CSR SuperShield...... details ? #187475
01/08/09 02:15 AM
01/08/09 02:15 AM
Florida STAYcation
IcorkSOAK Offline OP
Financed his waterbed
Florida STAYcation
anyone have complete data on this piece?
Re: CSR SuperShield...... details ? [Re: IcorkSOAK] #187476
01/08/09 09:47 AM
01/08/09 09:47 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Are you asking about the CSR carbon-fiber trans shields? Not sure exactly what you mean by "data"...
Re: CSR SuperShield...... details ? [Re: BradH] #187477
01/08/09 11:36 AM
01/08/09 11:36 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
These shields are often called carbon fiber but they are actually Kevlar with what appears to be an epoxy or Gel coat covering the Kevlar.
I spoke to the manufacturer and he told me that they do extensive testing to certify to the SFI spec.
Still I hope I never have to personally find out if they will hold an exploding 727.
Re: CSR SuperShield...... details ? [Re: DodgeCharger] #187478
01/08/09 12:08 PM
01/08/09 12:08 PM
Florida STAYcation
Florida STAYcation
Like weight, thickness, cost. And if the SFI cert does expire....and if it can be re-certed and the cost of same.
Are there any published tests ? ... can you explain what you mean by "extensive testing" ? ....
THANKS
Re: CSR SuperShield...... details ? [Re: IcorkSOAK] #187479
01/08/09 03:42 PM
01/08/09 03:42 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
They are to be used in stock bodied floor cars, If used in a tube chassis car (aluminum floor) you NEED to have a after market aluminum drum or steel billet drum. They changed from CSI to CSR for a reason.
I have one in each of my two drag cars and I have seen them do there job more than once by others when applied correctly. Cert expires every 5 years, I just had 2 of them recertified.
Keith
Re: CSR SuperShield...... details ? [Re: DodgeCharger] #187480
01/08/09 03:52 PM
01/08/09 03:52 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
true. i have one as well & sure am glad this didn't happen to my car.
Re: CSR SuperShield...... details ? [Re: Keith Richards] #187481
01/08/09 04:31 PM
01/08/09 04:31 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Good luck getting it to fit in a stock floor. I can tell you with 100% certainty it will not fit a stock a-body floor without modifications.
What are you implying here?...
Re: CSR SuperShield...... details ? [Re: dizuster] #187482
01/08/09 05:41 PM
01/08/09 05:41 PM
CT
turbocolt2.4L Offline
CT
I have on in my 69 charger 496/727 fits great and i also have one in my 72 dodge colt 2.4L/904 fits like it was made to go there........
Re: CSR SuperShield...... details ? [Re: dizuster] #187483
01/08/09 05:49 PM
01/08/09 05:49 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
not much of a mod really. what, 1 minute with a rubber mullet to massage over the firewall pinch weld? doesn't have to look pretty, the shield hides your handywork.
Re: CSR SuperShield...... details ? [Re: IcorkSOAK] #187484
01/08/09 07:12 PM
01/08/09 07:12 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
the shield is a nice piece ,I have the super shield on my 65 Coronet it fit perfect other than the front trans line . Also you have to remove the casting ears from the trans case. If you purchase one make absolutely sure you do not trim or modify any part of it. I trimmed mine about 1/4 inch to clear the front cooler line and now they will not certify it. The certification is good for 5 years, it cost $25 per sticker which it has two also you have buy new bolts when getting recert.total cost minus shipping is about$75 it's a ripoff having to do this , but the establishments say so , so you play the game.Now that I vented my frustrations about CSR .I wouldn't run without some kind of protection. It is a nice piece but could be better ,it weighs in at 4lbs about 1/4 inch thick and cost about $400
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: CSR SuperShield...... details ? [Re: 65dragnet] #187485
01/08/09 07:25 PM
01/08/09 07:25 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
My SB 727/CSR fits my Barracuda without modifications.(to the car)
Now I need one for a 904.
Re: CSR SuperShield...... details ? [Re: 65dragnet] #187486
01/08/09 07:31 PM
01/08/09 07:31 PM
oregon
greendart408 Offline
oregon
I had one and tried to install it in an a body with a 727 in the stock location. It was nowhere close to fitting without a huge hammer , im talking like beat the floor up about an inch or more. My car is a original 69 340 swinger.I didnt want to do that. I sent it back and installed a jw ultrabell and a blanket instead. Miles of clearance to the stock floor
Re: CSR SuperShield...... details ? [Re: S/ST 3040] #187487
01/08/09 07:46 PM
01/08/09 07:46 PM
S/ST 3040 Offline
S/ST 3040  Offline
Scratch that.
I forgot........mine was originally a Formula S/4-speed so, the floor
where the shifter was, must not be as tight as a factory automatic.
Re: CSR SuperShield...... details ? [Re: S/ST 3040] #187488
01/09/09 12:19 PM
01/09/09 12:19 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yeah the flange was the easy part. It was the rear portion that was problematic. The "hump" that holds the 3" belt in place hit the floor. I wasn't willing just to beat the floor to sucess. Also, it's right were the factory console shift brackets go, so I didnt' wan't to whack them out of shape. I ended up cutting a 2" wide x 10" long section out of the floor, and creating a nice bead rolled patch to go back in there...
Re: CSR SuperShield...... details ? [Re: S/ST 3040] #187489
01/09/09 05:44 PM
01/09/09 05:44 PM
Canada
CrAzYMoPaRGuY Offline
Canada
You wanna hear a good/weird one?
I have heard some techs fail the CSR shields if they have stickers on them. Anybody else hear anything about stickers/decals and composite shields? Is there anything in the rulebook about it, or does it void the inspection certificate?
CrAzYMoPaRGuY
Re: CSR SuperShield...... details ? [Re: CrAzYMoPaRGuY] #187490
01/09/09 07:47 PM
01/09/09 07:47 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I hope not, because mine came with a big CSR sticker on it right from them....
Re: CSR SuperShield...... details ? [Re: dizuster] #187491
01/09/09 07:51 PM
01/09/09 07:51 PM
Canada
Canada
Mine too!!!!!!!!!
CrAzYMoPaRGuY
Re: CSR SuperShield...... details ? [Re: CrAzYMoPaRGuY] #187492
01/09/09 08:58 PM
01/09/09 08:58 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
They have never said poo to me about anything, they hardly even look at my car..
Guess it looks good enough , you should see some of the cars running here , and very "fast" cars
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: CSR SuperShield...... details ? [Re: CrAzYMoPaRGuY] #187493
01/10/09 05:33 AM
01/10/09 05:33 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
isn't the SFI std printed on a sticker & stuck to the side of them? it is on my shield, i made the tech inspecter get on his hands & knees to read the sfi #.
Re: CSR SuperShield...... details ? [Re: rebel] #187494
09/04/11 12:00 PM
09/04/11 12:00 PM
Finland
LUMI Offline
LUMI  Offline
Finland
just installin one on my -68 Charger
no way it will fit without a big
or lowering the rear mount about 1/2"
