Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1875226
07/21/15 07:03 PM
07/21/15 07:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Doesn't the headlight switch feed the dimmer? Otherwise the dash lights and parking lights would be on all the time.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: stumpy] #1875244
07/21/15 07:27 PM
07/21/15 07:27 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Yes. The H.L. Switch actually controls 2 seperate circuits with 2 different power feeds. Black with white tracer wire (from main harness power in splice) switches to green power wire to Floor H.L. Dimmer switch. Power from dome lamp circuit runs to H.L. Switch (pink wire pigtailed to grey clock wire at back of switch) and powers the Parking Lamps. When you turn on Parking Lamps power flows through Switch to yellow wire to Dimmer Switch. Pic shows the Dome/ Cigar Lighter circuit removed from a '70 Coronet Dash Harness. Top Right you can see the fuse tap with red and pink wires. That's where power enters this circuit.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1875288
07/21/15 08:32 PM
07/21/15 08:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A wiring diagram would be much more helpful than a pic of loose wires.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: stumpy] #1875315
07/21/15 09:19 PM
07/21/15 09:19 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
That's why I have an FSM. Don't you?
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1875521
07/22/15 01:37 AM
07/22/15 01:37 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's a neat wiring harness you posted but it doesn't help the OP very much because it's hard to see where the wires would go. But a wiring diagram would. Why would I need a FSM for a car I don't own? shruggy
Re: Converting dash lights to superbright LEDs - Questions.. [Re: stumpy] #1875599
07/22/15 08:46 AM
07/22/15 08:46 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Well if you had the '70 Coronet FSM then you could have pointed out that I was wrong. Power to the dimmer switch does come through the H.L. Switch, but from the Stop and Tail Lamps fuse, not the Dome Lamp, as I had previously posted, and through a black wire pigtailed from the back of the H.L. Switch, other end pigtailed to a yellow w/ black tracer wire at back of Dimmer Switch. What's confusing about the FSM schematic is the multiple use of Pink Wires. Three different circuits use Pink as power wires, Parking Lamps- dimmable circuit, Windshield Wiper, and Brake- Dome Lamp( from the Hazard Flasher which also runs power to the Flasher Switch, opposite side of connector). And the Brake Lamps are on the Hazard Flasher fuse, not the Stop and Tail Lamps fuse.
The '70 Coronet FSM is not available for free download from MyMopar.com, and the schematic they have available pales in comparison to what's printed in the FSM.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: Pynzo] #1875899
07/22/15 05:30 PM
07/22/15 05:30 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Ask and ye shall receive.
I’m listening.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: Pynzo] #1875926
07/22/15 05:51 PM
07/22/15 05:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I believe I said you were incorrect and didn't need a manual to figure it out.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: stumpy] #1876025
07/22/15 07:44 PM
07/22/15 07:44 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
That read like a question, so I answered it. Didn't recognize it as a cryptic remark on my response. My bad.
And I am correct- pink wire powers the parking lamps and dimmer switch.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876696
07/23/15 06:11 PM
07/23/15 06:11 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
My Dome lamp, map light, glove box, turn signals and bright lights indicator all work properly..
The only thing that doesn't work are the dash lights.... frown
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876703
07/23/15 06:17 PM
07/23/15 06:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you try supplying power to the dash light fuse?
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876709
07/23/15 06:30 PM
07/23/15 06:30 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
in your diagram - E1-18T Instrument Lamp (FEED) feeds the instrument panel fuse in the fuse block. The E2-18O (fused output)goes to the instrument panel lights. Both 18T (top of the fuse) reads 0 volts as does 18O) bottom of the fuse... when using the voltmeter...
My thinking is my dimmer switch is bad... as all other lights, Dome, door jam switches, turn signals and indicators on the dash, H/L headlamps. bright light indicator and map light all work...
From the diagram this implies that the H/L feed to the dimmer switch L7A-18BK is hot - otherwise no dome light etc...
What do you guys think?
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876711
07/23/15 06:32 PM
07/23/15 06:32 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
No I haven't tried to supply power to the top of the instrument panel fuse... Guess that's my next test - doh!! smile
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876713
07/23/15 06:33 PM
07/23/15 06:33 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876721
07/23/15 06:51 PM
07/23/15 06:51 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Jump the dimmer and see if you get dash lights.
I want my fair share
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876775
07/23/15 08:11 PM
07/23/15 08:11 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
next car task on my list!
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876893
07/23/15 10:12 PM
07/23/15 10:12 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Originally Posted By OLD318
That's my problem - no dash lights now!
When I work the dimmer switch I get nothing.
I checked the fuse block - no voltage at either the top of the fuse or
the bottom of the fuse - I took the fuse out and it's perfectly intact not blown.
I guess I need a new dimmer switch (sucks!)
anyone else ever have this problem?
I installed the 5-LED Lights from O'Reilly's in the dash of my 84 D350. I installed four of the nine and stopped to check them out. They looked great. I continued on and installed the rest - and then they didn't work. I chased the problem for DAYS. My finding: They were polarity sensitive!!! I used my Power Probe to find the + and - of each bulb, then traced the circuitry of the dash insert for the + and - and installed the bulbs accordingly and then, they worked!!
Good Luck!
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876898
07/23/15 10:18 PM
07/23/15 10:18 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Rotate the dimmer wheel. I've had a couple with dead spots- you can clean the resistance coil and contact of the dimmer switch with 1000 grit sandpaper and some WD40- cheaper than buying a new switch. Be gentle though- the coil is fragile. If you need an expert, JS Restoration can restore your switch. Check the Hot Deals forum.
Re: Converting dash lights to superbright LEDs - Questions.. [Re: OLD318] #1876906
07/23/15 10:28 PM
07/23/15 10:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The reason for applying power to the fuse is that it feds the bulbs directly. If they don't light then check polarity. It takes the dimmer out of the equation.
