Re: is there a better shifter ?
[Re: modelmakerinc]
#1873009
07/18/15 05:42 PM
07/18/15 05:42 PM
eh100
eh100
My T/A shifter must be close to 25 years old. Love it! You can swing the cable to a rear entry by pulling a couple of bolts out and swing the assembly around. I like that you can get a morse cable anywhere (usually a boat shop) in different lengths, if you need a replacement. ![](https://farm4.staticflickr.com/3310/4586958786_3ec71ccf7d_z.jpg)
[Re: ProSport]
#1873072
07/18/15 06:36 PM
07/18/15 06:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Love my B&M Pro Ratchet... wish I would have bought another over the B&M Quicksilver... I wouldnt ever put a PPP in my car.. they look like crap... I could build that in my shop.... what does it use to go from the shifter to the trans.... a cable ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Monte_Smith]
#1873097
07/18/15 07:08 PM
07/18/15 07:08 PM
MR_P_BODY
Of course they use a cable..........but so do most of the factory shifters and you wouldn't use that in a race car. A GOOD shifter is about the quality of the cable and how precise and repeatable the detents are in the mechanisms. Like the looks of the PPP or not, they are one of the most precisely machined shifters on the market. Couple that with a quality cable and correct adjustment and they are pretty much foolproof. Most shifters come with a very cheap cable that is prone to stretch.
Too many other shifters don't have positive detents and the shifter can be "in between". The detents on the PPP shifter is like a road map and has a positive stop at every location, it just doesn't slide in a gate and hit a stop. Very positive. Most ratchets can be caught "in between" as well when they get a little wear on the mechanism or if you don't pull it hard enough.
I tend to be a little more about function and weight, than "pretty", but have to admit I think the PPP is one of the best looking shifters out there as well as very light and well made. I have NEVER.... repeat... NEVER missed a shift with the pro ratchet... and like most other shifters it also uses a cable.. you can buy the skinny one or the heavy duty one... and I dont even call the pro ratchet the prettiest either.. but it doesnt fail... a slight touch of a finger or two and its done.. I'm not a fan of a gate shifter.... but to each his own ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: tex013]
#1873139
07/18/15 08:42 PM
07/18/15 08:42 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Thanks for all input . I am fitting a proratchet this week for a customer , t400 , will try that Mrpeabody . I will also try a mates 1/4 stick . I think a couple of guys i race against have ppp shifters will check them out
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: MR_P_BODY]
#1873260
07/19/15 12:14 AM
07/19/15 12:14 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
I could build that in my shop.... no....... you can't.
[Re: tex013]
#1874372
07/20/15 03:34 PM
07/20/15 03:34 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
That's the first I've ever heard of a ProRatchet missing a gear, I didn't think it was even possible unless something in their is broken. I run a cheetah rmvb.
[Re: tex013]
#1874906
07/21/15 07:08 AM
07/21/15 07:08 AM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
PPP
Accept no substitutes
Cable exit can be front or rear
1974 Roadrunner
1967 Charger
[Re: Saskabusa]
#1874910
07/21/15 08:08 AM
07/21/15 08:08 AM
Posts: 1,629 pa
572charger
pa
hust quarter stick here put it in the car in 1984 still works perfect probably have 20000 + shifts on it !!! LOL
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
[Re: vc360]
#1874996
07/21/15 11:57 AM
07/21/15 11:57 AM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
T/A Cheetah here for close to thirty years still have the original cable, 0 problems
[Re: tex013]
#1875022
07/21/15 12:50 PM
07/21/15 12:50 PM
Posts: 7,506 Az
Crizila
Az
I'm sure a lot of people will laugh at this, but I use my factory ( I don't use no stinking cable ) solid linkage shifter. I fortunately have the room to do this in my car. ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) . I upgraded the pivot bushings so it is very positive and repeatable every shift. Only drawback to it is you can go from 1 to 3 if you are over zealous ( I have done it a few times ). Even incorporated the gear selector panel ( lit for night racing ) in my aluminum box cover.
Fastest 300
[Re: Thumperdart]
#1875096
07/21/15 02:59 PM
07/21/15 02:59 PM
Posts: 9,893 Weddington, N.C.
Streetwize
Weddington, N.C.
I always liked the Cheetah but I always run the Forward VB style gate whether I'm running a FVB or RVB; When you use a reverse VB you can slap back on the 1-2 as hard as you want and then for the 2-3 it's just slightly toward you and back again. With a 3 speed the 1-2 is always the harder and more critical shift to execute, the 2-3 has never been an issue to hit quick. Never worried about missing a shift but I could see that the RVB gate could have that tendency if you get a little over-anxious so I like the hard stop (no-miss) detent pulling back on the 1-2 and never minded easing it over for the 2-3 for the peace of mind. and on a FVB the cheetah kicks it over for you for the 2-3. The only thing that ever vexes me is initially which car I'm in (I have a FVB and a RVB car...both with Cheetahs)
I guess I never liked in-line or ratchets because it just doesn't feel natural to me....I went straight from years and years of 4 speeds to a Cheetah, so it's all what you're used to I guess.
[Re: J_BODY]
#1875114
07/21/15 03:39 PM
07/21/15 03:39 PM
Thumperdart
State of confusion
That's funny Thump. I had the same cheap azz shifter in the Mirada and it also worked great.... So good we bought another for the Duster and that thing was a miserable pos that we could never get properly adjusted. First I`ve heard of that but maybe they too use over-seas crap parts these dayz......... ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Thumperdart]
#1875262
07/21/15 07:55 PM
07/21/15 07:55 PM
tex013
Sydney,Australia
Thumper , I run the Pro Matic II shifter,since 2007/8, and that is my biggest bugbear , inability to get good/correct adjustment and whenever I pull the pan the adjustment goes out ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I do like the PPP but after mocking up off VC360's dimensions that will not fit with the bench seat . [censored] Fitted a Hurst 1/4 stick in a friends Roadrunner , with buckets , about 15 years ago been fine never even melted a cable . A mate has a 1/4 stick in his 65 Belvedere , mounted on a raised bracket , has bench seat , seems ok I have replaced 1 cable but with better shielding seems fine . Just fitted a ProRatchet yesterday in a Holden ute with T400 - wow that is a sweet feeling shift .After I race this weekend , Mopar Sunday , I may have to look at 1 and just make a raised bracket to clear the bench seat . I would like to keep my Hurst T handle with line lock button , so a ratchet seems the go. thanks Tex
[Re: Streetwize]
#1875268
07/21/15 08:04 PM
07/21/15 08:04 PM
tex013
Sydney,Australia
Wize , thanks for the insight that makes a lot of sense .uess like many others I want to avoid that missed shift that the reverse gate may promote
Tex
