Re: is there a better shifter ?
[Re: tex013]
#1875376
07/21/15 10:25 PM
07/21/15 10:25 PM
Posts: 4,715 Wichita
GY3
Wichita
Hurst Pistol Grip Quarter Stick here.
I Wrapped the cable with a heat resistant insulation and bent the trans bracket a little to clear the header and starter.
So far lots of street miles this Spring and it works perfectly!
It takes some getting used to as 1-2 is a normal shift and 2-3 requires you to pull the trigger. Release the trigger after 2-3 shift and it goes easily into neutral. It's almost impossible to miss a shift!
I have a TA Fwd pattern manual VB.
[Re: ProSport]
#1875580
07/22/15 05:18 AM
07/22/15 05:18 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
That's the first I've ever heard of a ProRatchet missing a gear, I didn't think it was even possible unless something in their is broken. I run a cheetah rmvb. I have seen several ratchet type shifters miss a shift. About the first ones were the B&M "Quick Click" but they all still seem to be made about the same. The detents never seem to be just exactly right, no matter how long the lever, or how many holes you put in it. That tells me the detents are not consistent, because you SHOULD be able to find a ratio that works.
[Re: tex013]
#1876010
07/22/15 07:28 PM
07/22/15 07:28 PM
Posts: 360 Ohio
shorthorse
Ohio
[Re: Monte_Smith]
#1877588
07/24/15 11:41 PM
07/24/15 11:41 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
That's the first I've ever heard of a ProRatchet missing a gear, I didn't think it was even possible unless something in their is broken. I run a cheetah rmvb. I have seen several ratchet type shifters miss a shift. About the first ones were the B&M "Quick Click" but they all still seem to be made about the same. The detents never seem to be just exactly right, no matter how long the lever, or how many holes you put in it. That tells me the detents are not consistent, because you SHOULD be able to find a ratio that works. I believe you, all racing parts have their glitches, but I've installed new Pro-Ratchets in many cars over the years and they have all been flawless, easy to adjust and never work on them again. I've always raced with one and now I drive my street Duster every day and wouldn't want any other shifter in that car, I love the ratchet action, easing a gate plate isn't for me at all but as Streetwise said, it's all about what you're used to using. One shifter I'd love to have just for looks is the TCI Outlaw, I think that thing looks awesome! But for the price they want, you may as well buy a PPP shifter.
![Name: 0803phr_04_z+1968_chevelle_tci_outlaw_shifter_installation+.jpg
ID: 203382 0803phr_04_z+1968_chevelle_tci_outlaw_shifter_installation+.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/203382/filename/0803phr_04_z+1968_chevelle_tci_outlaw_shifter_installation+.jpg)
[Re: tex013]
#1885973
08/05/15 11:22 PM
08/05/15 11:22 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Just an update . I bougjt and fitted a B&M proratchet . Wow what a difference over the promatic 2 . I did look at the PPP but with a bench seat and mocking one up there did not look like there was going to be enough room . Will be racing at the local nostalgia meet this weekend so i will see how it goes . I did make a 2 1/2 " extension for the shifter arm to get up above the bench
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1886137
08/06/15 08:23 AM
08/06/15 08:23 AM
ProSport
Akron, Ohio
Tex I knew you'd like it!
[Re: tex013]
#1886206
08/06/15 12:31 PM
08/06/15 12:31 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I'm a Pro Ratchet lover. I really don't think it could skip a gear if it was hit by a semi truck but....
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 383man]
#1886445
08/06/15 07:54 PM
08/06/15 07:54 PM
tex013
Sydney,Australia
Ron, you know I like your car and set up ! But with a bench seat you have to raise the shifter up , no problem , plus I use a Hurst T handle with lineloc button . That I think would be a problem . I have used the 1/4 stick style shifter in friends cars and was happy with it .
Tex
