Re: 1974 charger SE 400 4 spd ????
[Re: burdar]
#1905724
09/03/15 03:11 PM
09/03/15 03:11 PM
Posts: 142 lethbridge,alberta,canada
71RACER
Great color combo. At first I thought you had the year wrong. I've never seen JA5 on anything other than a 73. I looked it up on Hamtramck-Historical and sure enough...it was available in 74 on the Charger. It was a one year only color on the A and E bodies.(1973) Thanks for the info. The more I do this car the more interesting it gets.
why? why not!
[Re: Bull1tt]
#1905966
09/03/15 10:59 PM
09/03/15 10:59 PM
Posts: 22,900 Gabba Gabba Hey! NYC
Diego (not Ted)
WP29P4 Charger SE 400-4bbl 2,272 automatic, 104 4spd These are US numbers, so if it's a Canadian car it would not be included in the above. Also, the 360 was available in the SE - 802 US-spec cars were were built, according to Galen's White Book.
[Re: 71RACER]
#1906228
09/04/15 11:53 AM
09/04/15 11:53 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
I thought you said it had a perfect dash pad??? Looks pretty wasted in the photo. Those are almost impossible to find good - they were tough 30 years ago.
[Re: Sunroofcuda]
#1906299
09/04/15 01:59 PM
09/04/15 01:59 PM
71RACER
I thought you said it had a perfect dash pad??? Looks pretty wasted in the photo. Those are almost impossible to find good - they were tough 30 years ago. Your right the one in the car is cracked. I also got another dash pad with the car (I didnt mention, my bad) its the good one. Good eye sunroofcuda
why? why not!
[Re: 71RACER]
#1906306
09/04/15 02:07 PM
09/04/15 02:07 PM
71RACER
well I have the car in primer now. I sanded it down to bare metal and then primed it. No body work or filler work yet. car is very straight. I also cleaned and under coated the bottom with black rubberized undercoat. Found the factory tip hangers still in place? The diff is 8 3/4 with 323 suregrip.
why? why not!
[Re: Diego (not Ted)]
#1906374
09/04/15 03:52 PM
09/04/15 03:52 PM
Posts: 87 Wisconsin
EccentricMagpies
Wisconsin
WP29P4 Charger SE 400-4bbl 2,272 automatic, 104 4spd These are US numbers, so if it's a Canadian car it would not be included in the above. Also, the 360 was available in the SE - 802 US-spec cars were were built, according to Galen's White Book. Good point! I think I read somewhere to assume ~30% for Canada made. (fendertag should show this) Yes, 360's were an option for SEs. Just not the "L" coded for high performance.
Rallye 4spd WH23L4xxxxxx Rallye tx9 x 3 + V6X '69 Dart Swinger-340 4spd
