Re: Modern Bullitt build
[Re: Keepat]
#1901801
08/29/15 12:42 PM
08/29/15 12:42 PM
Posts: 19,934 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
Of all of the cool cars I've seen on Moparts since I started coming here in 1999, this is my favorite, and by a wide margin. Thank you for taking the time to document this incredible build. Your talent is off the charts.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#1901888
08/29/15 04:00 PM
08/29/15 04:00 PM
Posts: 676 Maryland
Keepat
Maryland
Of all of the cool cars I've seen on Moparts since I started coming here in 1999, this is my favorite, and by a wide margin. Thank you for taking the time to document this incredible build. Your talent is off the charts. Thank you! This car has been fun to build and I have enjoyed documenting and Posting the progress. Thank you for your comments. Pat
[Re: SattyNoCar]
#1907545
09/06/15 05:40 PM
09/06/15 05:40 PM
Posts: 676 Maryland
Keepat
Maryland
I'm envious of your skills sir! One question about the AC line routing, are you going to make some kind of cover/shield to protect them from road debris? My luck, a rock, or even worse, a blow out would take out all that hard work..... The S/S lines are over kill for this job as they are rated for over 2500 PSI working pressure. I think they could take the shrapnel as good as the fender has for over 45 years. The AC lines will get a 3/16 neoprene insulator that will also help protect them as the undercoating protected the inside of the fender. Thank You! Pat
[Re: Keepat]
#1911551
09/13/15 11:06 AM
09/13/15 11:06 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
If anyone has a proven method for access, cleaning, and coating the inside of the cowl please let me know.
In threads over on the a-body forum I have seen people remove windshield and drill out all the outer cowl spot welds and remove top outer shell of cowl. Then you will have full access. Other than that you cant get in there.
[Re: Keepat]
#1919294
09/25/15 06:26 AM
09/25/15 06:26 AM
Posts: 1,896 New England
Q5_Ed
New England
Very awsome project! Here is my cowl removed to repair old holes from racing in the top center of inner cowl. I hated to do it but only way to get full access. On a plus now can clen up vent holes correctly.
WANTED : ...A New Sponsor or Winning Lottery Ticket
69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
[Re: SomeCarGuy]
#1924769
10/03/15 09:41 AM
10/03/15 09:41 AM
Posts: 676 Maryland
Keepat
Maryland
Did you beef the lower rad support ala the old XV brace? It is a US Car Tool lower rad support that I special ordered without the holes in it so it looks original. Fit and worked great! Thank you! Pat
