Page 3 of 3 1 2 3
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1891794
08/14/15 12:55 PM
08/14/15 12:55 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
If you have money leave it in there and start it and see what happens. If you are on a budget I would pull the pan and look for it. Too many could have, would have, should have scenarios in the long run. If it was me I would pull the pan and try to look for it at least. Some what a peace of mind that I can say I tried to look for it.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Dropped a tiny lock washer into open engine [Re: 70sixpkrt] #1894173
08/18/15 03:52 AM
08/18/15 03:52 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I think I would put a put a magnetic drain plug in and drive it.
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1894277
08/18/15 12:03 PM
08/18/15 12:03 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Jack the car up so it angles the engine back. Put a 12" or larger sub-woofer under your oil pan. Play some appropriate rap, preferably gangsta rap with explicit lyrics, at a very high volume.
The vibes should make the washer wanna chill in the oil pan, and probably smoke blunts. From there, you can fish it to the drain hole with a magnet.
Sometimes you gotta think outside the (speaker) box.
apimp
Re: Dropped a tiny lock washer into open engine [Re: 65Fury440] #1894365
08/18/15 01:57 PM
08/18/15 01:57 PM
dogdays Offline
dogdays  Offline
Bah!
Can't believe we're still on this non-issue. Does he or does he not have a screen on the intake of his oil pump? If there is a screen, end of story.
A magnetic drain plug would be nice, or a magnet epoxied to the outside of the bottom of the pan would work.
We need to get out of this oh-so-scary car business and take up crocheting. Knitting is too dangerous, those sharp needles!
R.
Re: Dropped a tiny lock washer into open engine [Re: dogdays] #1894484
08/18/15 03:46 PM
08/18/15 03:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The pan is steel. No need for epoxy. It will be happy to hold itself in place.
- Stu Harmon
Re: Dropped a tiny lock washer into open engine [Re: 65Fury440] #1894519
08/18/15 04:29 PM
08/18/15 04:29 PM
California
mickm Offline
mickm  Offline
California
apimp
haha
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1894605
08/18/15 06:08 PM
08/18/15 06:08 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Try this magnet....it should hold the washer still
http://www.ubergizmo.com/2011/07/worlds-strongest-magnet/
Re: Dropped a tiny lock washer into open engine [Re: Black_Bee] #1894608
08/18/15 06:10 PM
08/18/15 06:10 PM
Good Ole USA
djw383 Offline
djw383  Offline
Good Ole USA
On eBay search for item# 221851605926
Page 3 of 3 1 2 3
