Re: Best Compression Ratio for Best MPG - 440 Question [Re: WyleECoyote] #1877247
07/24/15 02:03 PM
07/24/15 02:03 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
From a financial and practical point of view I would get the overdrive and a set of 3.08's or 3.54's first. Used transmissions can be had for $500 and up, and those diffs are everywhere, probably $250 to $500.
For a thousand bucks you will pick up at least 5mpg, and maybe up to 7mpg more.
FWIW, a 488 V10's have been known to get 15, 16mpg so there is no reason a 440 can't do it as well.
All highway mpg I'm quoting, if this is in town use then everything goes out the window.
Mo' Farts
Moderated by "tbagger".
Re: Best Compression Ratio for Best MPG - 440 Question [Re: Grizzly] #1877524
07/24/15 09:39 PM
07/24/15 09:39 PM
IN
ahy Offline
ahy  Offline
IN
As many have said, its a juggling act. I'd add that pushing compression too much and getting into pinging/detonation is no fun. With the open chamber iron heads (no quench) I would suggest 9:1 max. If you fit KB quench pad pistons and machine the pad on each hole to get .035 - .040 quench, maybe a bit more. Even with the above it may need premium fuel.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: ahy] #1877605
07/25/15 12:19 AM
07/25/15 12:19 AM
Here
jcc Offline
jcc  Offline
Here
Did OP mention his elevation and is he going to pulling a lot of hills? I would be surprised if 9:1 on pump gas is useful here. Three points I would press, coatings, skirt piston, exhaust port, A Hyd roller, and wait till the EFI is part of the equation, that alone will make more difference then anything mentioned so far and be a lot easier to tune to the edge. twocents
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
Re: Best Compression Ratio for Best MPG - 440 Question [Re: WyleECoyote] #1877648
07/25/15 01:46 AM
07/25/15 01:46 AM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
What you need sounds just like the motor I have listed in the engines for sale section.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: WyleECoyote] #1878447
07/26/15 02:53 PM
07/26/15 02:53 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I did use a liberal amount of themal barrier and dry film lube ooatings in my 440 build. I also spent considerable time dialing in the carb tune and ignition curve.
I didn't go efi or overdrive because the return on investment didn't seem like it would be there. I had gone from a tired old beater with 8 mpg to a freshly rebuilt engine and driveline at 18 mpg .Dumping another 3-4 grand to get into the low 20s didn't seem worth it to me.
Now if you already have a good engine and trans in the vehicle that don't need to be reuilt, then efi and overdrive may be the next logical progression and make more sense.
However, building an engine for a huge, pool table flat torque curve means you have enough torque to overcome the lack of additional gears in the transmission and do not need to build to a narrower rpm range to get good mileage.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: HotRodDave] #1879008
07/27/15 11:43 AM
07/27/15 11:43 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted By HotRodDave
I ran 10-1 with an iron head 318 in an extended cab long bed 98 ram with a stock cam and very tight quench, even pulling a 65 dart on an open trailer and a bed full of parts out of LA on the big pass it never pinged on 87 octane california crap gas.
I would expect the smaller displacement is coming into play there as well.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: WyleECoyote] #1879015
07/27/15 11:56 AM
07/27/15 11:56 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Compression makes torque.
I'm currently starting the build of a 10.5/11-to-1 cr 360, with the aim to get very good mileage and decent power.
I settled on a CompCams 20-221-3 (XE256H) cam.
The current daily 318 simply lacks the torque to work the heavy 518 transmission to easily get above 10-11mpg. Most of that comes from the 15-20 minutes commute trips to work and back everyday.
On the highway it manages 15mpg.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: WO23Coronet] #1879224
07/27/15 03:57 PM
07/27/15 03:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By WO23Coronet
I really wish I could find Dunnuk's article, he got ridiculous mileage with his 440, I'm sure it was 20 when empty
I read same art. He used a comp cam hdy. roller kinda big but was in mid 20s on fuel mileage in a car. I kept article but cant find it either, maybe he will we this and help
Might add the cam had some weird numbers for duration.
Re: Best Compression Ratio for Best MPG - 440 Question [Re: cudaman1969] #1880107
07/28/15 03:42 PM
07/28/15 03:42 PM
dogdays Offline
dogdays  Offline
Another 440 4x4 4.10 axle 3/4-ton build: I put the idea together for a friend.
KB 184 with squish set at 0.040
Measured 9.5:1 compression with the 452 heads.
The above took a little juggling and extra work by the machinist but he seemed to be into it.
Hughes cam HE1423BL.
Perf RPM intake
Can't remember the carb
Headers
Mileage in everyday driving jumped from 8 to 15. The truck would run on midgrade, he didn't want to try regular but it probably would have been OK. This guy was ecstatic, it about doubled his real horsepower, too.
R.
