Re: rear end identification
[Re: paddel]
#1899022
08/25/15 12:23 PM
08/25/15 12:23 PM
Posts: 13,794 md
mopars4ever
md
My bet 9 1/4, could be a 8 1/4 also but definitely not a 7 1/4 if it is OE. Is it a big block? Count the bolts on the axle cover.
Time just gets away from us I`m here until I`m not
[Re: paddel]
#1899042
08/25/15 12:47 PM
08/25/15 12:47 PM
Posts: 13,794 md
mopars4ever
md
Some of those description could also fit the dana axle. But I don't think so. Do you? look at the location of the bolts in the picture provided and compare Is that a good axle I can work with? what are you going to be doing with it?
[Re: paddel]
#1899047
08/25/15 12:55 PM
08/25/15 12:55 PM
Posts: 107 germany
paddel
germany
I wanted to change the gears to 3.55, rebuild the rest of the suspension (rear sway bar and such) and make the engine more powerful (new pistons, moderate heads and cam). nothing hardcore. The car will never go near 500 hp.
EDIT: No racing or dragging. Just fur the fun of it.
[Re: paddel]
#1899080
08/25/15 01:50 PM
08/25/15 01:50 PM
dogdays
A 9 1/4 should be up to the task. 3.55s were a standard ratio in Ramchargers so stock-type gears should be available new for cheap. An Eaton Detroit Truetrac is available for this rear end and would help put power to the pavement. www.doctordiff.com would be who I'd contact for a complete kit, everything you could possibly need. You'll have to email or talk to him because the 9 1/4 things are not in his online catalog but he's a board member and has the best reputation. R.
[Re: paddel]
#1899104
08/25/15 02:18 PM
08/25/15 02:18 PM
Posts: 13,794 md
mopars4ever
md
he is saying 10 bolts so I think that rules out the 9 1/4
[Re: paddel]
#1899180
08/25/15 03:40 PM
08/25/15 03:40 PM
Posts: 107 germany
paddel
germany
I made a picture: http://abload.de/img/dscf2062jxshx.jpgI hope it helps. The cover is almost round and 30 cm (about 12 inch) in size (like a vinyl LP record). There is a big bump on the left (the flash took that away). The bump takes about 3/4 of the whole cover area. I don't know if it's an aftermarket cover without oil plug or if it's original.
[Re: paddel]
#1899210
08/25/15 04:37 PM
08/25/15 04:37 PM
Posts: 13,794 md
mopars4ever
md
8 1/4 should be ok with what you are doing but obviously a 9 1/4 would have been better. I have used a 8 1/4 before in some performance applications without any issues.
[Re: paddel]
#1899212
08/25/15 04:40 PM
08/25/15 04:40 PM
Posts: 13,794 md
mopars4ever
md
I don't know if it's an aftermarket cover without oil plug or if it's original. Looks original to me. Should be a fill plug in the housing. Otherwise how would you fill it?
[Re: paddel]
#1899227
08/25/15 04:56 PM
08/25/15 04:56 PM
Posts: 13,794 md
mopars4ever
md
I think the later years 8 1/4 had the fill plug in the cover. The earlier ones were in the housing IIRC. Is it a 8 1/4? You kinda ran out of options( 10 bolt, round cover) so from the picture I would say yes. Swap it out? that`s up to you. I would personally be fine with it but you never said what size engine.
[Re: paddel]
#1899290
08/25/15 06:58 PM
08/25/15 06:58 PM
Posts: 44,171 Bend,OR USA
Cab_Burge
All the 9 1/4 rear ends have taperd, stepped axle tubes, all the rest of the rear ends in Mopars don't There straight from the center section to the brake backing plates IHTHs,
