Re: Ok Let's talk about A-Body Master Cylinders
[Re: ScottSmith_Harms]
#1896158
08/20/15 08:35 PM
08/20/15 08:35 PM
Posts: 43,626 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Here's a 71 with manual disc brakes....Again, a survivor, but I can't say if the MC is the original or not. Looks like the same MC the orange 71 Demon has with power discs. Notice the bail wire is reversed. I have found that all 71-up drum brake master cylinders are like the first picture Scott posted, and all Cardone rebuilt master cylinders for ALL forms of brake systems on A-Body's revert to this type master cylinder with power, manual, drums, or discs. ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif)
JB Rhinehart, Realist
A-Body's RULE!
[Re: Mastershake340]
#1896340
08/21/15 01:23 AM
08/21/15 01:23 AM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
My information came from documentation I had access to when I worked for the company that made Raybestos and United brake parts. We had researchers who would study the part numbers of all the car makers brake parts, and when a new part number was found, one of these parts was ordered through car dealer's parts department, and the part analyzed and documented by engineering for potential addition to our product line. This process went on for decades, we had documentation going back into the 50's. We kept the samples after they were analyzed. Unfortunately over the years before I began working there in 1990, there had been several housecleanings, and obsolete part numbers, parts we had discontinued from our line, they had tossed the samples. Rare samples like 2229171 and 2229191 were tossed a few years before I was hired. ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) In my spare time/boredom, I studied the Mopar master cylinder documentation for the late 60 through early 70s. I started buying up some parts I found for sale that had casting numbers I saw on documentation of interesting master cylinders that had been scrapped from our samples. As far as the original question, I believe the casting number 3461176 is correct for 71-75 power disc A bodies. As far as my info on 71 on A body manual disc my information is a bit incomplete unfortunately. There is a part number for a manual disc master cylinder used on B and E bodies. Maybe it was used on A bodies too? Here is a picture of it, casting number 2229271
![Name: IMG_5491.JPG
ID: 206379 IMG_5491.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/206379/filename/IMG_5491.JPG) ![Name: IMG_5492.JPG
ID: 206380 IMG_5492.JPG](/ubbthreads/ubbthreads.php/ubb/download/Number/206380/filename/IMG_5492.JPG)
#1896351
08/21/15 01:49 AM
08/21/15 01:49 AM
Mastershake340
Crook County, ILL
Note that sample I posted is painted black. It has a label on it that says "Bendix remanufactured" on it, but the flange and outlet areas look virgin, the part has never been installed on a car, so not sure how it ended up getting labeled remanufactured. For Bendix master cylinders from the 60s and 70s their original finish is something I've never 100% nailed down. '67-'70 Mopar disc brake master cylinders were always painted black. Many NOS Mopar master cylinders from the '70s had sort of a parkerized gray coating. I've seen others where the body was E coated. Bendix master cylinders I've seen from those eras for the other 2/3rds of the big 3 generally had black e coated bodies and plated caps. I have a couple NOS Mopar late 60s with the bolt on cap drum brake master cylinders that have black e coated bodies with plated caps. I hesitate to mention that, as I was shouted down here several years ago for questioning if any of these with the E coated castings were installed on the assembly line. People were sure that never happened, that style master was always bare metal. They must have E coated ones used for replacement parts so they wouldn't rust when in inventory was the theory as to how they exist. I was involved in a project at Raybestos around 12 or 13 years ago where we came out with a "premium" line of wheel cylinders, and one of the enhancements was that we black E coated the castings. That turned out to be a real headache, all the work setting up a complete second set of bills of materials, keeping otherwise identical wheel assemblies isolated from each other, and the added cost of the e coating, doomed the project and it was abandoned within a year. The fact that I don't think we were fooling customers much that a shiny black wheel cylinder with a higher grade of plating on the bleeder screw was worth paying more for than what our standard wheel cylinders cost! If they wanted to keep replacement drum brake master cylinders from rusting while on the parts dealers shelves, I would think they would have painted them, not E coated them. That is why I wonder if any originally installed drum brake Mopar masters were E coated black. Sorry to go a little off topic on the subject of original finishes! One of the few things about Mopar master cylinders I don't feel like I am an expert on.
#1896370
08/21/15 03:03 AM
08/21/15 03:03 AM
Mastershake340
Crook County, ILL
"0112" are the last 4 numbers of the Chrysler part number. I don't have anything in my notes with any Chrysler part numbers ending in 0112. I must admit though, when I was digging through the records at my old work over 10 years ago, I didn't dig too much into anything after '71. Now I wish I had when I had the chance. I am not completely sure on your tag question. Manual brake master cylinder primary pistons have a indentation machined into the recess where the push rod inserts into it, for the rubber retainer used on manual brake push rods to lock the pushrod in place. Most of the disc brake master cylinder primary piston recesses from that era have this indentation too though I've noticed, even though it serves no purpose with the push rod used with a booster. Those tags with part of the part number didn't appear until the early 70s. I've seen some tin tags on disc brake master cylinders from the late 60s, but on those tags, only a date code appeared. By late '68 or early '69 they didn't have the tags any more, the datecode was stamped into the side of the casting. When the tags started being used again in the early '70s is when they started putting the 4 numbers from the part number and PWR on them, and I think others said Manual or an abbreviation for manual.
#1896470
08/21/15 12:40 PM
08/21/15 12:40 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
I checked with theramman and it looks like he may have one. I had him rebuild.a MC for me a few months ago that had the later part number. I'm not going to use it since I found the correct part for the GTS. It's now packed up in Mesa, I won't be down there until mid September. I can check if you can wait.
Abe Lincoln
[Re: dart4forte]
#1896479
08/21/15 01:10 PM
08/21/15 01:10 PM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
Hope these help. Easier to see if you save the pic then zoom in.
