Flywheel mounted pilot bearing,who sells them? #189428
01/10/09 01:48 PM
01/10/09 01:48 PM
wi.
Rosco Offline OP
Rosco  Offline OP
wi.
Where can I find a flywheel mounted pilot bearing for a BB engine without the countersunk steel crank?
Re: Flywheel mounted pilot bearing,who sells them? [Re: Rosco] #189429
01/10/09 02:58 PM
01/10/09 02:58 PM
Blaine, MN
Buzzrider Offline
Buzzrider  Offline
Blaine, MN
Are you looking for this? It does not mount to the flywheel. It actually is put where the nose of a torque converter sits.
http://cgi.ebay.com/ebaymotors/MOPAR-Man...108117008r16204
Re: Flywheel mounted pilot bearing,who sells them? [Re: Buzzrider] #189430
01/10/09 03:30 PM
01/10/09 03:30 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
b287 or pb287
I got one that has the bronze bushing from partsamerica for about $10. Fits in the convertor register.
$32 for a pilot bearing?
https://board.moparts.org/ubbthreads/show...t=1#Post3669791
Re: Flywheel mounted pilot bearing,who sells them? [Re: RobX4406] #189431
01/10/09 03:45 PM
01/10/09 03:45 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
mopar part number 53009180ab is the bearing
4338876 is the bushing
butch
Re: Flywheel mounted pilot bearing,who sells them? [Re: rhad] #189432
01/10/09 04:08 PM
01/10/09 04:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Flywheel mounted pilot bearing,who sells them? [Re: DAYCLONA] #189433
01/10/09 06:09 PM
01/10/09 06:09 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
I dont think it'll work without milling down the taper on the input shaft. The crank needs to be opened up to accept a pilot bearing.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: Flywheel mounted pilot bearing,who sells them? [Re: 70dart360] #189434
01/10/09 07:14 PM
01/10/09 07:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Well?......don't tell that to the 76 440 cast auto crank that I used this bearing in with a manual transmission, I wouldn't want it to reject it ......FYI, it was a bolt in deal
Re: Flywheel mounted pilot bearing,who sells them? [Re: DAYCLONA] #189435
01/10/09 07:20 PM
01/10/09 07:20 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Cool, been a long time since I messsed with 4 speed stuff. Was I right about the flywheel inserted pilot?
