Re: Let's do speedo and rear gear math!
[Re: John_Kunkel]
#1902331
08/30/15 10:50 AM
08/30/15 10:50 AM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
i trust the math, not the gps. Problem is, the math only guarantees an accurate odometer not an accurate speedometer. Many speedo errors are in the head itself. GPS factors in new tire size without having to measure diameter and calculate to the original 7.00 X 14 tire, which the 'math' does not do.
[Re: Bull1tt]
#1902381
08/30/15 12:36 PM
08/30/15 12:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
i trust the math, not the gps. Problem is, the math only guarantees an accurate odometer not an accurate speedometer. Many speedo errors are in the head itself. GPS factors in new tire size without having to measure diameter and calculate to the original 7.00 X 14 tire, which the 'math' does not do. Not exactly, what the math does not take into account, because it is an unknown, is the EFFECTIVE diameter of the old and new tire. Effective diameter is the actual diameter with the load of the vehicle on it, not the listed diameter specification. And that is why the math is wrong. Problem solving is a [censored] when you don't know how the formula works.
[Re: lewtot184]
#1902518
08/30/15 04:54 PM
08/30/15 04:54 PM
Posts: 26,040 Rio Linda, CA
John_Kunkel
Rio Linda, CA
FWIW, finally got around to checking my original factory reduction unit and it's .80 reduction.
[Re: John_Kunkel]
#1903631
09/01/15 01:21 AM
09/01/15 01:21 AM
RapidRobert
I dont have GPS but I had assumed it was high tech dead on accurate, ain't so ???. What John said I would get the odo correct with the correct pinion then after that if the speedo ain't correct then it would need to come out & go to a speedometer specialty repair shop. I use 5 mile markers in a row on the interstate to check the odo and those portable lit up digital roadside MPH signs the city sets out on occaision to check the speedo
[Re: John_Kunkel]
#1904236
09/01/15 05:18 PM
09/01/15 05:18 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
When Lacking a GPS I would drive the car on the Interstate from mile marker to mile marker. Needs to be over 25 miles though, the more miles the better the accuracy. I divide the miles traveled on the odometer and the actual miles travel by the mile marker signs to get a percentage. If it is 20 percent too low I get a speedometer gear with 20 percent less teeth to speed it up. That being said, John is right about speedometer heads being off. My method works for calibrating the Odometer with the hopes the speedometer will be right afterwards.
