Re: Borgeson Steering box for B-Bodies - r we good?
[Re: BergmanAutoCraft]
#1890353
08/12/15 04:33 PM
08/12/15 04:33 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Does the newer Borgeson ps box have a greater or lesser turning "angle" vs the stock Mopar old PS box?. Does anyone know this?
Also, the old standard Mopar ps box has 3.5 turns lock-to-lock; the T/A PS box has 2.7 turns lock-to-lock.
How many turns... lock-to-lock... is the NEW Borgeson-box? (this may have been asked sometime in the past when it was first introduced via the forum).
T/Anks ahead.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1890360
08/12/15 04:46 PM
08/12/15 04:46 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Also, the old standard Mopar ps box has 3.5 turns lock-to-lock; the T/A PS box has 2.7 turns lock-to-lock. (only when longer T/A pitman arm is included)
T/Anks ahead. Just to clarify for others as I know you already know this... The "T/A box" with 2.7 turns lock to lock is only with the special T/A longer pitman arm. The longer pitman gives it the increased ratio. The T/A box has revised end stops compensate for the longer arms.
#1890914
08/13/15 12:12 PM
08/13/15 12:12 PM
Mopar Mitch
Steve... yes.. I knew about the T/A internal stops.
Peter... thanks for the info.
T/Anks to both of you!
Mopar Mitch
[Re: OLD318]
#1893548
08/17/15 01:42 PM
08/17/15 01:42 PM
Posts: 4,443 Michigan
MarkZ
Worthy
Worthy
I installed the large sector version a couple months ago and have been very pleased with the results. Really, it feels like rack and pinion. The only installation issue I had with the kit itself was the seal retaining clip for the slop joint. You can't quite get it to bend correctly to hold the seal in place; this was solved just by reusing the stock retaining clip.
The box was well worth the price and made one of the largest day/night differences in how my car drives.
[Re: MarkZ]
#1893609
08/17/15 03:33 PM
08/17/15 03:33 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The box was well worth the price and made one of the largest day/night differences in how my car drives. That is how I would describe mine. Steering is now a non-issue, probably end up taking it for granted now lol.
Mopar to the bone!!!
#1904701
09/02/15 06:30 AM
09/02/15 06:30 AM
Posts: 161 New Zealand
dart6
New Zealand
Maybe you don't want to hear from the one that sells them and makes the installation parts...This box has evolved into an all brand new box and is even smaller than the 1st gen style. At this point, it's a bolt in and fits 99% of its intended applications without issue. If you have a hemi with 2.25" headers and a Tremec with 8 deg of pinion angle, you may have an issue....The key here is the feel. This box is a little faster ratio than stock and has a sharp on center feel, which is where the oe box falls short every time. I'm sure others will chime in here and there and you'll make a choice that works for you. Peter i bought the borgenson kit from you when you started selling them so i guess it is the 1st version. I bought it for a 70 B Body so i gather it is small sector. I haven't installed it yet. Were there problems with these boxes, is there something i can check Thanks
