Re: Ok Let's talk about A-Body Master Cylinders
[Re: ScottSmith_Harms]
#1895338
08/19/15 01:50 PM
08/19/15 01:50 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I can take a picture of a Challenger Drum Brakes all around Master with Dana if that will help, original Master.Not sure if E and A used the same stuff in 1971 and have not looked in the parts book. You might also want to Message Mccannix he seems to be up on this stuff far more than I am.
1971 HEMI E BODY REGISTRY
#1895439
08/19/15 04:33 PM
08/19/15 04:33 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
All of the cars so far have disc brake master cylinders. You can tell because they have a big reservoir and a small reservoir. The drum masters will have equal size reservoirs. JeffC, That's what I thought as well, but here's a 1971 Duster parts car in my backyard, I can't swear that it's correct but it looks like original parts and it runs, drives, stops normally, it is a power drum brake car but since the fender tag is not coded for power brakes I can only assume the booster was added.
#1895464
08/19/15 05:26 PM
08/19/15 05:26 PM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
All of the cars so far have disc brake master cylinders. You can tell because they have a big reservoir and a small reservoir. The drum masters will have equal size reservoirs. JeffC, That's what I thought as well, but here's a 1971 Duster parts car in my backyard, I can't swear that it's correct but it looks like the original and runs, drives, stops normally, it is a power drum brake car. I think it was probably replaced at some point with the wrong master cylinder. I'm sure it stops fine I dont think the extra volume of fluid would effect the way the drum brakes work. I myself had a 69 Dart that was converted to front disc and I ran the drum brake master for a few years. It stopped good you just had to step on the pedal harder than normal.
#1895616
08/19/15 09:37 PM
08/19/15 09:37 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Should be the part number ending in 621. One inch bore. Worked for power and manual front disk brakes. It's often referred to as the Hemi MC. Are you looking for one?
Abe Lincoln
#1895748
08/20/15 02:44 AM
08/20/15 02:44 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Car
So the question. Where is the best source for the correct MC, one that does the job and looks correct? Swap meet I guess, a lot of the aftermarket ones have a small round recess in the front snout . I have a original MC for a manual drum for my 71 demon last time I checked the kit for it was available at Napa for around $35. I'd have to dig it out but it has numbers on the underside that jive with the SM, # 3461189
#1895852
08/20/15 11:58 AM
08/20/15 11:58 AM
dart4forte
Mesa, Arizona
Went back in my E-mails and here's what I found out.
67-68 used the MC 2225541. Had a 1" bore. Was used on both power and manual disc brakes. The MC lid had 70R3 stamping.
69-70 used MC 2229171 and 2229191 which was used on the Hemi cars. The lid had a stamping of J1703
It's my understanding that the 2229171 was used on all disc brake cars through 1975.
Also 70-71 Cuda/Challanger used 294444476 and 477.
Of course we all know the assembly workers used whatever part was available on a given day.
Abe Lincoln
#1895967
08/20/15 03:20 PM
08/20/15 03:20 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Car
So the question. Where is the best source for the correct MC, one that does the job and looks correct? Find an original and rebuild it ? I bought one about 13 yrs ago from Bill Rolik , he had some NOS ones, including the rod to the brake pedal, I put it in a friends 67 barracuda that he converted to discs ... wish I bought more than one ...
