Page 3 of 3 1 2 3
Re: Bondo over primer? Will it stay? [Re: Saint Crispan] #190392
01/26/09 06:31 PM
01/26/09 06:31 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Thanks for the advice, all. Just for good measure, I decided to take some shots of the holes in question:
Drivers side (shot 1)
Driver's side (shot 2)
Passenger's side (shot 1)
Passenger's side (shot 2)
These I think I can slip a little sheet metal behind.
weld a patch....imo
Re: Bondo over primer? Will it stay? [Re: 340dart4spd ] #190393
01/26/09 06:48 PM
01/26/09 06:48 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
weld a patch....imo
Weld it up and fix it once and for all.
Re: Bondo over primer? Will it stay? [Re: Neil] #190394
01/26/09 08:06 PM
01/26/09 08:06 PM
Truckville, the capital of NY
85_Ram_4speed Offline
With all the critisim here (even though some of it was just for fun) there has to be a memeber of the board that lives near this gentleman to go and weld a quicky patch in for him. I know i would if i lived close.
To the original poster, maybe place an ad on this board in an appropriate section asking for someone to help you weld a patch in. What you have there and the way the proposed fixes would happen, your are probably not going to be happy in the long run with all your time, money and fustration to fix it second rate as opposed to giving someone $40-50 to weld in a couple of patches. Of course this is just my opinion.
Outcast Dodge guy.
Re: Bondo over primer? Will it stay? [Re: Saint Crispan] #190395
01/26/09 08:09 PM
01/26/09 08:09 PM
BFE
vancamp Offline
super street
vancamp  Offline
super street
BFE
with the pics you've shown you need a cutoff wheel and and least take it by a bodyshop or body college and let someone weld in a patch for you.
VanCamp Dent Systems Paintless Dent Repair/ Mopar Restification
Re: Bondo over primer? Will it stay? [Re: 85_Ram_4speed] #190396
01/26/09 08:11 PM
01/26/09 08:11 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
bet this guy has a answer
Re: Bondo over primer? Will it stay? [Re: 340dart4spd ] #190397
01/26/09 09:44 PM
01/26/09 09:44 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
fix it right the first time...
but everyone missed the original post...
bondo over primer...go or no go?
Re: Bondo over primer? Will it stay? [Re: AARCONV] #190398
01/27/09 10:30 AM
01/27/09 10:30 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Never put bondo over primer, why risk it?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Bondo over primer? Will it stay? [Re: MOPARMIKE69] #190399
01/27/09 10:34 AM
01/27/09 10:34 AM
depends on what the car is, is it worth the work????
Re: Bondo over primer? Will it stay? [Re: AARCONV] #190400
01/27/09 10:43 AM
01/27/09 10:43 AM
Jacksonville Florida
elitecustombody Offline
every shop has their prefference and there is absolutely nothing wrong with filler over primer or any catalized material,as long as the surface is prepped for it,it has to be sanded very well, just like with anything,I, personally will never wipe filler onto bare metal and have been doing so for 20 years ,haven't had any reason to re-do any of my work ,either it's a 15k paint job or small fender-bender,no problems at all
Re: Bondo over primer? Will it stay? [Re: Neil] #190401
01/27/09 10:46 AM
01/27/09 10:46 AM
weld a patch....imo
Amen!
unless you like ghetto-rigging,I wouln't attempt to use anything but a new patch and a welder
Re: Bondo over primer? Will it stay? [Re: elitecustombody] #190402
01/27/09 10:51 AM
01/27/09 10:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
weld a patch....imo
Amen!
thems big holes..lol I'd make sure you cut or grind all of that out. Then I'd either weld in a patch or use something like liquid nails to hold it in place. Then you can use a skim coat of filler. I would not start smearing filler over those areas, they need some more work before you start.
Re: Bondo over primer? Will it stay? [Re: Mr.Yuck] #190403
01/27/09 04:08 PM
01/27/09 04:08 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You could buy a mig welder (with gas), read some tutorials on line, ask questions here, practice on some scraps, and then weld a patch in yourself. I took that approach and welded a new spare tire well into the trunk of my car and now the rust is fixed for good. Then when I painted the engine compartment I welded some holes shut and butt welded in a patch by the battery. It takes some time to learn but the average guy can do it.
Page 3 of 3 1 2 3
