Re: Harmonic Balancer .. which one??
[Re: Dduster]
#1883238
08/02/15 01:03 AM
08/02/15 01:03 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have had the same Fluidampr on three engines and and my current engine is smooth as silk with that 20 year old Fluidampr. Whenever a crankshaft breaks some builders are quick to point the finger at a Fluidampr as the cause just because they don't run them on their engines ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1883258
08/02/15 01:30 AM
08/02/15 01:30 AM
Posts: 1,845 Tampa
DusterDave
Tampa
Please stop calling them harmonic "balancers", they are harmonic dampers. They don't "balance" anything.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: Dduster]
#1883348
08/02/15 08:09 AM
08/02/15 08:09 AM
Posts: 2,937 A shed in England
Tig
A shed in England
Had 4 ATi dampeners over the years and one BHJ,(on different engines) the outer ring on the BHJ slipped after about 4 seasons but I don't know the recommended rebuild period for them.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1883526
08/02/15 02:14 PM
08/02/15 02:14 PM
Posts: 43,312 Bend,OR USA
Cab_Burge
My first after market dampener was a Fluid Dampener, the second was a BHJ that cracked one of the spokes after limitled use, the next was a non SFI Pioneer, My next SFI dampener was a ATI and is still going strong after 12 years of use. Once Fluid Dampener went bankrupt and I saw all the bad comments on here about them, even if some of the comments may have been B.S., I have bought and used ATI ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I have two complete ATI aluminum units in the shop now for high dollar, high HP motor builds and one ATI long hub that I will buy one of thier three ring steel outer dampener to use on my next build with a Milidon gear drive ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) BTW, the BHJ I bought and dyno tested was a all aluminum one that replaced a stock 340 dampener on the dyno, 7 lb differences in weight, we saw no measureable differences in HP or torque, maybe that test should have been at the track ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: DusterDave]
#1883534
08/02/15 02:28 PM
08/02/15 02:28 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Please stop calling them harmonic "balancers", they are harmonic dampers. They don't "balance" anything. What if you have a 360? ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
68 Barracuda Formula S 340
[Re: Bad340fish]
#1883536
08/02/15 02:31 PM
08/02/15 02:31 PM
Posts: 7,506 Az
Crizila
Az
Please stop calling them harmonic "balancers", they are harmonic dampers. They don't "balance" anything. What if you have a 360? Those would be harmonic dalancers. ![bow bow](/ubbthreads/images/graemlins/custom/bow.gif)
Fastest 300
[Re: Crizila]
#1883556
08/02/15 03:00 PM
08/02/15 03:00 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Please stop calling them harmonic "balancers", they are harmonic dampers. They don't "balance" anything. What if you have a 360? Those would be harmonic dalancers. Are you sure? What's a dalancer? The OP is building a 493. Pretty sure its a steel crank internally balanced big block.
[Re: justinp61]
#1883737
08/02/15 07:58 PM
08/02/15 07:58 PM
Cab_Burge
Does anyone know if ATI makes a damper that will work with a stock pulley set up on a small block?
Thanks. Call them tomorrow morning @ 877-298-4809, and ask for tech. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: justinp61]
#1884192
08/03/15 11:45 AM
08/03/15 11:45 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I have an ATI on my hemi, no problems. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I have a 15+ year old Fluidamper on my Indy headed 440...no problems. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I had a BHJ damper on a 440 once. It slipped the outer ring after the first trip to the track. ![down down](/ubbthreads/images/graemlins/custom/down.gif)
[Re: Dduster]
#1884304
08/03/15 02:08 PM
08/03/15 02:08 PM
Posts: 4,457 Washington
madscientist
Washington
So what we see here is marketing at it's very best. Maybe I missed one, but I didn't see anyone badmouth a FD who has actually USED one. Bought my first one in 1990 (IIRC) and still use them.
I do know this...if you are using an elosomer type dampner and they don't ask for your bobweight and RPM (at least) something is wrong, as elastomer type dampners are VERY sensitive to durometer, witdth, and thickness of the elastomer.
[Re: madscientist]
#1884453
08/03/15 05:08 PM
08/03/15 05:08 PM
Posts: 7,506 Az
Crizila
Az
I do know this...if you are using an elosomer type dampner and they don't ask for your bobweight and RPM (at least) something is wrong, as elastomer type dampners are VERY sensitive to durometer, witdth, and thickness of the elastomer. Why I went with a fluid damper.
Fastest 300
[Re: Dduster]
#1884493
08/03/15 06:18 PM
08/03/15 06:18 PM
Thumperdart
State of confusion
Need to buy harmonic balancer for new rb 493" race motor. Which is the favorite or best recommended? ATI. BHJ, TCI or Fluidampr? Ran the Fluidampr for years w/no major issues but always had a little vibration then went to ATI and no more vibration FWIW. Also what always made me nervous was why the Fluidampr didn`t want you to balance your rotating assembly w/it on and no mention of that on others...... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Thumperdart]
#1884499
08/03/15 06:35 PM
08/03/15 06:35 PM
madscientist
Washington
Need to buy harmonic balancer for new rb 493" race motor. Which is the favorite or best recommended? ATI. BHJ, TCI or Fluidampr? Ran the Fluidampr for years w/no major issues but always had a little vibration then went to ATI and no more vibration FWIW. Also what always made me nervous was why the Fluidampr didn`t want you to balance your rotating assembly w/it on and no mention of that on others...... Because at relatively low balancing speeds, you don't generate enough force to center the inner ring in the housing. Funny thing is a converter is much the same. When I balance clutches, I always zero the disc. You'd be surprised how far off a disc can be.
[Re: Thumperdart]
#1884550
08/03/15 08:01 PM
08/03/15 08:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Makes sense and maybe why I "heard" the Fluidampr`s were originally designed for low rpm diesel motors.............. I never used mine on the balance... and dont have any vibration at low idle or 8000+ rpm.... maybe some of the other parts... but the ATI is good enough to cover it.. I use both but I like the ATI because its lighter ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#1884616
08/03/15 09:36 PM
08/03/15 09:36 PM
Thumperdart
State of confusion
Maybe mine was just goofy and I weighted em both and forgot exactly how much lighter the ATI was but wanna say about 2.5 lbs.
