2 race motors 583 Aluminum Hemi Indy 426-1 RA motor and a 583 B1MC motor for my race cars. Thanks y'all for the input. If you just plan to DRIVE it on the street, pump gas and even high compression is not a big deal. Anything will drive on pump gas, with the timing a little low. When you choose to stick your foot in it is the issue. So you would either need the timing to be really low all the time, or lower the compression.
Doug
[Re: dogdays]
#1909414
09/09/15 06:32 PM
09/09/15 06:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Run E85 and keep the compression.
R. If you have E-85 in the area(if its easy to find) thats all I would do... change over the carb to E-85 which is probably about the same cost as the head gaskets EDIT this is based on if you have enough fuel pump to supply 30% more fuel
[Re: 65 Hemi]
#1909445
09/09/15 07:36 PM
09/09/15 07:36 PM
65 Hemi
San Diego CA
The issue with E85 is the stations are few and far between. 2 within a 35 mile radius and one had water in their e85 when I ran it before. Also with the humidity here I had a little trouble and even tried blowing nitrogen on top of the tank when the car would sit for 3-4 weeks durning the winter.
Doug
[Re: 65 Hemi]
#1909446
09/09/15 07:37 PM
09/09/15 07:37 PM
65 Hemi
San Diego CA
The issue with E85 is the stations are few and far between. 2 stations within a 35 mile radius and one had water in their e85 when I ran it before. Also with the humidity here I had a little trouble and even tried blowing nitrogen on top of the tank when the car would sit for 3-4 weeks durning the winter.
Doug
[Re: Monte_Smith]
#1909555
09/09/15 10:51 PM
09/09/15 10:51 PM
Posts: 2,122 Byron, NY
W.I.N. Racing
Byron, NY
If you mill the pistons .040 to put them in the hole more, or put .040 of head gasket on it...........what's is the difference other than making the top of the piston thinner. I would run a thicker gasket and then you always have the easy option of returning the compression
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 65 Hemi]
#1909568
09/09/15 11:04 PM
09/09/15 11:04 PM
65 Hemi
San Diego CA
Thanks for all the input. I will order the gaskets and rest easy when I install them.👍🏻
Doug
[Re: Monte_Smith]
#1910438
09/11/15 11:01 AM
09/11/15 11:01 AM
Posts: 2,475 SW Ohio
cgall
SW Ohio
On my pump gas engine I have Ross flat tops and the .084 Cometic gasket, compression is 10.3 to 1. This worked well for me since the block had been decked quite a lot and now the intake fits well with the standard intake gaskets. If your intake does not fit well when you change the head gasket, do a search and use a THICKER intake gasket. Sorry, I changed that, since you are adding to the deck height.
