What kind of ignition coil are you guys running lately?
#1902588
08/30/15 06:52 PM
08/30/15 06:52 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
The Firecore coil took a dump on my wife's '70 Barracuda today. What's the latest and greatest coil for a street/strip car with a traditional MSD 6AL? I had stopped using a totally fine MSD Blaster 2 when I installed the Firecore, but I recall a lot of people saying Blaster 2 coils should not be mounted horizontal. (One of the reasons I switched to a Firecore in the first place, for the Blaster 2 was mounted horizontal like a typical big block and I do recall a Blaster 2 leaking oil on our NSS Savoy back in the day.) Any recommendations? I thought about maybe the high vibration Blaster 2...it says it can be mounted in any position. High Vibration Blaster 2 Is there anything else out there? I have not even shopped for coils since installing the Firecore.
Re: What kind of ignition coil are you guys running lately?
[Re: Blues_Cuda]
#1902602
08/30/15 07:21 PM
08/30/15 07:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The one you show is what I use... or its the marine one.. both are high vibration type EDIT and its mounted horizontal
[Re: Charger453]
#1902866
08/31/15 12:29 AM
08/31/15 12:29 AM
Blues_Cuda
St. Louis, MO
MSD HVC here. I had a Firecore before that but it crapped out after 3 years on a car I didn't drive much. Same exact situation for me. Looks like I'll be replacing the one on the NSS Savoy as well before it craps out.
[Re: AndyF]
#1902874
08/31/15 12:42 AM
08/31/15 12:42 AM
Blues_Cuda
St. Louis, MO
There are lots of options. I make a simple bracket that hold the coil vertical or I make little brackets that hold the square type coils. Andy- Will the Blaster SS coil bracket fit on a 440 with the standard M1 single plane manifold? The cast-in coil bracket boss is kinda big on those intakes. In comparison, the Victor intake provides a lot more room in that area.
[Re: Blues_Cuda]
#1902978
08/31/15 06:09 AM
08/31/15 06:09 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
On my street car (Coronet Convertible), I have the MSD Chrome canister coil (Blaster 2, $48.95) mounted horizontal, and so far no problems? On the Charger that I race, I have the Crane PS91 "E-Core" coil ($79.18) The MSD Blaster SS is also an E-Core ($52.95), but I have not used one? The MSD "U-Core" coil (HVC 2) is supposed to be the best, but is also the most expensive at around $200+.
[Re: Blues_Cuda]
#1902996
08/31/15 09:04 AM
08/31/15 09:04 AM
Posts: 4,648 aotearoa
rebel
aotearoa
Accel E Core here. small enough to fit on the back of my engine plate & has a wicked spark. i know.
[Re: Blues_Cuda]
#1903014
08/31/15 10:07 AM
08/31/15 10:07 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Any recommendations? I thought about maybe the high vibration Blaster 2...it says it can be mounted in any position. High Vibration Blaster 2 I just replaced a 15 year old Blaster 2 with the one above chasing a miss. Mine is vertical mounted to on the chassis, however.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Blues_Cuda]
#1903025
08/31/15 10:28 AM
08/31/15 10:28 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I used Blaster 2s for a long time. I changed to a blaster SS while chasing an ignition problem. That blaster SS left me on the highway during drag week 2013 so I went back to the Blaster 2. Recently i switched to coil on plug so I run 8 GM LS truck coils.
68 Barracuda Formula S 340
[Re: Blues_Cuda]
#1903055
08/31/15 11:52 AM
08/31/15 11:52 AM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
I use a Pertronix IgnitorIII coil with my IgnitorIII distributor, low deck BB. I have it mounted vertically on my motor plate.
[Re: Blues_Cuda]
#1903058
08/31/15 11:53 AM
08/31/15 11:53 AM
ProSport
Akron, Ohio
Beautiful Cuda by the way, love the color combo.
[Re: Streetwize]
#1903163
08/31/15 02:54 PM
08/31/15 02:54 PM
Posts: 4,715 Wichita
GY3
Wichita
Isnt there an OEM that is supposed to wirk even better with the 6AL than the Blaster? Thought i read that somewhere? My Blaster 2 was junk. A terminal broke while barely tightening it down. I cleaned up and used an old Chrysler coil and it works great with the MSD. The MSD is hidden so most people think I'm still runnin' points.
[Re: Streetwize]
#1903198
08/31/15 03:35 PM
08/31/15 03:35 PM
Posts: 717 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Isnt there an OEM that is supposed to wirk even better with the 6AL than the Blaster? Thought i read that somewhere? FD478 Joe
Without Data, you’re just another guy with an opinion.
