Page 2 of 4 1 2 3 4
Re: whats the coldest temp you'd start your car at? [Re: Challenger 1] #189830
01/11/09 10:56 AM
01/11/09 10:56 AM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
i wouldn't start my chally below maybe 50-55 but my daily drivers are like me they are good to about 0.
dennis
Re: whats the coldest temp you'd start your car at? [Re: PLMCRZY] #189831
01/11/09 11:15 AM
01/11/09 11:15 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Many years ago I used to fire up my Hemi Roadrunner to jump start Dad's Maverick. Probably 25 degrees a couple of those mornings.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189832
01/11/09 12:33 PM
01/11/09 12:33 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
I think theres no doubt that temperature will affect longetivity. The JD 3055 down here in Louisiana has 13,000 hours on the original engine and has been abused (oil chnages every 500 hrs or so, with no air filters changes/maintenance) and still doing well.
Up in Maine/Vermont, you see alot of JDs the same size with the same use with only 4000-7000 hours. We alwasy have to change oil in our 2550 and 6410 from 15w-40 to 5-30 in the winter if we wanted to have reliable starting and then the issue of fuel gelling clogging the filters......
If I had a car I cared about, like if it was my Dads or grandads original 340, 440, hemi etc car, I would not start that below 40 or so. With the carbs and vaporization and oil viscosity, unless its my daily driver I would just hold off. 20w-50 is thick stuff, would not even consider trying to start our diesels with that in it without changing it out. We havn't used it since the late 80s. My
Re: whats the coldest temp you'd start your car at? [Re: jerseybud] #189833
01/11/09 03:00 PM
01/11/09 03:00 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Yep. My '72 318 has lived its whole life in Calif and Western Washington. A few nights in the twenties is all the cold we get. 230,000 miles and it doesn't smoke at all. My '65 327 was in Anchorage, Alaska for only four winters. Lots of short trips. 125,000 miles and its a smoker...
Re: whats the coldest temp you'd start your car at? [Re: I go fast] #189834
01/11/09 03:04 PM
01/11/09 03:04 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
well you know, just because you can start it up and drive it, doesnt mean that its a good thing. I think youd get a lot more wear and tear on a motor started at really cold temps.
You'd rather walk?
no, i have other cars i start anytime any temp. im just talking about a fresh build (less than or around 1000 miles on) 416. I wanted to go for a cruise but I pulled the dipstick when it was about 38 degrees outside and the oil seemed think. so I didnt go for the cruise (I had the same urge and temp and result today). its not like i had to walk. if i did, i would most probably been driving.... transportation is important
Re: whats the coldest temp you'd start your car at? [Re: RapidRobert] #189835
01/11/09 03:04 PM
01/11/09 03:04 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
I lived in Anchorage for several years. It doesn't really get very cold there very often.
You say it doesn't get cold in Alaska?
Alaska's a big place. Juneau ain't Anchorage ain't Fairbanks climate-wise. Anchorage is (relatively) mild. Seen days in the winter there when it was colder down in Texas. I used to wash my car during the winter there when we'd have a warm day in the 30s.
Re: whats the coldest temp you'd start your car at? [Re: DZJim] #189836
01/11/09 03:09 PM
01/11/09 03:09 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i just saw some places in alaska are hitting -20 degrees this week.
BURRRRRRRRRRRRRRRRRR
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189837
01/11/09 03:12 PM
01/11/09 03:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Some of us don't have any choice.
Been there and colder for the last 3+ weeks. Today it is up to 14 above and it feels like we are in the banana belt. Supposed to be sub zero again for most of the next week. Blizzard watch out for tonight and tomorrow with up to 6" more snow ontop of the 30 or so already on the ground and 35 mph winds will make it right interesting.
Re: whats the coldest temp you'd start your car at? [Re: MoparforLife] #189838
01/11/09 03:15 PM
01/11/09 03:15 PM
MoreParts Offline
MoreParts  Offline
Having a convertible, I wouldn't start it at anything below 70 degrees. But being in California that's rarely a problem.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189839
01/11/09 05:34 PM
01/11/09 05:34 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
Why do you want to start it?
Are you going out for a drive?
