Page 1 of 4 1 2 3 4
Cross Bolted Main Conversion #1907574
09/06/15 06:11 PM
09/06/15 06:11 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I have been holding on to these pics for a while. The first engine that I have installed cross bolted main caps in has successfully made trips to the track and lived. Knock on wood wink
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907575
09/06/15 06:12 PM
09/06/15 06:12 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Few more.
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907578
09/06/15 06:15 PM
09/06/15 06:15 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
And more.
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907579
09/06/15 06:15 PM
09/06/15 06:15 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
here we go again....
Re: Cross Bolted Main Conversion [Re: J_BODY] #1907580
09/06/15 06:16 PM
09/06/15 06:16 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Sorry, I don't understand your meaning.
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907595
09/06/15 06:53 PM
09/06/15 06:53 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i've had this done before and it worked quit well; especially with light weight components.
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907629
09/06/15 07:51 PM
09/06/15 07:51 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Looks real nice. It always seemed like a good idea to me, but I have heard some negativity about this conversion. Don't know why. I think that some have found that it hasn't stopped any of the cap walk that it was intended to stop. Most say that the weak link is actually the block webbing, not the caps. I had Best Machine aluminum caps installed in mine. Maybe an aluminum 4 bolt cap with a girdle? But then, the cylinders wouldn't handle the power that the bottom end could handle. Anyway, like I said to start, looks great. Let us know if you notice any cap walk after the season.
[image][/image]
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907631
09/06/15 07:57 PM
09/06/15 07:57 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
One of my 440 blocks has the ProGram cross-bolt conversion; the other one has been fitted w/ aluminum main caps and will also have a CRE girdle added to it.
My only suggestion for the ProGram deal is they will be a LOT easier to remove if they'd been drilled & tapped for a slide hammer to pull 'em straight up from the block. Otherwise, it's been a major PITA to work 'em back & forth enough to free them up from the block when I've had to remove the crank.
And, yes, this is the sort of post that's liable to bring out all the folks who don't like this approach. Moparts... feel the love. whistling
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907639
09/06/15 08:17 PM
09/06/15 08:17 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm indifferent on the modification.... but I guess deep down I have my suspicions as to what degree it actually helps. Guess for the cost involved I'd go with the aluminum main cap route. What HP level are we pushing that poor old OE block to?
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907640
09/06/15 08:18 PM
09/06/15 08:18 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks good !
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907646
09/06/15 08:27 PM
09/06/15 08:27 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
I have tried using a girdle. Didn't work for me. Now I will see what happens when I increase the cap strength. I haven't tried aluminum caps yet. I have a hard time understanding how they would stop cap walk. I think it may be making it harder to detect. But I do intend to try some in the future.
T & K Performance
Re: Cross Bolted Main Conversion [Re: FastmOp] #1907647
09/06/15 08:28 PM
09/06/15 08:28 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Originally Posted By FastmOp
Looks good !
Thank you!
T & K Performance
Re: Cross Bolted Main Conversion [Re: sgcuda] #1907648
09/06/15 08:28 PM
09/06/15 08:28 PM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Thank you!
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907654
09/06/15 08:59 PM
09/06/15 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like the 4 bolt caps... will it STOP cap walk... no
but it does stabilize the cap better... but the cap is
still bending/bouncing to give you the cap walk... thats
weight and/or detonation... I have 1 SB that has 4 bolt
mains(not cross bolted) and I like that block.. it has
shown to be good over the years.. the outer bolts are 3/8
but the caps are massive.... billet steel
EDIT
looks like you might have to grind the side washers
to clear the pan(just guessing on that.. but looks close)
wave
Re: Cross Bolted Main Conversion [Re: MR_P_BODY] #1907702
09/06/15 09:45 PM
09/06/15 09:45 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
PLEASE do us a favor. Don't just come back a year from now and say "oh ya it works" like many of our members that attend 3 Mopar races a year and run 10's. I would for once love to hear how quick the combo was, weight, and how many passes till it expired. I made it 275 passes with no concrete, no girdle, and only a set of 440sourse billit 2 bolt main caps. When I took the engine apart I found a crack up thru the block. This combo ran 8.60's -8.90 at 2400 pounds. This was with a .055 over 4.125 based 440 block
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: Cross Bolted Main Conversion [Re: pittsburghracer] #1907717
09/06/15 09:54 PM
09/06/15 09:54 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I see from the pics it's a 400 block.
Is it the cold weather casting with thicker mains?
'63 Dodge 330
11.19 @ 121 mph
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907820
09/07/15 12:57 AM
09/07/15 12:57 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
They DON'T.........nothing does
Re: Cross Bolted Main Conversion [Re: pittsburghracer] #1907845
09/07/15 02:02 AM
09/07/15 02:02 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
No problem. This car makes more passes in one weekend than most people get to make in a year. That is when we win wink
T & K Performance
Re: Cross Bolted Main Conversion [Re: GY3] #1907846
09/07/15 02:05 AM
09/07/15 02:05 AM
Texas
ChevyTS Offline OP
ChevyTS  Offline OP
Texas
Average 400. I wouldn't want to use a good one for a bracket engine wink
T & K Performance
Re: Cross Bolted Main Conversion [Re: ChevyTS] #1907901
09/07/15 09:26 AM
09/07/15 09:26 AM
PA.
"Little"John
"Little"John
PA.
. Great to hear but I can't believe guys don't have any idea how many passes they put on their combos. I love the info and learn from it so I log every pass. Instead guys will say I ran this for five or six years and it held up great. But they only put 20 passes a year on their car. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.38@138.67
Page 1 of 4 1 2 3 4
