Re: Demon build
[Re: Quickrunner]
#1988551
01/11/16 04:14 PM
01/11/16 04:14 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Gonna fab up a dolly for the front, eliminate all the visible pinch welds on the rails, trans area and smooth firewall some. Then drop all the stock front suspension in favor of one of Bob's front end kits.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Demon build
[Re: Quickrunner]
#1989047
01/12/16 02:34 AM
01/12/16 02:34 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Man, talk about deja-vu! I even modded my seat back similarly. FYI, you can mount a 2nd gen Neon wiper motor BEHIND the firewall and keep wipers if you desire. OK I promise I wont crap on this awesome thread again...
Mopar to the bone!!!
Re: Demon build
[Re: cudaman1969]
#1989214
01/12/16 02:01 PM
01/12/16 02:01 PM
Quickrunner
Like those assassin bars, got a web site or number? I'll save my cals for the other car. Google up Smith Racecraft. They have a good site and are good to deal with on the phone.
Re: Demon build
[Re: 72Swinger]
#1989219
01/12/16 02:05 PM
01/12/16 02:05 PM
Quickrunner
Man, talk about deja-vu! I even modded my seat back similarly. FYI, you can mount a 2nd gen Neon wiper motor BEHIND the firewall and keep wipers if you desire. OK I promise I wont crap on this awesome thread again... I was going to look into some sort of aftermarket hot-rod type wiper motor for behind firewall. What year's on the Neon wiper notor? Did ya have to fab up new linkage to the arms? I couldnt tell ya a 1st gen from a 5th gen Neon. LOL
Re: Demon build
[Re: STEFF]
#1989298
01/12/16 03:52 PM
01/12/16 03:52 PM
Quickrunner
What size tubing is this? Looks Killer!! Nice work!! What size tubing is this? 4x6 3/16 wall
Re: Demon build
[Re: Quickrunner]
#1989313
01/12/16 04:15 PM
01/12/16 04:15 PM
72Swinger
Nebraska
Wiper motor was off a 2001, IIRC 99-2003 neon are same. I cut both arms in two and welded old arm to new arm, then built a mount on inside of firewall mimicking the stock angle for the motor. I can get you a pic if you want tonight.
Re: Demon build
[Re: 72Swinger]
#1989523
01/12/16 10:35 PM
01/12/16 10:35 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
Wiper motor was off a 2001, IIRC 99-2003 neon are same. I cut both arms in two and welded old arm to new arm, then built a mount on inside of firewall mimicking the stock angle for the motor. I can get you a pic if you want tonight. I have a similar setup in my pro street demon but I'm using a wiper motor from a late 90's early 2000's dodge ram 1500. It's small but powerful and I only had to take about 1/4" out of one of the linkages. It works great.
Re: Demon build
[Re: 72Swinger]
#1989799
01/13/16 12:14 PM
01/13/16 12:14 PM
Quickrunner
I think these wiper motors are pretty common in the newer Mopars. Nice I like it, reliable setup and hidden and cheaper than aftermarket hot-rod stuff. win win. Thanks Really wanted to retain usable wipers for possibility of doing drag week. Does your cage have a dash bar hidden under dash?
Re: Demon build
[Re: Quickrunner]
#1989823
01/13/16 12:48 PM
01/13/16 12:48 PM
72Swinger
Nebraska
Yes it does, pillar bars are as far forward as possible and through dash. Had to notch the pedal brace for crossbar but I retained full use of glovebox to.
Re: Demon build
[Re: Quickrunner]
#1990106
01/13/16 07:26 PM
01/13/16 07:26 PM
72Swinger
Nebraska
Here is a shot of the dashbar taken through the glovebox opening. I can measure the distance of it to the firewall if you have some A/C unit dimensions, I am interested in A/C eventually myself.
Re: Demon build
[Re: BuckeyeBrawler]
#1990680
01/14/16 03:44 PM
01/14/16 03:44 PM
Quickrunner
[quote=BuckeyeBrawler]Very nice work!! Absolutely fantastic. You can tell you put a lot of thought into this build [/quote Thanks! many hours spent staring at it, I like to think of it as engineering time
Re: Demon build
[Re: 72Swinger]
#1990690
01/14/16 03:51 PM
01/14/16 03:51 PM
Quickrunner
Here is a shot of the dashbar taken through the glovebox opening. I can measure the distance of it to the firewall if you have some A/C unit dimensions, I am interested in A/C eventually myself. Thanks for the pic, in research phase of AC/heat systems now. Really mostly to get windshield to defog properly and AC would probably be nice on drag week. I remember going late rounds in the roadrunner at night and windshield would fog if big drop in temp like that year at Norwalk running till wee hours.
Re: Demon build
[Re: Quickrunner]
#1994026
01/19/16 01:03 PM
01/19/16 01:03 PM
Quickrunner
Body dolly fabed up out of steel from old girls gymnastic balance beam (Thats why it's pink LOL) and dropped front suspension and pulled column out. Getting ready to smooth firewall.
