Re: 8896 3 circuit rich down low [Re: Dodgem] #1893690
08/17/15 05:30 PM
08/17/15 05:30 PM
AndyF Offline
AndyF  Offline
Maybe you can but maybe you can't. All depends if the main circuit is designed to handle all the fuel that the engine needs or not. Before you tried that you would want to pull the carb apart and measure the main passages to see if it can handle the larger jets.
Re: 8896 3 circuit rich down low [Re: AndyF] #1893846
08/17/15 08:43 PM
08/17/15 08:43 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks Andy buddy say play with it a bit sooooo! LOL!
Re: 8896 3 circuit rich down low [Re: Dodgem] #1893905
08/17/15 09:41 PM
08/17/15 09:41 PM
Was the new carb. a HP version or a original pre HP carb? I like and have used a bunch of the original non HP 9375 on foot brake cars, they work good, last a long time up Not so on the other early carbs, same thing on the later 9375 HP I bought several years ago, it needed tuning before running good runaway
Re: 8896 3 circuit rich down low [Re: Dodgem] #1894596
08/18/15 06:03 PM
08/18/15 06:03 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
The 9375 (no dash) is old as dirt with pressed in air bleeds works awesome all the time the 8896 i'm trying for a friend is 1 year old hp I think pig rich down low great after 6500 1st gear for rest of the quarter. going to crack it apart next week and look in there. play with it a bit.
It would not work worth [censored] on his 410 Cubic inch de stroked hemi for a street car.
Re: 8896 3 circuit rich down low [Re: Dodgem] #1894757
08/18/15 08:52 PM
08/18/15 08:52 PM
Good luck up Let us know your results up I think I had one of those carbs. for a while, I sold it before fixing it shruggy The old stock # 9375 rock boogie
Re: 8896 3 circuit rich down low [Re: Dodgem] #1908534
09/08/15 11:08 AM
09/08/15 11:08 AM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Took new 574 to chassis dyno with my old 9375 pressed in air bleeds it was great AF till 6500 then leans out up two jet sizes that help AF past 6500 but then it lost hp and TQ.
Then dyno computer kept freezing so was done
94 octane 12.5 to 1
Re: 8896 3 circuit rich down low [Re: Dodgem] #1908593
09/08/15 01:05 PM
09/08/15 01:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s because the jetting controls the overall fuel available and the bleeds control the timing/curve of the fuel. Rich low lean up top is what we`ve gotten used to over the years but it doesn`t have to be that way anymore....... thumbs
Re: 8896 3 circuit rich down low [Re: Thumperdart] #1909021
09/09/15 02:04 AM
09/09/15 02:04 AM
In a house near you
Street Monkies Offline
In a house near you
what about trying a 30cc accelerator pump instead of 50cc?
Re: 8896 3 circuit rich down low [Re: Dodgem] #1910586
09/11/15 03:24 PM
09/11/15 03:24 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Not sure you can put a 30cc on a dommy?
