Page 2 of 3 1 2 3
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883195
08/02/15 12:11 AM
08/02/15 12:11 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
ATI with the front drilled for Big Chev.....opens up a door to a ton of accessories that are stocked everywhere. i.e. pulleys , mandrels.
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883219
08/02/15 12:37 AM
08/02/15 12:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
To me if its a rcae eng then ATI seems to be the best. But for a mild street/strip car like what I do I went with a Pro Sport balancer from Mancini and its not to pricey and has held up great on my 493. But remember I dont go racing every weekend and I dont street race. I drive my car alot and race it one or two times a year most of the time. Its SFI certified to like 18,000 rpm and I dont run over 6500. So its fine for what I do but all out race I would run an ATI. Ron
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883238
08/02/15 01:03 AM
08/02/15 01:03 AM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I have had the same Fluidampr on three engines and and my current engine is smooth as silk with that 20 year old Fluidampr.
Whenever a crankshaft breaks some builders are quick to point the finger at a Fluidampr as the cause just because they don't run them on their engines twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Harmonic Balancer .. which one?? [Re: fourgearsavoy] #1883258
08/02/15 01:30 AM
08/02/15 01:30 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Please stop calling them harmonic "balancers", they are harmonic dampers. They don't "balance" anything.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883348
08/02/15 08:09 AM
08/02/15 08:09 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Had 4 ATi dampeners over the years and one BHJ,(on different engines) the outer ring on the BHJ slipped after about 4 seasons but I don't know the recommended rebuild period for them.
Re: Harmonic Balancer .. which one?? [Re: Tig] #1883526
08/02/15 02:14 PM
08/02/15 02:14 PM
My first after market dampener was a Fluid Dampener, the second was a BHJ that cracked one of the spokes after limitled use, the next was a non SFI Pioneer, My next SFI dampener was a ATI and is still going strong after 12 years of use. Once Fluid Dampener went bankrupt and I saw all the bad comments on here about them, even if some of the comments may have been B.S., I have bought and used ATI up I have two complete ATI aluminum units in the shop now for high dollar, high HP motor builds and one ATI long hub that I will buy one of thier three ring steel outer dampener to use on my next build with a Milidon gear drive up BTW, the BHJ I bought and dyno tested was a all aluminum one that replaced a stock 340 dampener on the dyno, 7 lb differences in weight, we saw no measureable differences in HP or torque, maybe that test should have been at the track confused shruggy
Re: Harmonic Balancer .. which one?? [Re: DusterDave] #1883534
08/02/15 02:28 PM
08/02/15 02:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
What if you have a 360? smile
68 Barracuda Formula S 340
Re: Harmonic Balancer .. which one?? [Re: Bad340fish] #1883536
08/02/15 02:31 PM
08/02/15 02:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Those would be harmonic dalancers. bow
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Crizila] #1883556
08/02/15 03:00 PM
08/02/15 03:00 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Are you sure? What's a dalancer? laugh2
The OP is building a 493. Pretty sure its a steel crank internally balanced big block.
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1883583
08/02/15 03:34 PM
08/02/15 03:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Does anyone know if ATI makes a damper that will work with a stock pulley set up on a small block?
Thanks.
Re: Harmonic Balancer .. which one?? [Re: justinp61] #1883737
08/02/15 07:58 PM
08/02/15 07:58 PM
Thanks.
Call them tomorrow morning @ 877-298-4809, and ask for tech. scope up
Re: Harmonic Balancer .. which one?? [Re: Cab_Burge] #1883745
08/02/15 08:08 PM
08/02/15 08:08 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Thanks.
Thanks Cab.
Re: Harmonic Balancer .. which one?? [Re: justinp61] #1884192
08/03/15 11:45 AM
08/03/15 11:45 AM
an8sec70cuda Offline
I have an ATI on my hemi, no problems. up
I have a 15+ year old Fluidamper on my Indy headed 440...no problems. up
I had a BHJ damper on a 440 once. It slipped the outer ring after the first trip to the track. down
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1884304
08/03/15 02:08 PM
08/03/15 02:08 PM
Washington
madscientist Offline
Washington
So what we see here is marketing at it's very best. Maybe I missed one, but I didn't see anyone badmouth a FD who has actually USED one. Bought my first one in 1990 (IIRC) and still use them.
I do know this...if you are using an elosomer type dampner and they don't ask for your bobweight and RPM (at least) something is wrong, as elastomer type dampners are VERY sensitive to durometer, witdth, and thickness of the elastomer.
Re: Harmonic Balancer .. which one?? [Re: madscientist] #1884453
08/03/15 05:08 PM
08/03/15 05:08 PM
Az
Crizila Offline
Crizila  Offline
Az
Why I went with a fluid damper.
Fastest 300
Re: Harmonic Balancer .. which one?? [Re: Dduster] #1884493
08/03/15 06:18 PM
08/03/15 06:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By Dduster
Need to buy harmonic balancer for new rb 493" race motor. Which is the favorite or best recommended? ATI. BHJ, TCI or Fluidampr?
Ran the Fluidampr for years w/no major issues but always had a little vibration then went to ATI and no more vibration FWIW. Also what always made me nervous was why the Fluidampr didn`t want you to balance your rotating assembly w/it on and no mention of that on others...... shruggy
Re: Harmonic Balancer .. which one?? [Re: Thumperdart] #1884499
08/03/15 06:35 PM
08/03/15 06:35 PM
Washington
Washington
Because at relatively low balancing speeds, you don't generate enough force to center the inner ring in the housing.
Funny thing is a converter is much the same.
When I balance clutches, I always zero the disc. You'd be surprised how far off a disc can be.
Re: Harmonic Balancer .. which one?? [Re: madscientist] #1884521
08/03/15 07:21 PM
08/03/15 07:21 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Makes sense and maybe why I "heard" the Fluidampr`s were originally designed for low rpm diesel motors.............. shruggy
Re: Harmonic Balancer .. which one?? [Re: Thumperdart] #1884550
08/03/15 08:01 PM
08/03/15 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never used mine on the balance... and dont have any
vibration at low idle or 8000+ rpm.... maybe some of the
other parts... but the ATI is good enough to cover it..
I use both but I like the ATI because its lighter
wave
Re: Harmonic Balancer .. which one?? [Re: MR_P_BODY] #1884616
08/03/15 09:36 PM
08/03/15 09:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Maybe mine was just goofy and I weighted em both and forgot exactly how much lighter the ATI was but wanna say about 2.5 lbs.
Page 2 of 3 1 2 3
