Re: Engine oil ?? for the engine experts. [Re: 440Jim] #1900043
08/26/15 10:59 PM
08/26/15 10:59 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Originally Posted By 440Jim
Lots of good oils out there.
But from what you posted, I would run Brad Penn semi-syn with either 10W-30 or 20W-50 viscosity depending on how hot your oil gets. If the HOT oil idle (1000 rpm) is below 25 psi, then use 20W-50.
I have been using Brad Penn for many years.
10W-30 in my drag race engine,
How often do you change your Brad Penn oil?
Re: Engine oil ?? for the engine experts. [Re: 70RT Charger] #1900086
08/26/15 11:57 PM
08/26/15 11:57 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Originally Posted By 70RT Charger
Back in the day Rotella is all I ever ran in my 440 and that's what I run in my diesels. I'll never use T6 5/40 synthetic.I was out of town and needed my oil changed bad and saw that they had a sell on the T6 so I bought it and changed my oil. By 4,000 miles it had already went through a little over 3 quarts and this truck only uses 1 quart every 5,000 miles. I changed quickly, drained it again and changed once more. I don't know where it went and don't care but when I freshen up my motor I think I will run 15/40 again.
I wouldn't run 5/40 in a diesel either. In a newer gas engine like mine it seems to like it.
If I still had a flat tappet engine I would be using Mobil 1 15W50 with the red cap, that stuff is awesome.
Mopar to the bone!!!
Re: Engine oil ?? for the engine experts. [Re: G-Money1320] #1900228
08/27/15 07:47 AM
08/27/15 07:47 AM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
20/50 oil is old school thinking.... With all the advances in materials and oil the only reason I'd run anything that heavy is if the motor was wore out and needed it to survive.... And that only on a driver not something I was racing. Thinner oils flow better and have less drag....
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Engine oil ?? for the engine experts. [Re: QTR MILR] #1900230
08/27/15 07:53 AM
08/27/15 07:53 AM
Mo.
racerx Offline
racerx  Offline
Mo.
That's our little secret whistling Lol I've been running 10/40 in my car sense 06 with no problem up
Re: Engine oil ?? for the engine experts. [Re: rebel] #1900712
08/27/15 10:39 PM
08/27/15 10:39 PM
Az
Crizila Offline
Crizila  Offline
Az
Originally Posted By rebel
i just read a post about oils on another forum. i found this interesting. i run Royal Purple 10w40. after reading this i'm glad i do.
http://www.animegame.com/cars/Oil%20Tests.pdf
iagree I run 10-40 race royal purple
Fastest 300
Re: Engine oil ?? for the engine experts. [Re: Crizila] #1900716
08/27/15 10:47 PM
08/27/15 10:47 PM
Arizona
Chris'sBarracuda Offline
Arizona
If you have the time.. This article answers so much.. thumbs
https://540ratblog.wordpress.com/
Chris.. wave
Re: Engine oil ?? for the engine experts. [Re: G-Money1320] #1902404
08/30/15 01:15 PM
08/30/15 01:15 PM
Scat City, USA
SleeperBee Offline
SleeperBee  Offline
Scat City, USA
Sent you a PM. Thanks.
