Re: Installing 440 valley pan gasket ???
[Re: chicagotim2003]
#1897787
08/23/15 04:37 PM
08/23/15 04:37 PM
Posts: 15,495 Florida
scratchnfotraction
I used the fel-pro HP pan with heat block off. I installed the 4 gaskets = 1 each side of pan.
I installed those gaskets dry with the supplied black rtv in the 4 corners and a thin coat on the block/pan on end rails. I also used some copper rtv on the bolt threds to stop oil wicking up the threds and pooling on the intake.
I got the pan with end rails installed and snug pulling the pan down then slipped the gaskets into place. dropped intake on with the other gaskets. installed intake bolts and torqued to specs then torqued end rails down.
I did let mine sit 24 hrs for the rtv to cure before running engine.
I played around with intakes/leaks with "just" the pan with no gaskets.
gaskets fixed the leak issues I had. I have even swapped intake out 2x already with same gaskets/pan.
SUPERFORMANCE for the M/T valve covers and all other engine gaskets.
[Re: scratchnfotraction]
#1897944
08/23/15 09:13 PM
08/23/15 09:13 PM
RapidRobert
I'd use the side gaskets with the valley pan and Fellpro has thick ones and superformance (on here) has .015" thin ones. First I'd mockup the valley pan/gaskets/intake dry & see what your dimentions require as the height of the "V" will vary considerably due to block height block milling head milling head gasket thickness intake milling. Barring measureing the horizontle "height" of the head ports compared to the horizontle "height" of the intake ports & using that as a baseline I would simply pick the right gaskets (intake needs milled in some cases) so the bolt holes are dead centered. I would block off the heat risers and use "the right stuff" on the front rear "bars"
#1898656
08/24/15 09:07 PM
08/24/15 09:07 PM
Posts: 21,143 Niles , Ohio
therocks
Niles , Ohio
Since the 60s Ive installed all mine with just tins.Never had a problem with either iron or aluminum intakes and or heads.I run now alumionum heads and intake.Only place I use RTV is in the 4 corners and a slight amount where the hold downs bolt.Rocky
Chrysler Firepower
#1898732
08/24/15 10:51 PM
08/24/15 10:51 PM
Posts: 3,382 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
The last 2 engines I've put together, I couldn't have squeezed 2 of them in there, so I opted to put it on the head side only, and just used some Hylomar (the newer version made by Permatex, it's name escapes me now) on each mating surface.
For the RTV, I put a line along each block end, and a little extra in the corners.
[Re: therocks]
#1898956
08/25/15 10:56 AM
08/25/15 10:56 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Since the 60s Ive installed all mine with just tins.Never had a problem with either iron or aluminum intakes and or heads.I run now alumionum heads and intake.Only place I use RTV is in the 4 corners and a slight amount where the hold downs bolt.Rocky Only time I used side gaskets was on an aluminum intake and sometimes not even there.They were never installed on original iron head motors and when done right never leaked.I've use valley pan gaskets over in an emergency and if you seal them right they will not leak.
#1899018
08/25/15 12:20 PM
08/25/15 12:20 PM
Posts: 28,137 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Neither of my 440s will take the gaskets. They haven't been decked or had the heads machined.
[Re: feets]
#1899049
08/25/15 12:58 PM
08/25/15 12:58 PM
dogdays
Hylomar is its own company. Permatex used to market Hylomar Blue in this country. Permatex might attempt to make its own version, but it'll never be as good as the original. They have a variety of products. http://hylomar.com/Just don't get it on your hands unless you like blue hands! After fighting end seals on intake manifolds for nearly 40 years I am happy to say that they go into the junk box immediately and are ably replaced by silicone if I'm feeling cheap and The Right Stuff if I have a few extra bucks. R.
[Re: Cab_Burge]
#1899105
08/25/15 02:19 PM
08/25/15 02:19 PM
Posts: 4,836 Moved to N.E. Tennessee
GomangoCuda
The oil poolings is coming out of the valley pan, one side or the other. Let us know what you find and do. Or the valley pan is cracked.
[Re: GomangoCuda]
#1899295
08/25/15 07:04 PM
08/25/15 07:04 PM
Posts: 44,190 Bend,OR USA
Cab_Burge
The oil poolings is coming out of the valley pan, one side or the other. Let us know what you find and do. Or the valley pan is cracked. Could be that too I've seen that on a 383 motor with the heat insulation pack under it I have had a problem motor,440, that is wicking the oil up one of the intake manifold bolts and leaking onto the top of the intake, dangest thing I have seen in a while Never say Never
#1899444
08/25/15 10:27 PM
08/25/15 10:27 PM
RapidRobert
I would suggest a thin film of cement around the (4) ports on each side (on both sides) of the tin valley pan
#1899524
08/26/15 12:14 AM
08/26/15 12:14 AM
Cab_Burge
The blue RTV is probally the main reason it is leaking oil around the stock valley pan That stuff is worthless on motors in my opinion, I can't tell you how many guys that I know that tried to use that stuff on intakes when it first came out, they never sealed up oil tight As far as the "Right Stuff" you might want to reconsider using it,I've never used it due to its reputation on being very, very hard to take apart and remove once it has set Maybe some other people on here who have used it will chime in on there experiences and likes and dislike of it I have used Hylomar with good results on intake gaskets, heads and intake sufaces IHTHs
