Re: A engine oil pumps
[Re: Gavin]
#189372
01/10/09 07:36 PM
01/10/09 07:36 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Gavin, I leave the pump & end of pickup at 3/8" NPT but drill out the end of the pickups to .500" where they are welded to a more solid chunk of threaded round stock to thread into the pump. Takes a whole 30 seconds in the vice with a .500" drill bit do do something Milodon & Moroso should be doing....
Sorry Ryan, bear with me, I must be a bit slow today .....you don't touch the 3/8" hole in the pump, but you mention both leaving the end of pickup at 3/8 and also drilling out the end of the pickup to 1/2, and welding the new stock which threads to the (3/8) pump. Could you run that past me again.........thanks!
You're making it way too complicated..... take the Milodon or Moroso pickup & just run a .500" drill into the end of it where it threads into the pump. They're like .420" from moroso/milodon. That's it.... there's no wleding or tapping etc. You don't need 1/2" NPT inlet into your pump or pickup. A 3/8" NPT hole is larger than .500".....
I dunno why you guys are having pump/pan issues, obviously something is different between what you're using & what I'm using. Without having ever seen one in my hands that hit I can't really say what the deal is. All I can tell you is I've never had one hit which is odd seeing as how multiple people on here have had clearance issues, dunno. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Neil]
#189373
01/10/09 07:36 PM
01/10/09 07:36 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
Maybe there are manfacturing differences ![](/ubbthreads/images/graemlins/shruggy.gif) . This pan fit like profanity reference deleted, the bolt holes had to be elongated on both sides, it's like the pan is out of square ![](/ubbthreads/images/graemlins/hammer.gif) . If I ever buils another I'll use someone elses pan for sure.
[Re: aarcuda]
#189375
01/10/09 10:02 PM
01/10/09 10:02 PM
Posts: 189 long island new york
kingdust
i never had oil pump to pan clearance issues, ive built more than a few 340s ( not as much as ryan)but i did have a milodon pan that the bolt holes were'nt even close to lining up! sent it back to jegs and they sent me another one and that one worked. nothings ever perfect.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
[Re: justinp61]
#189382
01/11/09 12:07 PM
01/11/09 12:07 PM
Posts: 660 San Diego
formula S
San Diego
Pump #2.
I built a 360 over the summer and used a m72hv, and a stock pan that I got from mancini. No problems with fit, with that said the pump cover was cast differently, the screw pads on the pump cover were recessed. As far as oil pump and pickup modification on race engines, I disassemble the pump, drill the pickup out to 3/4", port and blend both suction and discharge sides of the pump. Then I use 3/4" O/D x.090 tubing to fab a pickup, then slide the pickup into the pump at least an inch, and braze it together this work really well. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: formula S]
#189384
01/11/09 04:16 PM
01/11/09 04:16 PM
Posts: 3,335 MARYLAND
69Cuda340S
MARYLAND
Here is what the top of my Mellings HV pump looks like. Bought last summer:
[Re: 69Cuda340S]
#189385
01/11/09 04:47 PM
01/11/09 04:47 PM
Posts: 15,493 the boonies
aarcuda
the boonies
ahaa!! Those bolts are countersunk A LOT. thats why some people arent having troubles with their (I bet).
The oil pump that caused me problems had a completely flat plate and that caused the hex heads to sit lower in the motor. I bet i wouldnt have had much (if any) problem with the pump in that picture. the one i had most trouble with look like :
