Re: Best Brake setup for 15" wheels [Re: OLD318] #1896188
08/20/15 08:21 PM
08/20/15 08:21 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
feets what are the other diameters of the bearings? maybe make a cup to seat the small b body bearing that will press into the rotor?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Best Brake setup for 15" wheels [Re: AndyF] #1896219
08/20/15 09:07 PM
08/20/15 09:07 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
Originally Posted By AndyF
Best setup for 15 inch wheels would be a C body knuckle so you can run the thicker C body rotor. It takes work to get it on there but it can be done. I designed up a C body knuckle conversion for my car but I never installed it. The knuckle is extra tall so you need a new upper control arm.
The C body rotor is 1.25 inches thick so the Viper calipers fit without needing pad spacers. With some creative welding+ machine work the Viper calipers will bolt directly to the C body knuckles.
I mocked all of this stuff up a few years back but at the end of the day it was just a lot less work (and money) to swith over to 17 inch rims. The 17 inch rims allowed me to build a very easy 13 inch rotor kit with a ton of caliper choices. Sometimes you just have to take the easy path.
I did this 5 years ago. Works great! Mitch , it fit with my 15" minilite wheels too. You will need the one year only spindles though ( 1973) And they are desirable and expensive usually. Relatively speaking....
http://www.cuda-challenger.com/cc/index.php?topic=73985.0
Re: Best Brake setup for 15" wheels [Re: Jerry] #1896492
08/21/15 12:24 PM
08/21/15 12:24 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The problem is the spindle. It has a smaller diameter on the outer bearing. You either have to sleeve it from .750" to .8661" or find a bearing with a smaller ID.
- Stu Harmon
Re: Best Brake setup for 15" wheels [Re: OLD318] #1896534
08/21/15 01:43 PM
08/21/15 01:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My first generation Viper on 11.75" brake kit is back in stock.
It fits B/E body drum knuckles and '73-'76 A-body drum knuckles. Because it uses 1.25" thick C-body rotors, pad spacers are not required.
'72 and older C-body rotors fit '72 and older B/E body spindles.
'73 and newer C-body/truck/van rotors fit '73-'76 A-body spindles with a simple bearing spacer I supply.
Re: Best Brake setup for 15" wheels [Re: OLD318] #1896538
08/21/15 01:52 PM
08/21/15 01:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
BTW, '72 and older C-body rotors will fit '73 and newer A/B/E/F/M/J/R body spindles if you install Set 13 inner bearings in place of the stock Set 6 units.
I never looked for a small OD/large ID seal to make this combination work, however.
Re: Best Brake setup for 15" wheels [Re: OLD318] #1897058
08/22/15 10:58 AM
08/22/15 10:58 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
69-72 c body rotors are not a cheap item - aprox $130 ea and not a lot of choices
If you can get some worn ones, you can remove the disc from the hub and replace them with some around '75 vintage ramcharger/w100 4wd front rotors (raybestos #7036r, $29ea @ rockauto), you will need new studs too. Hubs may need machining to make it square - the factory would have you fitting them to the hubs and then machining the disc, screw that
So, significantly cheaper rotors and you can get drilled and or slotted ones cheap if that floats your boat ($90 a pair on feabay)
It is very hard to find calipers that exceed the surface area of the 2.75 piston brakes, there are very few out there and unless you -really- need to shed weight, get some, paint em red and feel happy that your factory parts are better on paper than a new set of willwoods
Re: Best Brake setup for 15" wheels [Re: Alchemi] #1897137
08/22/15 02:17 PM
08/22/15 02:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
73 and later rotors are the same size and are available from $35-$65 each on Rock Auto.
I've done that but not with that rotor.
Factory brakes are good and floating calipers are easier to package. However, you can gain brake pad surface area with larger fixed calipers.
- Stu Harmon
Re: Best Brake setup for 15" wheels [Re: OLD318] #1897188
08/22/15 04:16 PM
08/22/15 04:16 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Replacement '69-'72 C-body rotors are 1 piece castings, identical to the '73 and newer version with the exception of the bearing sizes.
I sell drilled/slotted/plated rotors, but the plain version is available for $100 each.
http://www.summitracing.com/parts/ben-prt1047/applications/
Re: Best Brake setup for 15" wheels [Re: OLD318] #1897510
08/23/15 01:35 AM
08/23/15 01:35 AM
Alchemi Offline
Alchemi  Offline
So can anyone tell me which bearings and seal to use 73 rotors on the 71 c body spindles?
Re: Best Brake setup for 15" wheels [Re: Alchemi] #1897526
08/23/15 04:03 AM
08/23/15 04:03 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'73 and newer rotors will fit '72 and older spindles if you use Set 16 bearings, DoctorDiff outer bearing adapters, Set 17 bearings and DoctorDiff inner bearing adapter/seal kit.
