Re: Let's do speedo and rear gear math! [Re: John_Kunkel] #1902331
08/30/15 10:50 AM
08/30/15 10:50 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Originally Posted By John_Kunkel
Originally Posted By lewtot184
i trust the math, not the gps.
Problem is, the math only guarantees an accurate odometer not an accurate speedometer. Many speedo errors are in the head itself.
GPS factors in new tire size without having to measure diameter and calculate to the original 7.00 X 14 tire, which the 'math' does not do.
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1902381
08/30/15 12:36 PM
08/30/15 12:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not exactly, what the math does not take into account, because it is an unknown, is the EFFECTIVE diameter of the old and new tire. Effective diameter is the actual diameter with the load of the vehicle on it, not the listed diameter specification.
And that is why the math is wrong. Problem solving is a [censored] when you don't know how the formula works.
Don't be the exception.
Re: Let's do speedo and rear gear math! [Re: lewtot184] #1902518
08/30/15 04:54 PM
08/30/15 04:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
FWIW, finally got around to checking my original factory reduction unit and it's .80 reduction.
Re: Let's do speedo and rear gear math! [Re: John_Kunkel] #1903631
09/01/15 01:21 AM
09/01/15 01:21 AM
I dont have GPS but I had assumed it was high tech dead on accurate, ain't so ???. What John said I would get the odo correct with the correct pinion then after that if the speedo ain't correct then it would need to come out & go to a speedometer specialty repair shop. I use 5 mile markers in a row on the interstate to check the odo and those portable lit up digital roadside MPH signs the city sets out on occaision to check the speedo
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1903680
09/01/15 03:18 AM
09/01/15 03:18 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Free version gives you actual mph, paid version gives you actual miles plus a wealth of other features. I have on IPhone, likely Android version. Invaluable for syncing speedo/odometer.
Re: Let's do speedo and rear gear math! [Re: Sxrxrnr] #1903988
09/01/15 01:22 PM
09/01/15 01:22 PM
dogdays Offline
dogdays  Offline
Actually to my way of thinking the GPS is MORE ACCURATE than the math because you're never quite sure how many ACTUAL revolutions the tire will require per mile. You can quote rolling radius all you want, but it has to vary some and that's a dynamic process. Think of drag slicks.
We use GPS to measure movement on civil structures, and that is well below inch accuracy. It's repeatable, as well.
R.
Re: Let's do speedo and rear gear math! [Re: John_Kunkel] #1904236
09/01/15 05:18 PM
09/01/15 05:18 PM
IMGTX Offline
IMGTX  Offline
When Lacking a GPS I would drive the car on the Interstate from mile marker to mile marker. Needs to be over 25 miles though, the more miles the better the accuracy.
I divide the miles traveled on the odometer and the actual miles travel by the mile marker signs to get a percentage. If it is 20 percent too low I get a speedometer gear with 20 percent less teeth to speed it up.
That being said, John is right about speedometer heads being off. My method works for calibrating the Odometer with the hopes the speedometer will be right afterwards.
twocents
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1904425
09/01/15 09:22 PM
09/01/15 09:22 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: Let's do speedo and rear gear math! [Re: Bull1tt] #1905351
09/02/15 11:19 PM
09/02/15 11:19 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
If the actual odometer head is off, the GPS method still factors that in and corrects it. Along with the effective tire diameter and all variables, so it seems. I don't see the GPS being inaccurate, so I'm confident the .67 ratio adapter is the answer. Thanks for all the responses!
