Re: CNC'd ported vs hand ported heads: Discussion, long post
[Re: BradH]
#1875894
07/22/15 05:22 PM
07/22/15 05:22 PM
Posts: 31,072 Oregon
AndyF
The article HERE brings up some of what you're talking about, too. That is a classic article. Anyone who wants to build a race engine should read that article a few times.
[Re: pittsburghracer]
#1875915
07/22/15 05:43 PM
07/22/15 05:43 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I bet you could improve on most hand port jobs like that as well.
I think a lot of people think CNC heads are desighned on a computer, they are not (normally). They are a digital copy of someones hand port job, it will only be as good as the original hand ported head. I think a lot of CNC programs are too conservative to keep from cracking and such and speed up the process and keep people from sticking too much head on their engines sort of like how people put too big of a cam in most home built engines.
If some one made a real awesome port and had it digitized you could make CNC copys just as good. Most CNC heads just don't have that awesome of a port to copy.
#1875959
07/22/15 06:25 PM
07/22/15 06:25 PM
BradH
My Son for example has no interest in giving it a try and I even paid for him to go to Darrin Morgans 2 day theory class. Wish I could have gone to one of those classes. Looks like he stopped doing them after going back to R-M full time. I'm just doing stuff like this in my spare time for fun(?). Not sure how long I could take it as a regular day job.
#1876032
07/22/15 07:51 PM
07/22/15 07:51 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I have flowed many cnc ported heads. AFR heads seem to be right on the money with my bench. All others have fell short. As cast heads usually flow really close to advertised though. It seems to me that the superflow 1200 puts out higher numbers. Maybe it is actually more accurate though and my bench is just reading low compared to big box stores with mack daddy flow benches.
I really dont know what you guys mean by hand finishing a CNC port. I usually find no difference in flow sand rolling a port so mine are left like Brads picture above.
Btw, nice work Brad
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#1876041
07/22/15 08:06 PM
07/22/15 08:06 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I know of a small block engine that had its heads hand ported. After they started leaking water, they were scrapped, the same model/ type of heads were given a CNC port copied from the same guy who had hand ported the original set..... In other words his program/ parameters were used The results thus far..... Based on both sets of heads being on the identical engine and dyno, , at the same track, in the same car with no changes other than literally the heads ...It appears there is about a 20 horsepower difference in favor of the hand ported heads...... That was the difference on the dyno...... It appears the track difference is a solid tenth...... The CNC heads are without a doubt " smaller"..... But have more integrity regards the possibility of leaking. This on a 700 ish horsepower engine
[Re: B3422W5]
#1876061
07/22/15 08:24 PM
07/22/15 08:24 PM
sixpackgut
Charleston
I know of a small block engine that had its heads hand ported. After they started leaking water, they were scrapped, the same model/ type of heads were given a CNC port copied from the same guy who had hand ported the original set..... In other words his program/ parameters were used The results thus far..... Based on both sets of heads being on the identical engine and dyno, , at the same track, in the same car with no changes other than literally the heads ...It appears there is about a 20 horsepower difference in favor of the hand ported heads...... That was the difference on the dyno...... It appears the track difference is a solid tenth...... The CNC heads are without a doubt " smaller"..... But have more integrity regards the possibility of leaking. This on a 700 ish horsepower engine Sounds like that small block wants a bigger set of heads
[Re: Porter67]
#1876065
07/22/15 08:30 PM
07/22/15 08:30 PM
sixpackgut
Charleston
I will dig up some pics on my work computer late tonight of a cnc port before and after. For example as cnc programs vary and ive seen areas like where the bowl/runner meet that fair better with a cleanup and removing a bit of material. I myself never sand roll anything, just use a finer cutter in a die grinder and like that finish.
Also with the limited heads for small blocks to increase port volume and csa using a cnc head as a start helps since most are done in so called 'stages'.
I know what your saying, i have a set of west coast cylinder heads "stage two" in my garage right now.
[Re: sixpackgut]
#1876068
07/22/15 08:34 PM
07/22/15 08:34 PM
B3422W5
Portage,michigan
I know of a small block engine that had its heads hand ported. After they started leaking water, they were scrapped, the same model/ type of heads were given a CNC port copied from the same guy who had hand ported the original set..... In other words his program/ parameters were used The results thus far..... Based on both sets of heads being on the identical engine and dyno, , at the same track, in the same car with no changes other than literally the heads ...It appears there is about a 20 horsepower difference in favor of the hand ported heads...... That was the difference on the dyno...... It appears the track difference is a solid tenth...... The CNC heads are without a doubt " smaller"..... But have more integrity regards the possibility of leaking. This on a 700 ish horsepower engine Sounds like that small block wants a bigger set of heads Yep.... The bane of 59 degree Mopar stuff since guys started offering long armed cranks.Huge cubic inch potential, but small 30+ year old heads designed to be used on sub 400 inch stuff at most. Big drink, small straw.
[Re: v cummins]
#1876084
07/22/15 09:23 PM
07/22/15 09:23 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My thought is there is no difference between CNC Ports versus Hand Ports. The bad part about hand porting is duplicating all the other holes. This took me about two weeks--not two days. As Mr. P Body states, having a good master is the key. If you copy a bad port, you wind up with a bad port. By hand porting, once you have a good intake and exhaust port, you have to humanly duplicate it by measuring; which is extremely difficult and very time consuming. But worth the time. That is why everyone with a grinder can't port heads. Very tedious time consuming work.
[Re: tboomer]
#1876087
07/22/15 09:26 PM
07/22/15 09:26 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
John...I am quite happy with my hand ported Victors. Radar Lechtenberg did them along with matching the Indy intake. He learned the trade in the late 70s from Gary Ostrich. Worked for him a while before setting out on his own. He used to do a lot of Top Fuel stuff till it got to be too much work for him. Radar is still doing cylinder heads but he is getting up there in years and has slowed down a bit. The guy does a heckuva job and I am proud to have a set done by him! Me too! I had Radar do my 440-1s, and recommend a cam. First time out, 8.96 at 3,000 lbs, 528 cubes.
[Re: Hot 340]
#1876131
07/22/15 10:34 PM
07/22/15 10:34 PM
Posts: 4,457 Washington
madscientist
Washington
A cnc machine knows nothing by itself. If the cnc port doesnt move air then the digitized hand port lacked talent. And tool deflection? Really? Even if it pushed .010 it would still be a better REPEAT than a hand port. l deflection IS an issue and depends on several factors. I wouldn't [censored] about .010. If you can't match CNC heads by hand for repeatability you need a better porter.
[Re: Duner]
#1876338
07/23/15 01:06 AM
07/23/15 01:06 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I will never claim to be a professional but I do enjoy doing it most of the time. I would never want to do it for a full time living. Just finished my Indy's at 11 pm tonight. Will do the final valve job and deck cleaning tomorrow and hopefully on the engine ready to go in sometime tomorrow. Who knows maybe some passes this weekend
[Re: Duner]
#1876343
07/23/15 01:15 AM
07/23/15 01:15 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
. Thanks. Can't wait to give them a try
