Re: A engine oil pumps [Re: aarcuda] #189366
01/10/09 07:22 PM
01/10/09 07:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Milodon Pan 30940 I think. It also had to be bent out to clear the pick up tube. This pan has been modified to work with Headman 1 7/8" Hustlers.
Re: A engine oil pumps [Re: justinp61] #189367
01/10/09 07:23 PM
01/10/09 07:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Pump.
Re: A engine oil pumps [Re: justinp61] #189368
01/10/09 07:24 PM
01/10/09 07:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Pump #2.
Re: A engine oil pumps [Re: justinp61] #189369
01/10/09 07:28 PM
01/10/09 07:28 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
yup, i have the same looking pumps out in my shop right now. if i wasnt watching football, id show the same pics....
you can get away with grinding the heck out of the bolt heads but the philips heads screws make it so much easier.
most people dont build up 340's and build 360's instead. i bet thats the difference
Re: A engine oil pumps [Re: aarcuda] #189370
01/10/09 07:31 PM
01/10/09 07:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had to do this on my 340 and 360 based 408. The pump and pan in the photos are for the 408.
Re: A engine oil pumps [Re: justinp61] #189371
01/10/09 07:32 PM
01/10/09 07:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I have a Milodon large capacity pan and a milodon HV pump on an LA 360 block and don't recall having an issue with the bolts hitting. I am going to take the windage tray out so maybe I'll test the oil pump to pan clearance with some clay.
I have a hot rod or car craft 408 engine build article somwhere around here and they also said the pan needed to be clearanced.
Re: A engine oil pumps [Re: Gavin] #189372
01/10/09 07:36 PM
01/10/09 07:36 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Gavin, I leave the pump & end of pickup at 3/8" NPT but drill out the end of the pickups to .500" where they are welded to a more solid chunk of threaded round stock to thread into the pump. Takes a whole 30 seconds in the vice with a .500" drill bit do do something Milodon & Moroso should be doing....
Sorry Ryan, bear with me, I must be a bit slow today .....you don't touch the 3/8" hole in the pump, but you mention both leaving the end of pickup at 3/8 and also drilling out the end of the pickup to 1/2, and welding the new stock which threads to the (3/8) pump. Could you run that past me again.........thanks!
You're making it way too complicated..... take the Milodon or Moroso pickup & just run a .500" drill into the end of it where it threads into the pump. They're like .420" from moroso/milodon. That's it.... there's no wleding or tapping etc. You don't need 1/2" NPT inlet into your pump or pickup. A 3/8" NPT hole is larger than .500".....
I dunno why you guys are having pump/pan issues, obviously something is different between what you're using & what I'm using. Without having ever seen one in my hands that hit I can't really say what the deal is. All I can tell you is I've never had one hit which is odd seeing as how multiple people on here have had clearance issues, dunno.
Re: A engine oil pumps [Re: Neil] #189373
01/10/09 07:36 PM
01/10/09 07:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Maybe there are manfacturing differences . This pan fit like profanity reference deleted, the bolt holes had to be elongated on both sides, it's like the pan is out of square . If I ever buils another I'll use someone elses pan for sure.
Re: A engine oil pumps [Re: justinp61] #189374
01/10/09 07:45 PM
01/10/09 07:45 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i agree.
in fact, on this last motor, the oil pan lip and or heightseal at the oil pump/flange end was messed up alsoi. the rubber seal sat up above the pan rail ends by about 1/4" of more. I put the pan on anyways think the installation would press the seal down but it split the seal instead.
Since then, Ive read another post on this site about the same exact thing. that person spoke with milodon about it and got a new pan.
I just modified the rubber seal to shorten it and that seemed to work.
maybe i got a factory defect. i got the pan from mancini
Re: A engine oil pumps [Re: aarcuda] #189375
01/10/09 10:02 PM
01/10/09 10:02 PM
long island new york
K
kingdust Offline
kingdust  Offline
K
i never had oil pump to pan clearance issues, ive built more than a few 340s ( not as much as ryan)but i did have a milodon pan that the bolt holes were'nt even close to lining up! sent it back to jegs and they sent me another one and that one worked. nothings ever perfect.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: A engine oil pumps [Re: Gavin] #189376
01/10/09 10:50 PM
01/10/09 10:50 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I did this a few times at Ryan's suggestion. Picture courtesy of Shady Dell.
Re: A engine oil pumps [Re: 68Fastback] #189377
01/11/09 09:40 AM
01/11/09 09:40 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I run one of the old MP HV oil pumps and the installation sheet was still in the box and it mentions filing the the edge of the plate for clearance on some pans.I filed mine before i installed it,then checked the clearance and it was fine.I run a Milodon low proflie 8qt pan on my 408
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: A engine oil pumps [Re: 77DragracerR/T] #189378
01/11/09 10:08 AM
01/11/09 10:08 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Destined for the tech archive
Rich H.
Esse Quam Videri
Re: A engine oil pumps [Re: ZIPPY] #189379
01/11/09 10:21 AM
01/11/09 10:21 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Thanks Ryan, gotcha
Re: A engine oil pumps [Re: Gavin] #189380
01/11/09 11:06 AM
01/11/09 11:06 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run a Mellings HV pump with a 6 quart Kevko oil pan and didn't have any clearance issues. It doesn't hit even when I mocked it up with no oil pan gasket.
Re: A engine oil pumps [Re: 69Cuda340S] #189381
01/11/09 11:39 AM
01/11/09 11:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the Melling HV pump on my 340 builds and
stock pans that I deepen to 8 qts and never had
the pan hit without a gasket
Re: A engine oil pumps [Re: justinp61] #189382
01/11/09 12:07 PM
01/11/09 12:07 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Pump #2.
I built a 360 over the summer and used a m72hv, and a stock pan that I got from mancini. No problems with fit, with that said the pump cover was cast differently, the screw pads on the pump cover were recessed. As far as oil pump and pickup modification on race engines, I disassemble the pump, drill the pickup out to 3/4", port and blend both suction and discharge sides of the pump. Then I use 3/4" O/D x.090 tubing to fab a pickup, then slide the pickup into the pump at least an inch, and braze it together this work really well.
Re: A engine oil pumps [Re: formula S] #189383
01/11/09 12:14 PM
01/11/09 12:14 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah I guess it does seem kind of stupid to drill the block to 9/16" main passages to the oil filter, when the pickup is only 1/2"...
Re: A engine oil pumps [Re: formula S] #189384
01/11/09 04:16 PM
01/11/09 04:16 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Here is what the top of my Mellings HV pump looks like. Bought last summer:
Re: A engine oil pumps [Re: 69Cuda340S] #189385
01/11/09 04:47 PM
01/11/09 04:47 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ahaa!! Those bolts are countersunk A LOT. thats why some people arent having troubles with their (I bet).
The oil pump that caused me problems had a completely flat plate and that caused the hex heads to sit lower in the motor. I bet i wouldnt have had much (if any) problem with the pump in that picture. the one i had most trouble with look like :
