Re: Thinking of upgrading small block heads Advice ?? [Re: MR_P_BODY] #1904549
09/01/15 11:20 PM
09/01/15 11:20 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By MR_P_BODY
Originally Posted By pittsburghracer
Lighten the car and it's a win,win. I lost 52 pounds so far since late April trying to make up for my 130 pound heavier R3 block
How do you figure 130# more than a stock block... my
car with a 395ci to my 405ci W-9 R-3 block with a dry
sump was 18# heavier... and thats dry sump over a wet
sump.. and that engine had more braided line by far..
but the 395ci was a W-2 head.... but when it rolled over
the scale it ended up 18# heavier
wave
. I know it's way more than 18 pounds heavier but I thought for sure it said 130 pounds in my building big inch small block book. I hope it's not that much but hopefully I make it to Norwalk so I can weigh it again
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Thinking of upgrading small block heads Advice ?? [Re: J_BODY] #1904551
09/01/15 11:21 PM
09/01/15 11:21 PM
PA.
"Little"John
"Little"John
PA.
Originally Posted By J_BODY
stock 340 block come in around 142. R3 block right around 220.
. This I could believe
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Thinking of upgrading small block heads Advice ?? [Re: pittsburghracer] #1904633
09/02/15 01:10 AM
09/02/15 01:10 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
Jay your motor has a 9.200 block, I think I read that a standard deck R3 is close to 235lbs.
Re: Thinking of upgrading small block heads Advice ?? [Re: Kindafast] #1904655
09/02/15 01:47 AM
09/02/15 01:47 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Don't know if it's true but I was told my R1, 9.58" block weighed about what a factory 400 B block weighed. I do know there is a bunch more iron in it than a production block.
Re: Thinking of upgrading small block heads Advice ?? [Re: Kindafast] #1904680
09/02/15 02:46 AM
09/02/15 02:46 AM
K
KOS Offline
KOS  Offline
K
i had my tall deck r3 lightened and it was 90lbs heavier than stock block.i went from a 360 block with a tall fill and iron w2s to a r3 block non siamese indy alum head and car was still 50lbs heavier.so safe to say 75-100lbs diff for sure.
Re: Thinking of upgrading small block heads Advice ?? [Re: Kindafast] #1904749
09/02/15 10:55 AM
09/02/15 10:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
......and getting away from the fatt azz R3 block drivel, I agree with the earlier suggestion that the OP seek out a set of 59 degree W9 heads!!!! Member Spareparts has the set in the Racingjunk ad.
Re: Thinking of upgrading small block heads Advice ?? [Re: Kindafast] #1904909
09/02/15 02:11 PM
09/02/15 02:11 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
That is the direction I plan on going , Hope I can sell my top end to help offset some of the cost..
6.50 @105.26
Re: Thinking of upgrading small block heads Advice ?? [Re: Kindafast] #1904918
09/02/15 02:24 PM
09/02/15 02:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
There was a very good deal on a set of 360-1s in the race parts for sale last month also.
Re: Thinking of upgrading small block heads Advice ?? [Re: justinp61] #1905054
09/02/15 05:06 PM
09/02/15 05:06 PM
Seaford, Va
Seaford, Va
That looks like a killer deal on the heads and intake. I have to put my stuff up for sale soon.
6.50 @105.26
