Re: Thicker Head gasket to bring down compression [Re: 65 Hemi] #1909730
09/10/15 03:23 AM
09/10/15 03:23 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Best choice
Re: Thicker Head gasket to bring down compression [Re: Monte_Smith] #1910438
09/11/15 11:01 AM
09/11/15 11:01 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
On my pump gas engine I have Ross flat tops and the .084 Cometic gasket, compression is 10.3 to 1. This worked well for me since the block had been decked quite a lot and now the intake fits well with the standard intake gaskets. If your intake does not fit well when you change the head gasket, do a search and use a THICKER intake gasket. Sorry, I changed that, since you are adding to the deck height.
Re: Thicker Head gasket to bring down compression [Re: 65 Hemi] #1910448
09/11/15 11:23 AM
09/11/15 11:23 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thanks for the input.👍
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
