trans chatter #1873216
07/18/15 11:06 PM
07/18/15 11:06 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
My 04 Dak 3.7 with 46re trans I think that's the model 2 WD ??? Does that com from the converter or trans . I've heard both..Me Not a trans guy..Chatter 35 -45 mph then gone..
Re: trans chatter [Re: dynamite] #1873386
07/19/15 10:37 AM
07/19/15 10:37 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Any body ??? Kunkle,, mopar Ron ,others ??
Re: trans chatter [Re: dynamite] #1873418
07/19/15 11:46 AM
07/19/15 11:46 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Should have a 42RLE trans. Yes sounds like TQ chatter at that mph. Try this find a open road and drive steady at the mph this happens. Tap the brake pedal with your left foot and see if every time you let up the chatter happens. Signal from stop lite switch disengages the converter.
Re: trans chatter [Re: SALEM1912] #1873423
07/19/15 11:54 AM
07/19/15 11:54 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
There is a flash for a similar problem you might want to look in to.Try googling tsb 18-001-15 and see if this would help. There are some additives that you could use also help.
Re: trans chatter [Re: SALEM1912] #1873521
07/19/15 02:22 PM
07/19/15 02:22 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Thanks Salem..I'll try that Google..you are right it's 42 RLE., I tried the Lucas stuff .. no help ..
