Re: 1971 Challenger Build date
[Re: Challenger 1]
#1901497
08/28/15 11:26 PM
08/28/15 11:26 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
My 71 hamtrack car was built Dec 23 1971, probably the last day before Xmas break. They couldn't wait to get out of there. LOL If that's the date it's probably a 72 Or really, really late
[Re: Morty426]
#1901552
08/29/15 12:14 AM
08/29/15 12:14 AM
Challenger 1
Cincinnati, Ohio
My 71 hamtrack car was built Dec 23 1971, probably the last day before Xmas break. They couldn't wait to get out of there. LOL If that's the date it's probably a 72 Or really, really late Oh your right, sorry it was 70 not 71, DUH.
[Re: Morty426]
#1901652
08/29/15 02:38 AM
08/29/15 02:38 AM
Posts: 117 SE-WI
skdmark
SE-WI
My 71 JS23V1B344xxx is an SPD of 3/31
My 71 JH23H1B has a SPD of 5/20 but I cant get you the first three numbers until Thursday I have a JS23N1B398### with a 520 SPD with the door sticker of may 71.
[Re: JAK]
#1901659
08/29/15 02:59 AM
08/29/15 02:59 AM
Posts: 118 Westchester County NY
Big Mopar Jay
my sequence number is 435242 built in hamtramck with a build date on the fender tag of june 16th, 71. Engine casting date of Jan 71 My Challenger was built the same day at Hamtramck. June,16th 1971. Vin sequence is 435459. I don't know the engine casting date. But I know the engine is original.
Mopar Nation
70 Challenger SE 340
71 Challenger 2nd registered owner
[Re: DEERLODGE]
#1901661
08/29/15 03:06 AM
08/29/15 03:06 AM
Posts: 27,465 So Cal
autoxcuda
So Cal
I think I pretty close with April 28 as a build date. Directly two weeks after the Engine assembly date. I think the actual date could have fallen between 4/26/71 and 4/30/71 Thoughts? Are those the dates you want to use for the fender tag?
[Re: Big Mopar Jay]
#1902414
08/30/15 01:27 PM
08/30/15 01:27 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
my sequence number is 435242 built in hamtramck with a build date on the fender tag of june 16th, 71. Engine casting date of Jan 71 My Challenger was built the same day at Hamtramck. June,16th 1971. Vin sequence is 435459. I don't know the engine casting date. But I know the engine is original. LOL that must have been a busy production day. My 71 Challenger R/T's SPD on the fender tag is also 6/16 with VIN sequence of 435197.
[Re: KillerBee]
#1902447
08/30/15 02:43 PM
08/30/15 02:43 PM
Posts: 1,672 Virginia
HemiStan
Virginia
my sequence number is 435242 built in hamtramck with a build date on the fender tag of june 16th, 71. Engine casting date of Jan 71 My Challenger was built the same day at Hamtramck. June,16th 1971. Vin sequence is 435459. I don't know the engine casting date. But I know the engine is original. LOL that must have been a busy production day. My 71 Challenger R/T's SPD on the fender tag is also 6/16 with VIN sequence of 435197. My friend's '71 Challenger R/T also has a SPD of 6/16 with sequence number 435191. Very close!
[Re: HemiStan]
#1902456
08/30/15 03:05 PM
08/30/15 03:05 PM
KillerBee
N.E. Ohio
my sequence number is 435242 built in hamtramck with a build date on the fender tag of june 16th, 71. Engine casting date of Jan 71 My Challenger was built the same day at Hamtramck. June,16th 1971. Vin sequence is 435459. I don't know the engine casting date. But I know the engine is original. LOL that must have been a busy production day. My 71 Challenger R/T's SPD on the fender tag is also 6/16 with VIN sequence of 435197. My friend's '71 Challenger R/T also has a SPD of 6/16 with sequence number 435191. Very close! Wow! that is close. What color and options does your buddy's R/T have? Mine is a low option FC7 383 4 speed car with cloth insert interior.
[Re: hemicar1971]
#1902732
08/30/15 10:24 PM
08/30/15 10:24 PM
KillerBee
N.E. Ohio
Great info. My 1971 Challenger with 6/16 SPD does have slotted bumpers, I'm not sure what to look for with the difference in the trunk pans. My wife's 1971 R/T Challenger has a 1/27 SPD, I assume her car's trunk pan would be different? Anything else between the cars to compare? I was surprised at the late date codes on the carpeted lower panels on my Challenger. I would have guessed they were leftovers from the 1970 SE optioned Challengers.
