Re: Mark Williams Billet Caps for 8 3/4
[Re: runnerrt]
#1890598
08/12/15 10:31 PM
08/12/15 10:31 PM
Posts: 550 Lakewood, Colorado
runnerrt
Lakewood, Colorado
Thanks for the input. My quest for a Dana begins
1969 Super Bee High School car I got back
2004 Ram 2500
[Re: Roughbird72]
#1890741
08/13/15 01:04 AM
08/13/15 01:04 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I was wondering what differential is best for a street/strip car. A spool. Many will disagree , but I've done it for years and never had a problem. Regarding the " wet road ' stories that this post is sure to generate , I don't drive my car when it is raining. There are certainly things you need to be aware of , but for a toy car , it is an easy choice.
[Re: tubtar]
#1890751
08/13/15 01:17 AM
08/13/15 01:17 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I was wondering what differential is best for a street/strip car. A spool. Many will disagree , but I've done it for years and never had a problem. Regarding the " wet road ' stories that this post is sure to generate , I don't drive my car when it is raining. There are certainly things you need to be aware of , but for a toy car , it is an easy choice. I agree.........
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: tubtar]
#1890782
08/13/15 02:23 AM
08/13/15 02:23 AM
Posts: 1,238 North Central, Indiana
Roughbird72
I was wondering what differential is best for a street/strip car. A spool. Many will disagree , but I've done it for years and never had a problem. Regarding the " wet road ' stories that this post is sure to generate , I don't drive my car when it is raining. There are certainly things you need to be aware of , but for a toy car , it is an easy choice. I had a spool in my 8 3/4 for one summer on the street. 3900#car + manual steering + spool = a b**** going around corners.
72 Plymouth Roadrunner 11.08@123.25
[Re: justinp61]
#1890869
08/13/15 10:40 AM
08/13/15 10:40 AM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I was hesitant to have a spool installed in my S-60 when I ordered it. The only time I can tell it's in there is turning tight into a parking spot which I try to avoid. On the street it shows no ill handling characteristics, even the few times I've been caught out and it rained. Nothing wrong w/ a spool on the street...even in the rain.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: fishy340]
#1891171
08/13/15 06:16 PM
08/13/15 06:16 PM
Quicktree
Don't listen to these guys....The weakest part of an 8.75 rear is the stupid adjusters which is a bolt in the center of the cap. The billet caps from MW will make your 8.75 a much better piece and it's more the Enough strength for 90% of the mopars out there. really not even close to being the real problem with an 8- 3/4
[Re: fishy340]
#1891229
08/13/15 07:46 PM
08/13/15 07:46 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Don't listen to these guys....The weakest part of an 8.75 rear is the stupid adjusters which is a bolt in the center of the cap. The billet caps from MW will make your 8.75 a much better piece and it's more the Enough strength for 90% of the mopars out there. Not sure exactly what "bolt" you're talking about? The adjusters, which are threaded discs on either side of the carrier don't change a bit moving to steel maincaps, and they certainly are not the weak link in an 8-3/4. The steel maincap (really needed on the driver side only) certainly do make the 8-3/4 a better piece, but still not applicable to a 500-cube, 4-speed, B-Body (IMO).
[Re: StealthWedge67]
#1891411
08/13/15 10:54 PM
08/13/15 10:54 PM
Thumperdart
State of confusion
How about a 3200 lb 700 horse 470 BB w/stock caps and w/60 ft`s in 1.36`s.......?
[Re: fishy340]
#1891553
08/14/15 02:04 AM
08/14/15 02:04 AM
Posts: 43,723 Bend,OR USA
Cab_Burge
Don't listen to these guys....The weakest part of an 8.75 rear is the stupid adjusters which is a bolt in the center of the cap. The billet caps from MW will make your 8.75 a much better piece and it's more the Enough strength for 90% of the mopars out there. Me think you mean the stupid boss for the retainer bolt for the adjuster, yes? The left(driver side) cap usually breaks at that boss first which destroy a bunch of other parts, been there, done that The last 8 3/4 I built and raced ended up bending the housing bad enough on the passenger side to rip the ladder bar mounts off it during a run at the starting line, NOT GOOD OP, if you do decide, or anyone else who wants to drag race a 8 3/4, do what ThumperDart did, add a backbrace before starting to race it
[Re: runnerrt]
#1891606
08/14/15 05:49 AM
08/14/15 05:49 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Your just as well off to take that billet cap money and light it on fire..........does about as much good. The cap is NOT the weak link
You will NEVER fix what is wrong with an 8.75. It flexes the case, which causes ring gear to move away from the pinion and shells teeth.......THEN, when all that carnage gets going in there running over itself, it breaks the cap. When it is trying to turn with gear teeth piled up on top of itself, SOMETHING has to give........it's usually the cap. So yeah, you can put a cap on it, and when it DOES shell the teeth, which it WILL, you still have a bunch of broken parts, in a rear with some really pretty, expensive caps
To fix something, you have to know what is actually happening..........seems a few, actually many, have no clue.......LOL!!!
[Re: Thumperdart]
#1891610
08/14/15 08:04 AM
08/14/15 08:04 AM
Quicktree
How about a 3200 lb 700 horse 470 BB w/stock caps and w/60 ft`s in 1.36`s.......? 700 HP are those CAB 700HP?
[Re: Quicktree]
#1891792
08/14/15 12:54 PM
08/14/15 12:54 PM
Thumperdart
State of confusion
How about a 3200 lb 700 horse 470 BB w/stock caps and w/60 ft`s in 1.36`s.......? 700 HP are those CAB 700HP? Yes, we share the same dyno and I drive to Oregon every sunday to dyno my stuff.
[Re: runnerrt]
#1891871
08/14/15 03:25 PM
08/14/15 03:25 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
First, let me say that the car in question would be better suited with a dana. I don't agree with the forensic explanation by Monte though, and here's why. I was breaking ringgear side caps on mine(3 times), and also seeing chipped teeth. Had I stopped there, I would have agreed with Monte's explanation. I went with a heavily gusseted housing, and added cap support load bolts. Still using the factory caps. I no longer broke caps, or chipped teeth. The failure at that point was pinion shaft shear. After 2 episodes of that, I went with a strange ultra case 9 with 35 spline pinion. Never even had to think about the rear end again. 8 3/4 has its place. But it's not under the car in question.
[Re: Thumperdart]
#1891937
08/14/15 06:20 PM
08/14/15 06:20 PM
Quicktree
How about a 3200 lb 700 horse 470 BB w/stock caps and w/60 ft`s in 1.36`s.......? 700 HP are those CAB 700HP? Yes, we share the same dyno and I drive to Oregon every sunday to dyno my stuff. thats what I thought . 700 CAB HP is around 600 real HP. to give you an example my challenger at 3100#s made 468hp to the wheels and ran 10.40 @ 130mph and thats with a tight converter and 16x32 steam rollers. car would run easy 10.20s range with those corrected. if you think you are making 700hp you are only fooling yourself.
