Re: Do they always go quicker right before they break? Long [Re: roadhazard] #1904090
09/01/15 02:35 PM
09/01/15 02:35 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Sounds like quaker city took a toll on both of us. We broke a lifter last weekend. Hoping to get it back together for Norwalk. Good luck!
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Do they always go quicker right before they break? Long [Re: 69dart] #1904598
09/02/15 12:17 AM
09/02/15 12:17 AM
BigFish69 Offline
BigFish69  Offline
Doug
So what's the difference between ATI and the ultimate converter you noticed.
Tom
Re: Do they always go quicker right before they break? Long [Re: dvw] #1904604
09/02/15 12:26 AM
09/02/15 12:26 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Ultimate is taller, has 2 rows or indents (fin attachment?) in the turbine cover, lightened ring gear attachment. The ATI has 3 rows of indents in the turbine cover, a thicker anti balloon cover, thicker seam between the turbine and pump, the stator is tapered. I will gather data from both on the tach/driveshaft replay. If one pass is any indication the ATI went 1 mph faster in 660, 2 mph in 1320. Lenny says to get the info and he can tailor the ultimate to match if necessary. His converter was pretty good fit considering we only guessed at the car weight and no dyno numbers. He built it before the car was ever run.
Doug
Re: Do they always go quicker right before they break? Long [Re: dvw] #1904673
09/02/15 02:38 AM
09/02/15 02:38 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Told you it was a converter bolt😀 Very glad to hear you ar feeling better that is most important.
You must be well before Monster Mopar I am getting acustom to your cooking.
This guy fixed Casey and I a very nice taco dinner after all the thrashing, hard to find a good cook that can thrash😀
Get you and car well! See you at MM !
Poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
