Re: Installing a Jerico 4 speed in 68-70 B-body
[Re: Chargerfan68]
#1902923
08/31/15 01:40 AM
08/31/15 01:40 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I just installed mine and set it to 8 turns with no counterweight. I drove it around the streets for about an hour and it felt just fine. Actually, alot more streetable than I thought it would feel. Than at the track, I had to abort the first run after about 3rd gear as it was slipping too much. I tightened it up eventually to 10 turns and it is performing real good now. I did add small counterweight and ran 3 runs with it. I might try to back off to 9 turns next track outing.
I don't know...maybe yours had a defect or something not right. are you sure you had the adjustments all even around the p plate? Just asking. You can pm me if you want for my number.
Good luck, Greg.
[Re: dogdays]
#1904285
09/01/15 06:38 PM
09/01/15 06:38 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Jerico...gotta love those Ford Toploaders! I'm amazed that someone hasn't gone off on the tranny like they do on Glides and TH400s.
Ford also made an overdrive 4th Toploader during the '70s.
R. shhhhh ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: Chargerfan68]
#2031695
03/15/16 03:04 PM
03/15/16 03:04 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
This is a great thread... Maybe some day I'll have enough power to need this...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: Cape]
#2032130
03/16/16 02:02 AM
03/16/16 02:02 AM
Chargerfan68
New York, USA
I was wondering what's your engine combo, rear gear and power your putting out? Those are nice times for a heavy car. The engine is a stock block with main studs-line honed, decked, bored to 4.350 with 440 source rotating assy. Comes in right at 10.4 compression. Edelbrock Rpm heads just cleaned up a little by me and a Victor portmatched intake. Cam is a Comp 640-648 (w/ 1.6 Harland sharps) at 268-272 dur at .050" degreed at 106 . I run a 1050 dominator 2 circuit conversion. It has Hooker super comps 2" headers. 4.30 rear gear with MT et drags 28/11.5 - 15 rears. Thanks for asking.
[Re: OhioMopar]
#2032131
03/16/16 02:03 AM
03/16/16 02:03 AM
Chargerfan68
New York, USA
This is a great thread... Maybe some day I'll have enough power to need this... Thank you...it is definitely worth the investment for me. I hope it last s a very long time. Best of luck.
