Re: What kind of ignition coil are you guys running lately?
[Re: Blues_Cuda]
#1903247
08/31/15 04:29 PM
08/31/15 04:29 PM
Posts: 31,081 Oregon
AndyF
There are lots of options. I make a simple bracket that hold the coil vertical or I make little brackets that hold the square type coils. Andy- Will the Blaster SS coil bracket fit on a 440 with the standard M1 single plane manifold? The cast-in coil bracket boss is kinda big on those intakes. In comparison, the Victor intake provides a lot more room in that area. Should fit with the M1 single plane. I tested that bracket with a bunch of single plane intakes and it worked with all of them. I think it even works with the Performer RPM but it doesn't work with other dual planes.
[Re: Blues_Cuda]
#1903256
08/31/15 04:44 PM
08/31/15 04:44 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I've had a Blaster 2 mounted horizontally for years...like ten years... still works..
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Cudajon]
#1903406
08/31/15 08:02 PM
08/31/15 08:02 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am also using a MSD Blaster 2 coil..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Blues_Cuda]
#1903547
08/31/15 11:24 PM
08/31/15 11:24 PM
Posts: 5,447 So Cal
Sinitro
So Cal
The traditional MSD Blaster round tower coil internally uses an oil-bath to help kool its windings .. When mounted horizontally the oil lays differently and is less efficient for cooling. How well/long it runs OK really depends upon how hot does it get.. This is determined by the value of the ballast resisitor, the ECU used and physical location..... Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
