Re: can timing affect engine temperature?
[Re: sunroofgtx]
#1885453
08/05/15 09:00 AM
08/05/15 09:00 AM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Mike, thanks. I never thought of that. Quad, I'll check into that as well. A new timing chain set is on the Winter upkeep list. Mike, distributor is on its way. I want this trip to go as planned. As far a a bung, that might be an amazing idea. Let me get your address. We are leaving Fri morn.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: sunroofgtx]
#1885474
08/05/15 09:49 AM
08/05/15 09:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Friday morning? Hmm... anyone at the Nats going to have a welder? haha. Rick, you probably won't want to drive out here that close to the nats. I'm about 1 hr, 15 minutes from the track.
22675 Buck Allen Dr Marysville OH
I can try to pack my welder, it's not that big, but I need a solid 110vAC source to plug into. The welder will pull up to 20 amps and has tripped my breaker when I've had other things running on the same circuit.
**Photobucket sucks**
[Re: sunroofgtx]
#1885568
08/05/15 01:21 PM
08/05/15 01:21 PM
Posts: 10,235 Someplace you aren't
SomeCarGuy
How sure are you the rad was flushed good? Cap ok? That carb is junk, richening should be in order from what I've seen. Nats might be good place to snag a better carb.
Hood seals in place and in good shape?
I want my fair share
[Re: mattsmopars]
#1885905
08/05/15 09:34 PM
08/05/15 09:34 PM
sunroofgtx
Cleveland
MAtt, please call me!! I'll take the Imperial one if it'll fit!! Awesomeness.. Not sure on the flushing. I'm going to lube stop tomorrow to have them do it!! I'll wait on the bungs...Thanks a ton for the offer! You have always been so generous ! 216-224-3667
[Re: sunroofgtx]
#1885995
08/05/15 11:45 PM
08/05/15 11:45 PM
70Cuda383
Marysville, O-H-I-O
I'll be on the lookout for that sweet station wagon! I'll be hanging out at the Gerko Enterprises vendor tent most of the weekend, my Dakota will be there too. Stop by, have a beer!