Re: whats the coldest temp you'd start your car at? [Re: boydsdodge] #189840
01/11/09 09:09 PM
01/11/09 09:09 PM
the boonies
aarcuda Offline OP
aarcuda  Offline OP
the boonies
i wanted to, yes. Im getting a little antsy and want to take er out for a romp.... quite satisfying. but i didnt. chickened out.
next week it will be in the 30's. so maybe next weekend...
Re: whats the coldest temp you'd start your car at? [Re: boydsdodge] #189841
01/11/09 09:16 PM
01/11/09 09:16 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Synthetic will solve the problem. I run 10w30 Mobil1 in my 4.7 Ram and it spins the same at -20 as it does at +70. I would not be keen on firing an engine like yours up in this weather (0ish) with 20w50 in it unless it was synthetic. Just asking to twist off the oil pump drive IMHO.
Kevin
Re: whats the coldest temp you'd start your car at? [Re: Twostick] #189842
01/11/09 10:15 PM
01/11/09 10:15 PM
USA
CrAlt Offline
CrAlt  Offline
USA
I had 20w50 in my D150 when i was up camping in VT a few weeks ago. There was a cold snap and it was 5 or 10 below over the night and the high was 12 that day. I had to move the truck in the morning so i had no choice but to start it.
It started right up but oil light took along time to shut off and the lifers sang for a wile. I just let it idle until it warmed up and the lifters shut up.
I wouldnt try and start a new motor like that unless i really had to.
I was asked to contribute money to help solve the civil unrest in Egypt, but I suspect it's some sort of pyramid scheme.
Re: whats the coldest temp you'd start your car at? [Re: CrAlt] #189843
01/11/09 10:21 PM
01/11/09 10:21 PM
Upper Midwest
Upper Midwest
Do you realize how thick 20/50 gets when cold. The reason the lifters rattled is that the pump couldn't move oil. At that temp it will not pour out of a bottle.
Re: whats the coldest temp you'd start your car at? [Re: aarcuda] #189844
01/11/09 10:27 PM
01/11/09 10:27 PM
boydsdodge Offline
boydsdodge  Offline
Where are you?
I have at least 5 cm of snow every few days to deal with and minus 5c
Re: whats the coldest temp you'd start your car at? [Re: boydsdodge] #189845
01/11/09 10:36 PM
01/11/09 10:36 PM
No metrics please
Re: whats the coldest temp you'd start your car at? [Re: RapidRobert] #189846
01/11/09 11:20 PM
01/11/09 11:20 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
wind chill only affects warm blooded people/animals. It can drop the temp of an object faster than it would drop if there was no wind but it doesn't drop it below the ambient temp.
Right on RR
Also guys keep in mind the clearances between things
are a lot different at cold temps vs hot temps. I'd freak out more trying to run a hot engine with no oil pressure at start up vs a cold one.
Re: whats the coldest temp you'd start your car at? [Re: MoparforLife] #189847
01/12/09 12:13 AM
01/12/09 12:13 AM
USA
CrAlt Offline
CrAlt  Offline
USA
Ya i know. I forgot it was in there because i parked the truck back when gas was $4+/gal. This trip was the 1st time i used it since the summer. Im sticking to 10w30 now year round in everything.
The 20w50 was just a band aid to the leaky valve seals anyways.
Re: whats the coldest temp you'd start your car at? [Re: CrAlt] #189848
01/12/09 08:15 PM
01/12/09 08:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I had to fire up the Savoy and give a potential engine buyer a ride around the block in 36* weather a few weeks ago.It has 20-50 in it and pegged the 80 psi gauge
Gus
64 Plymouth Savoy
Dana 60
Re: whats the coldest temp you'd start your car at? [Re: fourgearsavoy] #189849
01/12/09 08:40 PM
01/12/09 08:40 PM
Renton Washington
Triple Threat Offline
Renton Washington
Meh, your all a bunch of sissies. Like i said, 20w50, started, lifters were pumped up fine (the oil probably doesn't drain out of them when its that cold). Drove it around for a little bit mind you with some snow and ice on the ground drag radials aren't the best for traction. Got the job done, Got some thumbs up and parked it.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Page 2 of 4 1 2 3 4
