Re: pump gas 340 stock stroke 11.50 combos [Re: Bad340fish] #1904225
09/01/15 04:00 PM
09/01/15 04:00 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Originally Posted By Bad340fish
Streetable is all in opinion. My 360 is 11:1 KB107s, Shady Dell stage II Eddie heads, 258@.050 solid roller, 4500 converter, 3.91 gear, 830 Holley,full exhaust system, 3525lbs. It has been a best of 11.18@120.5 in good air and is very streetable in MY opinion. It will get 13-14mpg on the highway and has completed 3 drag weeks. I drive it to work, to run errands, to get groceries, it is streetable. It has a thumpy 1000rpm idle and it gets up on the converter to get moving but nothing that stops it from being street driven anywhere. Going down 20 cubes might move up the RPM range some but I don't see it having much of a negative effect on street driving.
Curious, what is the RPM at freeway cruise? Do I recall you're on 275/60/15's?? Thanks!
Re: pump gas 340 stock stroke 11.50 combos [Re: Stroker Scamp] #1904378
09/01/15 07:23 PM
09/01/15 07:23 PM
K
KOS Offline
KOS  Offline
K
.030 trw replacement pistons,stock rods and crank.
555 solid flat tappet 258@50
iron W2s mild port flow 290cfm with indy intake
1 7/8header with 3"exh to axle
727 4800stall
4.88gears in 3250lb car 11.4s @118mph
Re: pump gas 340 stock stroke 11.50 combos [Re: KOS] #1904498
09/01/15 09:32 PM
09/01/15 09:32 PM
Rescue CA.
joes68340s Offline
joes68340s  Offline
Rescue CA.
Cudadoug are you saying that you change gearing to 3.91 and drag radial and went from 11.45 to 11.77 at 114. Thanks
Re: pump gas 340 stock stroke 11.50 combos [Re: joes68340s] #1904688
09/02/15 02:30 AM
09/02/15 02:30 AM
cudadoug Offline
cudadoug  Offline
3.91s were in place when it went 11.77. Changed the muffs to something quieter and changed to the 315/60 drag radials. The extra 600 rpm difference at the stripe appears to have produced the 11.45 vs.the previous 11.77. More speed too: 117 over the 114.
Re: pump gas 340 stock stroke 11.50 combos [Re: cudadoug] #2637053
03/25/19 04:33 PM
03/25/19 04:33 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
coffee
Re: pump gas 340 stock stroke 11.50 combos [Re: skep419] #2637058
03/25/19 04:54 PM
03/25/19 04:54 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
whistling You know...This is a 4 year old thread you just bump I wouldn't hold my breath with that cuppa joe...
