Re: Quick Trans ?
[Re: DemonDust]
#1896226
08/20/15 10:15 PM
08/20/15 10:15 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Sounds like you have a lock up pump and non lock up convertor. Or vice versa. It will almost seem like you have a trans brake and you have to rev it up and then it will hit.
I made this mistake before, scratched my head for weeks. The pump I put in it worked fine in the first trans... that trans we forgot a torrington bearing in the OD and after about 400 miles it ate up the OD drum... so that pump worked.. I got it from Cope.. and I picked up another pump from him for my spare trans ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: MR_P_BODY]
#1896394
08/21/15 08:44 AM
08/21/15 08:44 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
If I had an overdrive I would still cruise at the same RPM as my car is really happy there(at least with the old motor) so an overdrive would just be there faster lol.
68 Barracuda Formula S 340
Re: Quick Trans ?
[Re: MR_P_BODY]
#1896415
08/21/15 10:35 AM
08/21/15 10:35 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
727 727 727 727 F that OD!
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
Re: Quick Trans ?
[Re: dizuster]
#1896418
08/21/15 10:47 AM
08/21/15 10:47 AM
MR_P_BODY
Mike this is the used trans, or the one just rebuilt? Used... bought it at the bone yard... pulled the pan and the oil was good and almost nothing in the pan (trash).... I went thru the one that was in it... I feel sure its good but I have lost my confidence... I'm gonna run it up to a trans shop in Almont thats suppose to be good on mopars and have him take it apart.. if he can get it done in a couple of days I'll pull the engine/trans ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: John_Kunkel]
#1896478
08/21/15 01:04 PM
08/21/15 01:04 PM
Posts: 16,932 NC
440Jim
NC
Balky Reverse and drives forward in Neutral is a rear clutch that's not releasing...usually due to a failed Belleville. Has to come out.
That is what came to my mind also (rear clutch not competely disengaged).
Re: Quick Trans ?
[Re: 440Jim]
#1896482
08/21/15 01:11 PM
08/21/15 01:11 PM
MR_P_BODY
I took my spare trans into the shop..this is the one I rebuilt myself... it should be fine.... but to be safe I took it in... I'll let them check it out... and he can have it done in 3 days... he said he'd pull it apart this evening.... so the engine and trans are coming out again.. today ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: Kindafast]
#1896530
08/21/15 02:39 PM
08/21/15 02:39 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My trans has always tried to creep in neutral and it works fine. Check your band adjustments front , the easy one and then try the rear " the one inside. Creeping in Neutral due to a tight rear clutch pack isn't all that unusual but the OP also has a bind-up in Reverse which isn't normal. Band adjustment has nothing to do with transmitting power, bands are brakes used to stop components from moving not to connect components...only clutches do that.
Re: Quick Trans ?
[Re: John_Kunkel]
#1896556
08/21/15 03:19 PM
08/21/15 03:19 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
My trans has always tried to creep in neutral and it works fine. Check your band adjustments front , the easy one and then try the rear " the one inside. Creeping in Neutral due to a tight rear clutch pack isn't all that unusual but the OP also has a bind-up in Reverse which isn't normal. This is why I brought up mismatched Converter and front pump. I've had it happen and this is exactly what it did to me. Not sure why it does it. But it did.
Re: Quick Trans ?
[Re: DemonDust]
#1896622
08/21/15 04:32 PM
08/21/15 04:32 PM
MR_P_BODY
My trans has always tried to creep in neutral and it works fine. Check your band adjustments front , the easy one and then try the rear " the one inside. Creeping in Neutral due to a tight rear clutch pack isn't all that unusual but the OP also has a bind-up in Reverse which isn't normal. This is why I brought up mismatched Converter and front pump. I've had it happen and this is exactly what it did to me. Not sure why it does it. But it did. This pump and this conv were working fine for over 400 miles till the OD drum burn up due to no torrington in the one thats in the shop now ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: quickd100]
#1896630
08/21/15 04:43 PM
08/21/15 04:43 PM
MR_P_BODY
If I lived close by I'd be there to give you a hand Mike. Dave Thanks... I'm just about ready to pull the engine/trans but I have to turn the car around... 2 of my buddies will be here in the morning to help turn it around... I'll pull tomorrow... then wait for the trans... if he tells me that everything looks good in the one I did.. then I'll do this one also as a spare.. I want him to verify the whole thing ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: MR_P_BODY]
#1896639
08/21/15 05:02 PM
08/21/15 05:02 PM
MR_P_BODY
Also.. found that its different today from yesterday.. today it moves about 10" in reverse and locks up... put it in park then back into reverse it moves 10".. I did this about 20 times trying to turn the car around... then said F-it and pulled forward onto the hoist to start tearing things apart ... turn it around tomorrow and pull it out ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
Re: Quick Trans ?
[Re: dizuster]
#1896723
08/21/15 07:25 PM
08/21/15 07:25 PM
MR_P_BODY
Mike, I had this happen on a 47RE in a diesel truck one time. It turned out that it had broken the middle ring on the input shaft.
As I remember this middle ring seperates the rear clutch and converter lube circuit. When the ring is broken, the converter lube will actually apply the rear clutch. Normally this isn't a problem because the rear clutch is "on" in all forward gears.
But it can cause the vehicle to move forward in Neutral, and bind in Reverse.
Isn't this the ring that you damaged that I had Tiffany drop off to you? Maybe it is damaged again (or a mismatch of parts not allowing them to go together properly?) The trans thats in the car is from the bone yard.. I changed the pump and input shaft and put a drain plug/temp gauge on it... thats all I did so maybe this thing was broke when I bought it... it just looked decent inside... if I changed the pump and the input shaft is in it... could I have broken that ring but the pump did slide in nice.. I used pins to align it.. but this sounds lie how its acting
Re: Quick Trans ?
[Re: MR_P_BODY]
#1897756
08/23/15 04:58 PM
08/23/15 04:58 PM
Posts: 5,160 Texas
dannysbee
Texas
Hope you get it worked out Mr. P. You U definatly deserve a break.
Getting old just means you were smarter than some and luckier than others.
